How to cut pipe threads without a pipe vise
 by enfieldbullet
Featured
First! i hope many to come.
well, the title says it all, i needed to cut some pipe threads for my new bed (yet another pipe bed) and i didn't wan't to invest money in a new vise with a pipe holding jaw, mainly because i alredy have a pretty heavy vise which suits most of my needs.
so, i proceded to find a way. tried pieces of cloth on the vise to have a better grip, then tried adding shellac to the cloth to make it 'stickier', then i made rubber jaws for my vise. none worked. finally i devised a simple method with tools most people alredy have lying around, and if they don't they really should make/buy (i often make even though it costs more, because it's fun!)
you'll need a heavy vise ideally, you could do around that using a fulcrum of some sort but if the pipe keeps sliping that will bother you to death, cutting threads is alredy hard enough.
the second tool is a pipe wrench. yes! a pipe wrench! turns out an instrument used to apply huge ammounts of torque is also the ideal instrument to resist applied torque. and really, the hard part of cutting pipe threads is the torque which causes the pipe to slip in the vise.
third tool is the threading die. this one is pretty straightforward, you need a die to cut the threads unless you want to file them (not since maudslay we don't!). you need to buy/make/rent a die and a threading kit (the turning thingy). mine is 1/2".
fourth tool is cutting oil. i use lard. that may sound retrograde but it actually has great adhering and lubricating properties. in fact, some machining oils still use lard in the mix even today. i advocate it's use because
1º it's enviromentaly friendly, lard is a byproduct and it is completely biodegradable and relatively non-toxic, unlike many cutting oils
2º it's cheap. the small cup you'll see me using in this instructable was made by myself and it cost me almost nothing
3º acessible to the hobbyist and still provides great, just as good, results as anything else.
well, let's get to it!
Step 1: Setting things up
First you'll need to measure, mark, and cut the pipe to lengh.
measure twice, cut once. (that saved me today while i was cutting these)
be sure you are cutting square, you don't have to be absolute about it but some care makes the threads come out better and makes work easier.
i like to lubricate the blade of the hacksaw (guess i didn't mention this tool, duh) it makes it MUCH easier to cut, the lard beatifully adheres and doesn't drip (try finding a cutting oil which will do that). also , the lard won't stay solid as people may think, it sort of liquefies on contact with metal (my guess is that the metal's ability to transfer heat fast is the responsible, but i digress)
after you cut, take down the edges with a file and make up for any imperfections in the cut.
i know most of you all know this, but bear with me, someone might not know that so i'm including every step except the stuff you can figure by yourself(not going to take all of the fun out).
lube it up and it is ready to tap!
Ricardo Furioso says: Dec 10, 2012. 7:54 PM
Great Instructable.
One question.
Is lard the same as bacon grease?
My wife throws that out a lot.
Thanks.
rich
enfieldbullet (author) in reply to Ricardo FuriosoDec 11, 2012. 4:58 AM
lard is rendered pork fat. that can be done by wet or dry rendering, in dry rendering you heat the fat in heat without water, the resulting 'oil' is extracted. similar to what happens when you cook bacon.
so they're similar. but bacon is salted and smoked, so there will be some corrosive salts in the result as Iperkins said.
i'm thinking about putting up a ible on rendering lard. what do you guys think?
lperkins in reply to Ricardo FuriosoDec 10, 2012. 9:08 PM
More or less. Bacon has a lot of extra salt though, so be sure to clean if off your tools when you're done though.
lperkins says: Dec 10, 2012. 9:24 PM
A good vise will have removable teeth in the jaws. You can use this to make all kinds of useful things for bending metal and holding oddly-shaped objects. If you ever find yourself bending enough pipe to be worth it, a set of pipe jaws is a relatively easy thing to make.
SwitchGear says: Dec 7, 2012. 11:23 AM
any hardware store can do this for you.
enfieldbullet (author) in reply to SwitchGearDec 7, 2012. 11:49 AM
yes, i heard that. but they don't do that where i live.
skylane in reply to enfieldbulletDec 10, 2012. 12:44 PM
"Can" and "will" are two different things.
Many will thread when you buy the pipe.. not all.
mnwingnut says: Dec 10, 2012. 5:35 AM
You may know this, but not everyone does so I'll revel in redundancy.
