loading
I did this at TechShop Menlo Park. http://www.techshop.com
A large chunk of microcrystalline wax is not easily cut or broken. We had to get creative with the solution.
Step 1: Tried Using a Saw
And it gummed up the blade right away.
Step 2: Introduce Electrical Heat
We figured we would use a car battery charger to introduce heat to the blade.
Step 3: Charged Saw
It worked for a second but didn't get too far. Maybe because the blade surface being too big to send an even charge.
Step 4: Wire Cutter
Using conductive copper wire and two sticks of wood we created a cutter. It didn't work by itself but charging it helped.
Step 5: Cut
Electricity provided heat for the wire which cut through the wax nicely and easily!
Step 6: Chunks of Wax
The smaller chunks of wax are much easier to work with. I am using them for lost wax casting.
Enjoy!
<p>While copper wire will heat up, steel wire will work better. I use stainless mig wire (Handy for lots of things) for that. To control the heat from a battery charger, make a plug in with a light dimmer switch on the AC side of the charger (where the plug is). You can control the heat nicely that way. Same thing can be used to cut styrofoam.</p>
Yow! that looks like a real PITA. <br> When I was using that stuff I just put it in the freezer overnight and then put it in a trashbag and whack it with a small sledge hammer. It shatters quite nicely. Also I would use a soldering iron to &quot;score&quot; it to break off parts. BTW soldering irons also work well for welding wax parts together. <br> <br>Oh, and I just remembered that I would melt the shattered chunks in a pot and pour it into shallow baking trays to make easy to manage 1/4&quot; slabs.
He he.. yeah pita! Thanks a lot for your suggestions. They all work quite well, freezing worked great, soldering iron was good for sprues and shallow trays work well too. I was working in a huge rush so I needed to melt some chunks stat. This is why I came up with this unorthodox but weirdly fun method.
Sorry, I didn't realize that it was instructables itself that had changed the picture viewing format. My bad.
How did you get the pictures they way they are?
We used to score &amp; snap. I'm not sure if you'd call it easy, but it worked.
Scoring and snapping didn't work for this particular slab until it got frozen. It does for beeswax and hard paraffin and cutting is easy with red french wax. :)
The problem here would be that the blade is too big and conducts too well, so the amount of electrical resistance it is offering is low, and resistance is required to convert electrical power into heat energy. The thin wire you used later is small, has a much higher resistance, and gets quite hot as a result. Clever idea with the hot wire cutter. <br> <br>Do you use this wax for lost wax casting because it is easy to carve without it melting or warping when being worked, or for some other particular reason? Seems like a difficult substance to work with.
I use this wax to pour it hot into a silicone mold. Dispite it being hard to cut, it has a low melting point and doesn't hurt the mold so I can make many wax replicas of chicken feet and heads. :0 The soft paraffin is too soft for this but beeswax worked just as well and is easier to cut but its more expensive.
About This Instructable
7,800views
13favorites
License:
More by Miss Cabbit:How to clean out a rusty gas tank and replace oil on a moped Making a sink cover for a house boat Making a collapsible dog ramp for a houseboat
Add instructable to:
