loading
Picture of How to do a Manicure or Pedicure that will last!
Tired of dropping $40.00 on a manicure or or pedicure? It's not hard and if you don't need a fancy paint job, here's a solution for you.
Step 1: Tools and materials
Picture of Tools and materials
Begin with a nail file and a series of multi-stage buffers. For the final shine, I've found nothing better than the "Flash Shiner" available on Amazon or eBay for about $2.00.
bhvm1 year ago
finally a great guide for men. I love it!
Kaiven4 years ago
What do I do about all the torn skin kinda screwing up my cuticles?
wnailart Kaiven2 years ago
Start with a professional manicure, then once the dead and dry skin has been cleaned up use a serious moisturizer. This can be complicated by work or hobbies that really dry out the skin. Some people do just grow more cuticle but keeping it from drying out and trimming (carefully, don't cut too close and use only sanitized tools) can keep it tidy. It is a good idea too, splits and tears increase the potential for infection.
wnailart2 years ago
It appears to be an advertisement for the buffer, the advice falls very short of anything like a professional manicure or pedicure, the writer is clearly not professionally trained.
wnailart2 years ago
It will last until you scratch it and, your nails will grow... I can't imagine it will last a month unless you do nothing to scuff it.... as I said, be careful to not remove too much nail when buffing. I don't recommend doing this often. The top layers of nail are more dense, the layers beneath become more porous... once you have buffed off the top layers, the layers beneath can split and peel in layers depending on the nail. You are not sanding paint on a car, you are removing nail surface. You cannot paint over it if you remove too much nail. This article suggests that a few simple steps replace a $40 professional manicure or pedicure... it does not touch on the clean up of cuticle and dry skin common on a pedicure. I suspect it was written by someone who has never had a professional service, or thinks you haven't.
wnailart2 years ago
"unchecked" nail ridges? Ridges in the nails show many things but they do not stop developing by buffing them and they do not harbor nail fungus... sorry but that is just silly... buffing too much off the surface of the nail can lead to peeling nails. Buff only lightly if you must and realize, each time you buff your nails you remove more of the denser nail off the top. This points out why it is worthy paying a professional.
wnailart2 years ago
Bad idea, the edge of the file is not designed to push cuticle without tear cuticle and scratching the nail... use a soft pusher designed for the job and soak the cuticle to soften it and make it more flexible so it will be less likely to tear.
wsheppard5 years ago
Always file in the one direction, Not back and forth, this will damage the nail.
Not true, that makes no sense at all, if filing both ways "damaged" the nail, filing one way would damage it too. What it is that tears nail fiber and makes it shredded at the edge is using a file that is too coarse. When filing natural nail use the softest grit file that will get results. You would be surprised how fine a file will still shape natural nail.
Marsh (author) 5 years ago
Voting is now open for the Beauty Contest, so If you really like it, please vote for my instructable.
Buffing is key. If you do a good job, you don't really need a lacquer, and I have one that's 4 stages and each one is thankfully labeled. Phew! Works great on toe nails too. :-P
gnomedriver5 years ago
After a lifetime of biting my fingernails, I've gone cold turkey and stopped. It has been nearly two months but I really want to rip into them and chew them. It’s driving me MAD!!!!! However, I can resist (but only just) As a kid I got a grooming set from my aunt and thought it a total waste of time. But this instructable has come at a great time. I have a use for that nail file. I can have tidy nails instead of little stumpy things. Thanks for the pointers.
Marsh (author)  gnomedriver5 years ago
That's exactly what I did! Cold Turkey! You can do it!
Thanks for the support. Perhaps I should join the N.B.A. Nail Biters Anonymous One great thing about longer nails; I can have a proper scratch.
Zansion5 years ago
Great instructable, just what I have been looking for!
ikeike405 years ago
hi