Using a tap or die set to cut threads (taps cut threads on the inside, a die puts threads on the outside), it works well to go forward a half turn at a time, followed by a quarter turn backwards.
This helps by allowing the bits of cut metal to be drawn back into the recesses of the cutting tool and ease the binding that occurs. It also reduces heat a bit, which keeps the pipe from expanding and causing even more binding, and makes for more precisely-fitting threads.
Nice Instructable! I love the lard tip, that's awesome!
onemoroni1 says: Dec 9, 2012. 2:12 PM
More than one way to skin a cat, tap a thread. I worked as an elevator mechanic and had to improvise many methods to get the job done. Nice illustration of being creative and practical.
mr_bandit says: Dec 9, 2012. 1:23 PM
Not bad - but try using two pipe wrenches, one for each direction.
In general, one should cut about one turn, then back off a bit to break the cut bit off, then cut another turn. Use this time to put a bit more cutting oil on the threads - too much is much better than not enough (practice will tell you when you have enough but not too much).
You want to use about the same amount of force on each cutting turn. If it gets really hard to turn, you need to back off, apply oil, and start the next turn.
Any reasonably good oil will work - ie 30 weight engine oil. The oil lubes the cutting edge and keeps things cool. Higher speed (ie drilling into steel) needs oil. Cutting oil is specifically made for the high-speed cutting.
The poster uses lard - it will do in a pinch, although motor oil would be easier.
So - in general, a good idea. You can use two wrenches to create a "tripod" with the pipe, then lash/clamp the whole thing solid to a workbench.
dll932 says: Dec 9, 2012. 12:06 PM
Lard oil is what machinists used to use-nothing wrong with it. In fact, I'd be real suprised if that wasn't what's in Tap Magic (tm).
kleinjahr says: Dec 9, 2012. 10:25 AM
Been there done that, all workable solutions though vise grip is probably best as it doesn't let go when you back off the die.
For cutting the pipe you can drill a pipe sized hole through a piece of wood, 4by probably best. Then rip down in line with that hole. Next drill a smaller hole below the first at 90 degrees and rip down to that. Slip the pipe through its hole and clamp across so it holds it tight, saw goes down the other rip which keeps it at 90 degrees. If you line the pipe hole with sand paper it will give a better grip and so use it as a pipe vise.
Good practice is to deburr the inside of the pipe after threading, a file tang works well enough as a reamer.
enfieldbullet (author) in reply to kleinjahrDec 9, 2012. 11:39 AM
thank you for the advice, it is indeed a good idea.
i didn't deburr because this was 'structural' pipes, nothing will pass inside them. but i did have to deburr and knock down the edges on some of them so they would thread onto the fittings easier.
Wroger-Wroger says: Dec 9, 2012. 11:37 AM
A simple vice can be made from TWO sturdy blocks of wood, spaced apart by 3 to 6mm of plywood, then drill the hole to the size of the pipe.
You can drill and bolt the timber to the bench top (or whatever) and then remove the plywood spacer/s and bolt or clamp the two pieces together.
Although the true compressive grip of dry oil free wood on dry oil free wood, is not astromically high, the lenght of the grip area, and the amount of wooden vices that can be used, you can lock them lenght of pipe up pretty tight with the wooden vice.
Be sure to use a few LARGE THICK washers with small holes, under the bolt head and nut, if using bolts to clamp the wooden vice jaws together.
Ob1zenobi says: Dec 9, 2012. 11:10 AM
Hi, good instructable! For the critics, there is such a valid thing as emergency & improvised methods: McGyverize. For many years have used this method out in the field when pipe vise not available etc. Just a note: when using any kind of tap/ die whether pipe or machine thread, it will be gentler on the life of the tool & easier to cut if you periodically back the tool off by 1/4 turn. I go forward maybe one turn or less then back 1/4 then repeat. Follow the increase in drag as a reference. This reduces the drag on the cutting teeth as you're allowing the cut filaments to break off instead of dragging all the cuttings around under the teeth.. You had mentioned a broken tooth, this may be what you were referring to ( instead of the pipe wrench popping loose in your face, lol. This method above will absolutely save your small 8/32 & smaller machine taps from breaking off in the work & they wont wear out as fast!
