3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to etch aluminum panel labels/designs with a reusable acid mix
Step 2Print on pnp blue
Print on pnp blue
1.- Create your design in any vector app: Illustrator, Corel Draw, Ink Scape, etc.
2.- Flip the design before printing as you would with pcb etching.
3.- Print the design on regular paper sheet(100% scale), this will work as a guide to print on the pnp sheet.
5.- Cut a piece of pnp-blue just big enough to extend a little bit from the edges of your design on the already printed paper sheet, the extra length will help to print and transfer the design to the aluminum panel.
6.- stick the pnp blue to the printed paper sheet with some tape on each corner, use just enough tape to hold the pnp in place.
7.- Set the laser printer to high quality print, again, 100% scale.
8.- Print again, you should end with something like in the image below.
10 comments
Mar 9, 2010. 6:48 PMexlxaxd says:
One thing I don't understand: What's the purpose of printing on regular paper and taping the PNP to it? Can't you just print the design directly to the PNP Blue sheet without the pre-printing and taping? Great instructable, by the way.
Mar 22, 2009. 1:17 PMairfoil says:
would a photocopy machine work the same on pnp paper instead of a laser printer?
Feb 13, 2010. 12:35 PMflyingpumpkin says:
www.techniks.com/information.htm
According to the PNP website you can use a laser printer or photocopier (as long as it uses dry toner which is most of them).  You cannot use an inkjet.
"An image is printed or photocopied onto this film, using a laser printer or photocopier (dry toner based), and subsequently ironed or pressed onto a cleaned copper clad board. "
Apr 2, 2009. 8:08 AMelabz says:
Guys, I'm missing the important bit of info: what's a "pnp blue"? Is it a transfer paper of sorts?
Apr 2, 2009. 9:20 AMColorfulNumbers says:
That refers to "Press-N-Peel Blue," a product for transferring a resist onto metal. It's used for making circuit boards
It comes in sheets. You print your design onto the Press-N-Peel using a laser printer or copier (but not an inkjet), then transfer your pattern from the Press-N-Peel to the metal using a clothes iron. If you place the metal into acid, any surface not covered by the resist gets etched away, but the protected metal remains.
Details on the manufacturer's website here.
Sep 11, 2009. 12:29 PMdchall8 says:
Thanks to scriptster for asking about PNP and thanks to ColorfulNumbers for the reply. PNP stands for lots of different things. I had no idea this stuff was around. I wonder if the PNP will work to make a resist on fabrics?
Apr 2, 2009. 4:03 PMskullm says:
I hear somewhere you can use glossy photo paper, like when etching circuit boards. would this work?
Mar 22, 2009. 4:11 PMairfoil says:
Thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:sineSurfer
