Introduction: How to Do Recursive-like Modeling in Tinkercad
Picture of How to Do Recursive-like Modeling in Tinkercad
I really love the look of recursive math-y things, but as of now I can't program (or math) nearly well enough. But I still want to make cool, fractally-weird stuff.
Duuuuude. Fractals.
Step 1: So You Think Recursive Models Are Neat But Can't Code Worth a Lick
I really love the look of recursive math-y things, but as of now I can't program (or math) nearly well enough. But I still want to make cool stuff! WHAT IS A GIRL TO DO
Enter Tinkercad! I love it. I use it all the time. You can make weird stuff that is recursion-esque by using some of it's functions.
Functions you'll need to know:
-CTRLD
I have no idea what Tinkercad calls this function, but when you hit CTRL-D the first time, it flashes yellow and starts 'recording' actions; which are then repeaded when you hit CTRL-D subsequent times. It does not work if you hit CTRL-Z during the 'recording'.
-ALT>move
Like illustrator, if you hold down ALT while you move a shape, you make a copy of it.
Step 2: Open TinkerCad, Choose Yo' Shapes
Picture of Open TinkerCad, Choose Yo' Shapes
You like shapes? Of course you do. Shapes are awesome. That other instructable- the one that I'm very, very gently ribbing- is all bubble-spherish. So I'm going to go with that as well.
First you have to make your 'base' shape. I chose three spheres in a triangle-bubble sort of arrangement.
Group this new base-shape. It'll make it a lot easier to move around.
Then- the magic- hit CTRL-D. You'll see the outline of your shape flash yellow; that indicates that you've just hit 'record'.
Now, make a copy of your foundation shape, and arrange it with the first one so that it intersects. Your aim is to make the first 'step' in a recursive pattern, which will then repeat. For example, if you move it up 1mm and reduce it's size by 10%, the next step will be up the same amount and reduced another 10%- 19% from the original. I've found moving it slightly up, changing the size a tiny bit, and adding a touch of rotation makes a nice effect. Think about the angles of a spiral staircase.
Step 3: HIT CTRL-D LIKE IT'S GOIN' OUTA STYLE
Picture of HIT CTRL-D LIKE IT'S GOIN' OUTA STYLE
Hit that. Over and over. See what happens!
In this case, it made a sort of tall..thing.
Now, group THAT, shape, and repeat the last step. Keep doing this until you have something you like- make a group, CTRL-D, move a bit, stamp stamp stamp. It helps if you make the subsequent groups smaller than the first- like branches off a tree.
Step 4: Go Nuts
Picture of Go Nuts
You can see here how far I went with this. This was maybe..5 iterations.
Play around, try doing recursion with different shapes, holes, anything.
Now go make you some strange.
audreyobscura (author)2014-09-22
This is great! I cant math well either, thanks for posting this!
wilgubeast (author)2014-09-12
Recursivish.
Recursabout.
Touché. :D
This is what an intro to CAD course should be: play, experiment, play some more, and gently rib an existing project. Very gently.
About This Instructable
3,127views
42favorites
License:
Bio: Artist in Residence at Instructables. I'm a hardware hacker, artist, illustrator, and cartoonist. I make things with whatever tools I can. I design and ... More »
More by Ladycartoonist:Gearing up in TinkerCadDownload, edit and print your own parts from McMaster-CarrGetting started with (laser) etched-line watercolor
Add instructable to:
