How to drill a clean hole through tile - porcelain, clay, glass, hard tile by bmerritt5
video How to drill a clean hole through tile - porcelain, clay, glass, hard tile
There will be times when you are tiling that you will need to cut a hole through the tile to allow for plumbing or electrical wires. This is a very effective method for drilling through any type of tile using a drill and a carbide tile bit.
mcarrell says: Jul 12, 2011. 6:58 AM
You can also just put a piece of masking tape where you want the hole? Mark the tape and drill through the tape.. It works for me every time! :) A bit faster than a putty mountain?
shuarose says: Feb 11, 2011. 1:27 PM
For an installed vertical tile, I used my kitchen injector full of water and slowly dribbled water onto the drill bit as I drilled (this takes a little coordination or some help).
Birch says: Feb 3, 2011. 9:54 PM
Just start your diamond bit on an angle, dry. Once you have a crescent moon cut in, that will guide your bit. Spray on water or use a wet sponge. Drill the hole at a slight angle to keep the bit from over heating. This will make your hole slightly larger than the bit, but this is not an EXACT science.
dchall8 says: Oct 15, 2008. 11:10 PM
Okay, this is why I hate video Instructables. It took you longer to set up your camera than it would have taken to write a real Instructable. And it takes longer to view it than it takes to write the Instructable. Since you didn't want to write it or take a few still shots, here is the narrative. Step 1: This is a technique for drilling holes in glass and ceramics. This technique only works on flat surfaces that can be held horizontal. Step 2: You need an electric or air drill, the ceramic drill bit of the right size, plumber's putty, and some oil. Step 3: Locate the hole in the tile. Step 4: Build a dam with the putty around the hole. Step 5: Put some oil inside the dam. Step 6: Drill the hole. Step 7: Remove the putty.
IamTheMomo says: Dec 12, 2010. 6:14 AM
Thanks, dchall8! I think your easy-peasy instructions are quite sufficient and the video was overly long, but for the rank amateur who has no experience with power tools, it will suffice quite nicely. For myself, I copied your instructions to Notepad and saved it under Home DIY Instructions. I'll probably just use my sewing machine oil rather that buying a whole bottle of something I'll never use again - because I don't HAVE air tools! If I ever have to drill vertically, I'll use bmerritt5s instructions on pump sprayers, and um, doesn't it seem logical that if I could use water vertically, I could also use it horizontally? It would dissipate heat faster than oil, I imagine, because it is obviously less viscous.
LOZMAC says: Dec 9, 2010. 4:59 PM
For goodness sake dchaII8, your being a little intolerant aren't you? As a newbie dumbie at instructabless, finding a video of how to do something is a lot more encouraging than reading it. Also the comments clarify things well. I found the whole page gave me the info I needed and along with the masking tape idea, i was successful in drilling through a a very scary 300mm by 300mm tile splashback.
patmac says: Oct 23, 2008. 9:30 AM
I, on the other hand, liked the video very much, and have tried for the longest time to drill through glass without success. I will try this method, it makes so much sense I don't know why I didn't think of it!
bricabracwizard says: Oct 26, 2010. 6:34 PM
Have you thought of using a diamond drill, they are circular like a hole cutter that you use for wood except the edges of the hole cutter for tiles and glass has a diamond sand paper edge which gives you a very clean hole of any size.
patmac says: Oct 27, 2010. 7:34 AM
Thanks for the suggestion, I will certainly try this method.
bmerritt5 (author) says: Oct 23, 2008. 11:18 AM
You do mean glass tile right? If you are talking about drilling through glass table tops or something like that, you can really only drill holes using this method through glass that is not tempered. If you try to drill through tempered glass - it will crack and splinter in a giant mess.
