3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to design and build a combat robot
Step 7Assembly of components
As you are in the process of building your components test fit your parts together. Don't be surprised if you have to modify some of them as they won't always fit. Depending on how they were manufactured your parts will fit together differently.
Ones made in a machine shop or with a CNC will most likely go together as designed, the more manual the manufacturing the more modification you will need to do. Just make sure to use the montra of "measure twice cut once" as it is very hard to make material grow once you cut it away.
The main advice in this process is don't get discouraged if you take your time things will go together just fine.
Notes:
if you are using threaded fasteners make sure to use high quality ones. The fasteners at the big box stores (home depot and lowes) are of low quality. I recommend ordering from McMaster Carr www.mcmaster.com or another industrial distributor.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:gneedel
I used to say that I could be described by a quote from the Grateful Dead - "Sometimes we live no particular way but our own". However, more recently I realized that isn't completely true anymore. It ...
more »
