3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to create plaster copy of an action figure
Hi all,
I've been planing to do a scale model of a human figure, or some scifi/fantasy character for some time. But as it goes my modelling skills just weren't up to the task. That's why I decided to duplicate existing one and then build and model on it. On the firs model You can see the figure i used.
Step 1Dismantle the figure
The next step was to dismantle the figure using the screwdriver. If You are using some of the good old GI Joe figures You wont have problems with it. Just remove all the screws on the joints and that's it.
8 comments
Nov 2, 2011. 10:58 AMskittlespider says:
Nice idea with the liquid latex!
I tried making a copy of an action figure before, and it is tough. This idea seems to work a lot better than my attempt did. I made a plaster mold and tried to fill it with liquid plastic.
I'll have to remember to try using liquid latex for future mold making projects.
Dec 27, 2011. 5:52 PMheathbar64 says:
the trick with molding stuff is this: if you are going to cast with something hard, you need to use a flexible mold. if you are casting something flexible, use a hard mold.
Nov 3, 2011. 10:01 AMskittlespider says:
I have links in the supplies section on the first step of my Instructables.
This is the stuff I use for mold making:
http://www.smooth-on.com/Urethane-Plastic-a/c5_1120_1209/index.html
http://www.smooth-on.com/Silicone-Rubber-an/c2_1113_1136/index.html
It can be a little expensive, but it is some high quality stuff.
Nov 3, 2011. 11:09 AMskittlespider says:
Yeah, you have to be careful with the thin parts. Especially when dealing with plaster.
Maybe you could use your molding technique with wax instead. It is flexible and easy to cast, so it might work better for your hands.
(Of course wax does not work well with other materials, and you can't paint it. So it may not work for the parts that you will be customising.)
Your welcome for the info. I would suggest using a trial size at first. If you decide that you will be making a lot of these type of projects, the bigger sized containers will save you some money.
Oct 27, 2011. 12:34 PMmikeasaurus says:
you should link to your next Instructable on how to "add new features with modelling clay and then repaint it" in the bottom of this Instructable when you're finished.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mrky007
