How to Custom Paint a Nerf Maverick
71,149
65
16
Posted in PlayNerf
Introduction: How to Custom Paint a Nerf Maverick
Hello my name is FXAscensionz and I thought i would show how I custom painted my nerf guns.
Lets start of with something smaller, The Nerf Maverick. I chose a battle- damaged black and silver but feel free to use any colour that suits you. Lets Get Started!
Step 1: Gathering Equipment
You Will Need:
A Nerf Maverick (obviously)
A Phillips Head Screwdriver
Sandpaper (optional)
A Can of Plastic Primer
A Can of Black Paint
A Can of Silver Paint
Time
And Patience
Step 2: Disassembling the Gun
REMEMBER TO REMOVE ALL DARTS AND MAKE SURE GUN IS NOT COCKED BACK BEFORE OPENING
First use your Phillips Head Screwdriver to remove the 3 screws located in the cocking mechanism (it will split into 2 pieces with a spring loaded orange piece used in the tactical rail)
Next Carefully remove the first side of the gun. Remember to do this gently or the plastic will crack, this will leave you with the internal pieces exposed.
Gently lift out the 6 dart chamber and the barrel piece. set these aside for painting.
Remove the inverted plunger and spring (the orange tube at the top with a spring on it) then remove the catch (the hollow square that held the inverted plunger)
Finally remove the internal screws and set aside, then remove the spring at the top, the trigger and the rotating mechanism near the chamber. Underneath this is the chamber release button and a spring, remove those as well. KEEP EVERY SCREW AND SPRING IN A SAFE PLACE AND DO NOT LOOSE THEM
Step 3: Preparing and Painting
It is optional to prep the parts that you want to paint with sandpaper, but i decided not to because i was using plastic primer as a substitute.
Paint an thin even coat of plastic primer on the pieces that you want to paint waiting 20-25 minutes between each coat ( i used 2 coats per piece)
Then repeat but with the colour of your choice (i painted the paint body of the gun with 2 coats of black,the chamber and cocking mechanism i painted with 2 coats of silver paint)
 LEAVE ALL PIECES TO COMPLETELY DRY
Step 4: Adding Detail
I decided to give my gun a war torn feel and dry brushed some silver battle damage into the black casing of the gun. I also dry brushed the lettering "MAVERICK REV 6" to give the gun some character.
Dry brushing is made by painting a colour like silver onto your paintbrush and the painting onto a cloth or towel to remove colour, then brushing the surface
Step 5: Reassembling the Gun
The procedure of reassembling the gun is the exact reverse of disassemling it.
Replace the chamber release button and place the spring back ontop of it
 Screw back in the big rotating mechanism followed by the trigger (The trigger spring connects onto the nearest peg within the shell and the other end will latch onto a hook on the trigger. This was a problem for me but eventually i figured it out)
Replace the spring at the top, place the catch back into place  (be mindful of the spring) then insert the plunger with spring connected back into the catch
Add the chamber and barrel back into place
Find the half of the cocking mechanism that has a metal pin on it and place it so that it is through the internal spring at the top but remains outside the shell.
Screw the top half of the body back together and match up the two halves of the cocking mechanism, replace the spring loaded tactical rail attachment. screw together
Step 6: Finish
Thank you for spending your time reading my first ever instructable!
Let me know what you think of it by leaving a comment down below Positive or constructive feedback would be nice!
feel free to ask any questions
NEXT TIME: NERF RAIDER CS 35
    • Space Challenge
      Space Challenge
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    16 Comments
    Hey guys im really lost, i finished spray painting but when i tried shooting bullets it didnt work and now i cant open the gun up even when it has no screws supporting it
    Hi can i paint my nerf with acrylic paint??
    This was really helpful! Thanks for the straightforward guide :)
    No problem I'm glad you enjoyed it :D
    I like this, will be trying it later. Like you I am in the UK, technically it is illegal to make anything that could be mistaken for a real gun (I'm a lawyer and just got a colleague of mine to check), but I wouldn't be too concerned as you don't take it outside.
    Anyway, I am thinking of a similar colour scheme to yours but perhaps with some drybrushing on the silver to make it look dirtier.
    nice i painted mine in the same colour scheme but with a few bits of green in the indented lines around the release button and where the slide is
    yes, of course. im going to go rob a bank with this. i will get "did you get that of hellboy or something?"
    The rules are different in the UK
    thanks now my maverick, which i modded to shoot 3 times as far now looks awsome, except i couldnt put it back together, have to try again. thanx though
    no problem im glad you enojyed the instructable
    black and gold looks awsome if ya wanna try it
    just a little note, add some orange, you do not want to go outside with it and get shot because someone thinks its real
    Hi thanks for the advice but I live in te UK and I don't take the gun anywhere outside my property
    Good job, I really like the worn look you gave it.
    Instead of using Plastic Primer, you can also use spray paint made for plastic (Krylon and Rustoleum both have them, though there are very few colors to choose from). Also I was told that it is better to add a layer of clear coat/varnish to seal your paint job (especially if you want to use acrylic paint for detailing).
    Thank you for the advice I really appreciate the feedback!