sixstringsandrhyme says: Jan 21, 2010. 6:58 AM
hey man...i've actually had success drilling holes in simple glass bottles by submerging them in water and using a stone dremel bit.   fyi.  :)
dbretts says: Mar 25, 2011. 1:40 AM
Were you making bongs or something mate? Just asking :)
Larry Rossdale says: Sep 22, 2010. 12:43 PM
Great advice. My wife and I recently renovated our kitchen and we went with kitchen backsplash tiles. Check out http://www.glasstilewarehouse.com/, their designs are awesome! We need to drill through one and this video should help us out.
roadieflip says: Jan 20, 2010. 1:00 PM
I  worked as an electrician for the first 10 years of my working life, and I have put in many showers in already decorated bathrooms.  I have used a simple masonry drill bit without the hammer setting to drill holes in glazed tiles, and in those ten years, I have not broken a single tile...
I just don't see the point of taking such a long time to do something that takes no longer than changing to a different drill bit.
sixstringsandrhyme says: Jan 21, 2010. 7:05 AM
yeah...it does seem over-careful, but you have to hand it to him:  this WOULD be probably the SAFEST way you could possibly get this job done.   i usually do it your way, though, with a piece of masking tape placed where i'm going to drill to help prevent chipping a bit....another method, when i'm REALLY feeling careful, is to use a stone dremel bit...
moo of the cow says: Aug 28, 2009. 12:28 AM
would this work with a glass bottle ????
sixstringsandrhyme says: Jan 21, 2010. 6:57 AM
hey man....i used to drill holes in glass bottles with a dremel's stone bit and i would submerge the bottle in water while i did it....worked like a charm every time....i'd suggest that route, if you have a dremel available.
and-reas says: Dec 4, 2009. 10:57 PM
great vid, want to do this with a bottle. Or should I then use the drill that's more like a circle which grinds the glass?
iamtoats says: Nov 7, 2008. 2:08 PM
Do you think this would on a mirror too?
hazellr says: Feb 20, 2009. 10:03 AM
YES our kits drill mirrors, as well as glass, aquariums, and of course granite, porcelain, travertine, marble, pottery, ceramics up to 30mm thick
chalky says: Oct 14, 2008. 3:18 PM
Great job! but what's the reason you can only use air-tool-oil?
bmerritt5 (author) says: Oct 16, 2008. 6:47 AM
I recommend the use of air-tool-oil because it is a clear, low friction oil. It will transfer heat well, and will not stain any tile or grout.
mylady_t says: Oct 22, 2008. 12:37 PM
Thank you so very much for posting this. You don't know how many clay tiles and pots I have cracked or chipped using different techniques. Soaking unglazed clay in cold water for quite some time helps, but I still get chips on the back side, even with the carbite drill bit. I am gooing to get some air tool oil, have plumbers putty, and give my new 12v lithium ion drill a work out. Thank you!
bmerritt5 (author) says: Oct 23, 2008. 11:15 AM
Glad I can help out! Happy drilling!
NE-Phil says: Oct 15, 2008. 5:01 AM
Nicely done but how about drilling holes in tile when it's on a vertical wall? Obviously the putty and oil would not work. I spent hours drilling four simple holes for a towel bar holder awhile back. Any suggestions there?
bmerritt5 (author) says: Oct 16, 2008. 6:59 AM
Thank you for your comment. This is a common problem. If you have to drill holes on a vertical wall that is already installed, I still recommend that you use a carbide tile bit or a diamond core drill bit, but that you spray water onto your bit while drilling to keep it cool. I have seen expensive systems in tile stores for pumping water onto the bit, but all they really are is a handheld pump sprayer that you can find in the garden center of Home Depot, Lowe's, K-Mart, or any hardware store. Just fill the pump sprayer up with water, prime it, and run a clear tube up to the drill bit - and spray while drilling. If you can, get someone to spray while you drill - it makes it easier to manage. Here is a link to some pump sprayers at Home Depot that work great - I bought the cheap one : http://www.homedepot.com/webapp/wcs/stores/servlet/Navigation?Ntk=AllProps&N=10000003+90401+527083&storeId=10051&catalogId=10053&langId=-1um=1&hl=en&q=handheld+pump+sprayer
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
