This is a mini-instructable as it will be useful for some other instructables that I will post which require square holes in ABS! I thought I would post how I do it - as it took me a VERY long time to find a satisfactory solution. I am still experimenting with this method but so far it seems to be the fastest way to cut into plastic for making square holes. I have found so far that the smaller the hole the narrow your blade needs to be to avoid plastic bubbling over the line - with larger holes it is not so much of an issue. ( Thanks to Iliah Borg for pointing me in this direction )
Remove these ads by
Signing UpStep 1Tools Needed
The other item you will need is some kind of grinding kit. I recommend the Rotary Craft mini rotary tool. This contains a selection of grinding tools. I bought a grinding/cutting addon for mine. This is actually what I attempted to use to cut the square holes to start with but it didnt work out - very hard to control the circular blades and pretty useless for small holes. Do a search on ebay for them.
The grinder I use is shown below. You can see two tips. The one attached to the rotary tool I used to polish up the metal after grinding. The pink tool is what I used for grinding - worked very well.
I'm in the market for a rework machine so this may be interesting to try.
Also
It would be nice if there were some pictures of the actual box being cut.
