How to Do a Proper Back Squat
43,484
13
16
Posted
Introduction: How to Do a Proper Back Squat
To perfect a back squat you must start with the least amount of weight as possible. If you stack on too much weight, you are likely to hurt yourself and then you really want to doing any working out.
In my Instructables I will only be showing you the "form" of a back squat therefore, I will not be using any weight. If you are struggling with your back squat technique or if you are trying a back squat for the first time I suggest you start off using no weight. If you have a broomstick or a plastic pole around the house that would be the perfect for practicing your back squat.
Once you have practiced and mastered the technique for a back squat, you can start to add weight. Bt, be sure to always wear a weight belt and to have a spotter behind you to prevent injuries.
To do a proper back squat you only need one thing:
- a wooden pole (a plastic pole, or a broomstick can work as well)
Step 1: Feet Position
Stand with your feet shoulder width apart.
- If you are right footed, place your right foot slightly in front of your left foot ( See Picture #2 for correct stance)
- If you are left footed, place your left foot slightly in front of your right foot. (See Picture #3 for correct stance)
- Do not stand with your feet pointing out, a.k.a "duck-footed."  (See Picture #3 for incorrect stance)
Step 2: Bar Placement
Place the broomstick on the top of your shoulder blades.
- To prevent injury, do not place the stick on the top of your spine. (See Picture #2 for incorrect form)
In this same step, place your hands next to your shoulders.
- Wrap your numbs around the stick, but do no put any pressure on your back. You do not want to be forcing the stick down onto your back.
Step 3: Ready Position
Slightly bend your knees.
This will simultaneously put your rear down. Before you lower down into your back squat your body should look exactly like this step
Step 4: Proper Squat
Keeping your back straight and your slightly up (your vocal point should be slightly high), lower your rear like you are going to sit in a chair. This step is the most important because you cannot let your upper body go past your knees.( See Picture #2 for incorrect form)
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
18 Comments
Drew91 is right. That's not correct form for a lowbar or a high bar squat. Made no mention of depth. The form alone will limit the weight people can handle but get too ambitious and you're guaranteed to jack your body. If your form sucks try front squats. You'll be less likely to hurt yourself.
Thanks for these tips. I have been doing this with weights. The first time I hurt the back of my neck (spine....) with a weighted bar. To avoid the problem, I wrapped a layer of foam around the bar.... but if you do not need a weighted bar at all, I can use a broomstick and just do more reps. If you are seriously out of shape, do 20 squats in the evening before a shower and bed, and I guarantee that you will have a good night's sleep :D
20 squats - 2 sets of 10 or 4 sets of 5 if you are just starting out. If you are a couch potato like me do NOT go over the top on the first sets. Less is more, otherwise, you will ache for a week !!! Go slow, go steady, note your progress. If you are doing this to lose weight, reality check: It took you years to get to your current size, there is no miracle exercise or diet to make you lose that in a week. None. Zero. Nada. Zilch. Note your exercises, your reps, your sets. Go slow, increase step by step.
my rowing coach taught me this method, he called the first picture "ducks arse" i havent a clue why. Needless to say it helped me greatly
There are two many bits of bad advice to give a good rating.
-Putting one foot infront of another is a pointless move that will cause a slight imbalance.
-Your knees are not supposed to go in. By not having your feet "Duck footed", you run a large risk of injuring yourself, and it also prevents you from getting proper depth.
- Your wrists should be straight, not bent when holding the bar on your back.
- The squat depth demonstrated here WILL cause knee injuries if practiced regularly. A proper squat is a little bit below parallel. Don't believe me? Watch an Olympic squatter.
Drew91 is correct! Your squat depth plus foot, hand, bar, and back positions are all wrong. If you follow this form with weight, you will injure yourself. Please read "Starting Strength" by Mark Rippetoe.
http://www.amazon.com/Starting-Strength-2nd-Mark-Rippetoe/dp/0976805421/ref=wl_it_dp_o?ie=UTF8&coliid=I1MPHEQII7AXHY&colid=2BT3S7OPNMAQ2
This'll help til ya buy the book,
http://startingstrength.com/articles/squat_rippetoe.pdf
I definitely agree with you drew.
Completely agree. I'm a certified personal fitness trainer and the instructions the original poster gave are not an example of good technique, but instead a recipe for disaster.
Drew91, your instructions, however, are perfect. Thanks for the correction.
Here is a demonstration of the perfect squat, by chad smith.
http://www.youtube.com/watch?v=YV4ABSzt8kw
