How to dice an onion by dizzydave
U:\Dave\My Docs\My Pictures\2007_06_10\IMG_1023.jpg
This is the simplest and quickest way to dice an onion. If you don't want to cry--just breathe through your mouth the entire time. If you don't breathe through your nose you should be fine.
**Disclaimer 1: This project involves sharp knives. If your knife is dull, you have a tendency to chop off your appendages, or you are small child, you should not attempt this project.**
**Disclaimer 2: If you don't follow the breathing instructions, and this makes you cry, make sure you wash your hands before rubbing your eyes...then find a shoulder to cry on...**
Step 1: Slice off the top
U:\Dave\My Docs\My Pictures\2007_06_10\IMG_1026.jpg
Slice off the top of the onion--do not cut off the root end!
u2beal999 says: Nov 27, 2007. 8:51 PM
Yes, in culinary school and in commercial kitchens, you always start by cutting the onion in half through the root, peel, then cut the majority of the root "hairs" while leaving the root intact. This makes for a cleaner work area. Also, by cutting the onion in half, the cut side can lay flat on the board. This allows you to put pressure, with a flat palm, on the top of the onion while making the initial horizontal slices. This way even if the knife slips you aren't in danger of cutting yourself because the blade is lower than your hand and facing away from the body.
gglockner says: Oct 23, 2007. 10:34 AM
Noooo! The onion is round, and you are making cuts towards your hand. This technique landed me in the hospital for five stitches. There IS a better way -- quarter the onion first, then you can keep the onion on flat sides for all the cuts. Much safer, and really no more work. I'll try to upload my own instructions when I get a chance. Thx.
dizzydave (author) says: Oct 24, 2007. 5:29 AM
your quartering method sounds safer...i'll give it a shot next time...
Sir Chopsalot says: Sep 16, 2007. 7:43 PM
Great instructions, and the comments are helpful too! I tend to do this near running water, and put the onion under the faucet from time to time when the fumes get too bad and I can't see.
I'm still getting used to the posting here, so forgive me if this isn't the place. I'll try to do an instructable on this at some stage. I wrote a short guide on choosing the right kind of knife. As the author points out, it's important to have a good sharp one.
Choosing A Cooking Knife
Cheers!
dizzydave (author) says: Oct 24, 2007. 5:28 AM
if you breathe through your mouth the entire time you're usually ok--but if you get that one whiff through your nose you're toast.
RebelWithoutASauce says: Aug 1, 2007. 10:39 AM
I cut it in half before I even take the skin off. I find it is easier to remove the skin and as previously mentioned the cut side prevents the onion from rolling about while cutting.
dizzydave (author) says: Aug 1, 2007. 12:57 PM
I have taken to doing this as well...if I wasn't lazy I'd redo the instructable...
lemonie says: Jun 12, 2007. 6:11 PM
Not quite the classical technique, but modified as jtobako suggests by cutting in half exactly what I use.
You cannot appreciate how worthwhile this method is unless you've seen (or tried) mangling an onion in other ways (I have seen such, it amused me)
L
jtobako says: Jun 12, 2007. 10:03 AM
Cut the onion in half and do half at a time. That way, the onion won't roll your fingers into the knife blade : ) If you are horrified by slicing into the root, cut it off center or just a slice off one side for a sturdy base. After cutting the onion, rub your hands with something stainless steel under running water-it will get rid of the onion smell.
dizzydave (author) says: Jun 12, 2007. 10:28 AM
hmm...that's a great idea! i've known lot's of people who do this trick, but no one ever cuts it in half...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