enfieldbullet (author) in reply to Ob1zenobiDec 9, 2012. 11:36 AM
actually my tooth indeed. not during this though, it was when i was unthreading a piece of pipe from a joint later and it hit my face. my profile pic shows it. i'm not negligent, but you know, accidents happen.
i certainly am right with you on backing out the tap/die so you can clear the chips but i didn't feel the need on this one, they were just curling out perfectly.
orator says: Dec 9, 2012. 10:30 AM
Not that it matters in this use, but are those threads actually 'conduit' threads instead of 'pipe' threads. May be just my eyesight.
enfieldbullet (author) in reply to oratorDec 9, 2012. 11:30 AM
these are 1/2" USB tapered pipe threads.
hofy says: Dec 9, 2012. 10:07 AM
Wow, you need to think safety first. The very first photo you high light your feet and post "flip flops! no heavy machinery here so i can do that." . Then right next to that you high light the shavings and post "expect a lot of chips. a lot. these are like small razors and will cut your skin if you step on them. sweep as you go.
enfieldbullet (author) in reply to hofyDec 9, 2012. 11:29 AM
they won't cut through flip flops, they'll cut you barefoot though. and i wass sweeping the chips out of the way.
what i meant to say is that there aren't really any great dangers such as things falling and crushing my feet or splatter( as in welding). but you're right to point out safety is always welcome.
orator says: Dec 9, 2012. 10:31 AM
Forgot to say great idea!
charlycuervo says: Dec 9, 2012. 9:51 AM
Next time, cut two "V" block of wood for the vise jaws, instead of using fabric. That will allow you to hold the pipe in a stronger way, adding forces to the wrench.
By the way, nice work.
enfieldbullet (author) in reply to charlycuervoDec 9, 2012. 10:04 AM
i tried with rubber ones but that didn't work (hard industrial rubber, not the soft kind). i don't know if you can see but my vise will actually unscrew the jaws so you can substitute them.
i'll eventually make wooden jaws as well as soft metal ones(alu).
farmboy79 says: Dec 9, 2012. 9:10 AM
Pork chops for dinner honey, I need some lard for cutting threads! Seriously, as the author states lard is a good cutting lubricant. It has been used as a metal cutting lubricant for centuries and is probably as good and cheap as anything out there for the home hobbyist who doesn't need a gallon of cutting oil. It is obviously biodegradable as well so store it in the fridge or freezer long term or compost it when finished to avoid that rancid smell. Just have fried pork chops and save the grease but don't salt the chops until after you drain off the melted grease (lard). Lard in the grocery store has salt in it to prevent it becoming rancid and because it tastes good. Salt causes metal corrosion if left on metal and it is best it not be present in your cutting oil for sake of your cutting tools and the metal being cut.
audreyobscura says: Dec 6, 2012. 5:07 PM
Awesome! What did you need to thread a pipe for?
enfieldbullet (author) in reply to audreyobscuraDec 6, 2012. 6:01 PM
thank you! i am making a nomad pipe bed.
so far i had 3 failures mid-project and managed to loose a tooth. does this mean i can apply for the redneck challenge? lol.
but it is coming along!
thinkdunson in reply to enfieldbulletDec 9, 2012. 8:37 AM
there's a redneck challenge???
CHALLENGE ACCEPTED
jorricks says: Dec 9, 2012. 7:30 AM
Good Job well explained.
robots42 says: Dec 9, 2012. 7:25 AM
Glad someone else uses Lard. I bought a block from the grocery store, years later it still hasn't gone rancid or stink. If you back off the die - turn it back 1/2 a turn - when it gets tight you can avoid stripped threads.
lknowles says: Dec 9, 2012. 6:57 AM
Great idea! We sometimes don't think of things like this. A small chain tong would work well too.
pfred2 says: Dec 7, 2012. 7:15 PM
I did a project not too long ago where I had to thread 3/8" pipe but not mar it. It was pretty tricky. I did it by cutting open some copper tubing and putting the pipe I was tapping into it. Then I clamped that whole arrangement in a vise. It still slipped a little on me so I had to tap the pipe very slowly.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
