How to Custom Paint Your Xbox Contoller
4,323
72
5
Posted in PlayXbox
Introduction: How to Custom Paint Your Xbox Contoller
Are you bored of your plain controller? Then why not give it a custom paint job with this simple tutorial that will make your controller unique and give it some new life.
Step 1: Step 1: Supplies
First things first is the supplies.
Here's a list of supplies i used plus some optional ones for a better finish or design:
Spray paint
Controller
Controller shell
T8 Torx screwdriver
Pen
Scissors
Tape
Printer(optional)
Protective mask(optional)
Step 2: Step 2: Prepearing the Controller
The first thing to do is to remove the 7 screws from the back of the controller there are 3 on each side and one under a sticker on the inside of the battery pack.
The next thing to do is to remove the shell and the circuit bored.
The last thing to do is to remove all of the components ready for spray painting.
Step 3: Step 3: Spraying the Contoller
Now for the fun part, spray painting! If you have a shell then you spray paint the color of the designs you wont FIRST! Wait for the coat to dry then add more coats until its a good color.
Secondly to reassemble the controller, to put the designs on you wont with the tape. If you printed you designs, trace around the designs onto the tape and cut them out and stick them on.
Once that is done you will wont to spray the other color on, lightly at first so you get a good finish.
Step 4: Step 4: Reassembleing and Playing!
Lastly is to reassemble the controller by putting all of the components back in and screwing the screws back in.
Then test the controller and then play with your new custom painted controller!
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    5 Comments
    I used Krylon Fusion to paint a couple of our camouflage patterns and they came out great. The only problem I have had was paint adherence where you grip the controller. Not sure if I should have used xylene to clean them after washing/degreasing (put it all in the dishwasher) and rinsing, or sealing with a clear spray. I have done three rifles with plastic/composite stocks since then and used a vehicle acrylic spray sealer on them with much better results.
    Should read "..a couple of our controllers.."
    Easy and simple, great instructable!
