loading
Step 3: Attaching the Sewer Hose
 Remove the cap from the Drain pipe by twisting (most likely counter clockwise). and attach the sewer hose by twisting the channels around the protruding plastic pins on the pipe.
Slide the other end of the pipe into the sewage connection in the ground or into your portable tank (this connection does not lock in but rather slips).
Some may have the locking channels on both ends for different types of connections, some amount of analyzing may need to be done to make sure that you have the proper fittings for your particular situation.
Try to make sure that the hose drops elevation from your RV to your destination (becomes lower).
It is also a good Idea to support your hose so that it has good downhill flow. There are products sold for this but I have found that a board works just fine, and it was free.
Pull your sewage valve open and let it drain for a few minutes. I usually let mine go until I can't hear water flowing through it.
Close the valve. If you are connected to a sanitary sewer line (!!! NOT A STORM SEWER !!!) then proceed to the next step but  if you are using a tank like I am then I have added some extra steps at the end of this intractable for how I dump the portable tank.
<p>i love this camper </p>
It is probably the converter that charges your battery while plugged into power. Mine does not work so I have to use a charger to keep it powered up.
Please leave any improvement ideas, suggestions for deodorizers, or just general knowledge of the subject. I am not an expert and always appreciate learning a better way to achieve my goals.
<p>I have kind of a unrelated question, I recently got a Holiday Rambler travel trailer, close to 30 foot long and supposedly a 1993 aluma lite model, I'm not 100% sure though, I have a couple off topic questions for you, I plugged it in and there is a humming underneath the front (toward the tongue) about 4 or 5 feet back in the center underneath there was some kind of panel and that was where the noise was coming from, I got the noise to stop by turning off one of the breakers, but I would like to know if something is on that I can shut off, because until I find out I have no ceiling lights because that breaker is off.. the A/C is off and I think the heat is off since it uses gas. Since I really know nothing about the model other than it saying Holiday Rambler and Aluma lite on it, my question to you is, is there a place, a tag or something located in a common spot that has information on the trailer?</p>
<p>Need help regarding draining black tank on a Dutchmen Aspen Trail travel trailer. It is not moveable. The sewer tank to dispose it into is about 40 feet away. It is also slightly elevated. Does the draining only work with the help of gravity, or is there an way to force the contents out, in spite of a slight elevation?</p><p>THANK YOU!</p>
I've heard if you are traveling and want to clean your tanks, dump some ice down the toilet and drive... Cleans up the tank nicely
Some RVs have a pump called a mascerating (spelling?) pump that is sort of like a high powered blender so that there are no solids in the tank at all. It might be a good idea to have that special pump. I believe that some rigs also use that pump to force the waste to dump.
I know this is an old thread, but a mascerator fits on the drain of the tanks. It only &quot;blends&quot; the stuff as you drain the tank. It doesn't do anything to the stuff going into the tank.
this seems like a no brainer but i had a hell of a time draining my tank. definately gonna make myself a wand like yours, as well as use the laundry detergent, thanks!
About This Instructable
90,904views
60favorites
License:
More by A little of this and that:How to drain an RV's black and gray tanks.
Add instructable to:
