How to drill a hole into your thumb via being careless!! by JuxtaposedIToldYouSo
This Instructable will explain how being careless while working can cause you much more pain than the task was worth. *****VERY IMPORTANT NOTE: THIS INSTRUCTABLE IS A REMINDER AND NEVER TO BE REENACTED BY ANYONE!!!*********
Step 1: Step One:
In order to properly be careless while working it is recommended that you start working while very tired. To be as efficiently careless as you can be it is recommended that you both tire out your mind and your body. Sleep deprivation is usually the best way to achieve this state in both mind and body.
abstracted says: Mar 9, 2012. 5:37 AM
almost losing the index finger at the 1st joint with a fully extended olfa knife, i have no surface feeling. if that finger feels HEAT...its too late...blisters form lol
Turdcurd says: Oct 24, 2011. 3:56 AM
If above the appropriate age, drinking some alcohol or partaking in recreational drug use before step 4 may help with the pain in step 6, however, it may blur the line between step 4 and step 5 sufficient enough that come step 7, all memory of this instructable may be lost and may have to be repeated..
JuxtaposedIToldYouSo (author) says: Oct 28, 2011. 10:37 AM
This is certainly another way to go about finger divot rendering.
Irock148 says: Apr 14, 2011. 1:07 PM
exactly what were you doing?????????????????
JuxtaposedIToldYouSo (author) says: Apr 15, 2011. 1:01 PM
I was trying to hastily make a little mount for a flashlight because my dashboard lights had burned out. All in all it was a bad move.
hifatpeople says: Jan 18, 2011. 7:23 PM
someone at school drilled through his hand
didgitalpunk says: Jan 8, 2011. 10:18 AM
oh wait it was more than that
it was on 6th of march 2010
didgitalpunk says: Jan 8, 2011. 10:15 AM
about 7 month ago i cut the end of 2 of my fingers with a bike's disc brake . i only bled for about 2 hours non-stop ... and i only spent 12 hours in the hospital!
i live in france so the social security system took all the fees but i guess it must have cost a lot...
samchamb says: Aug 6, 2009. 1:26 PM
As a child I once slipped with the soldering iron and plunged the hot tip into my finger . hot knife, butter e.t.c...
beehard44 says: Nov 13, 2010. 10:45 AM
owww, and i thought a blister on my leg from a soldering iron was bad enough...
JuxtaposedIToldYouSo (author) says: Aug 7, 2009. 8:34 AM
Ouch, that had to have been an interesting feeling!
JuxtaposedIToldYouSo (author) says: May 27, 2009. 7:41 AM
Unit Two
"numbers 1 to 5 please circle the conjunction"
(Worth up to 3 points each)
killerjackalope says: May 26, 2009. 8:59 AM
If this had some nicer pictures I'd probably have featured it... I'm pretty amused, sorry to hear about the minor issue of a hole in your thumb...
JakeTobak says: May 26, 2009. 10:50 AM
Not that I really WANT to see clearer pictures, but check your camera for a macro mode.
killerjackalope says: May 27, 2009. 3:12 AM
I'm not the author - Probably should have mentioned macro though...
JakeTobak says: May 27, 2009. 5:22 AM
Yah, I was gonna make it a seperate post but you already touched on the subject so I put it as a reply to yours and forgot to change the pronouns :P
killerjackalope says: May 27, 2009. 6:29 AM
Oh no not the pronouns!
lemonie says: May 26, 2009. 12:21 PM
Yes! (it's a while since I heard "macro", mine makes no damm difference...) L
ycc2106 says: May 26, 2009. 4:30 PM
@JakeTobak Try taking a clear picture with one hand and holes in your fingers... =P
ibayibay1 says: May 26, 2009. 2:24 PM
this is more of a comedy thing than a instructable gave me a few laughs shud be featured
thepelton says: May 26, 2009. 10:48 AM
Everyone needs to remember that if it can cut hardwood, it can cut flesh and bone. Never get distracted when using a power tool, or allow something to distract you. Keep dogs, cats, and children too young to learn tool respect out of the workshop.
JuxtaposedIToldYouSo (author) says: May 26, 2009. 10:35 AM
Its been a few weeks now since the injury and i have yet to regain the sense of touch on most of the tip of my thumb. At the hospital my medial nerve was numbed completely before a piece of tissue was removed; when it was snipped away it was an unforgettable surge of pain through my body. Ah the lessons we learn!
scarabeetle101 says: May 26, 2009. 9:44 AM
Okay, maybe a fireball in the face and an accidental tattoo aren't the worst things I could do to myself... (oh yeah, don't forget the slingshot dart through the end of my thumb)
Phil B says: May 26, 2009. 9:24 AM
A number of years ago I put a 1/8 inch bit through my thumbnail and out the fleshy side of my thumb. I was using a dull bit and pushing too hard on it. The bit broke and went for my thumb, which was holding down a piece of sheet metal close to the intended hole.
jeff-o says: May 26, 2009. 9:00 AM
Ouch. Any word on whether you did permanent damage to nerves and blood vessels in your thumb?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
