How to extend the life of your Razor Blade keeping it sharp for months and months
 by jakerobinson
Contest WinnerFeatured
video How to extend the life of your Razor Blade keeping it sharp for months and months
This video shows a simple method of extending the life of an ordinary disposable razor blade for months and months and months. Razor blades are very expensive and most people use the blade for a week or more until it gets dull, then you change it to a new one. By using this simple 'Blue Jean Sharpening Method' it will extend your blade life and receive a sharp and smooth shave for months and months.. I don't know how long it will work as I am still using a blade that is at least 6 mos old now and I'm still using it...
When you finish shaving... walk to your closet... pull out one leg of a pair of blue jeans... hold the end with one hand and with the other simply stoke the razor along the entire length of the blue jean for 10 to 20 strokes... I like 20... then switch directions... the threads of the jeans run in a diagonal so switching directions allows for an balanced approach to fine tuning the blade's edge.
This is similar to using a straight blade on a leather strap... this is cheap or free considering you have a pair of jeans!
It will take the fine nicks out of the blade and allow for you to keep the blade very sharp.
I also sharpen the blade 20 strokes before and after each shave just for good measure.
I also blow on the blade to knock off any water droplets as oxidation/rust is the biggest enemy of a sharp razor blade.
If you want, you can drop your razor 'blade down' into a cup of rubbing alcohol to store it until next use to eliminate any traces of water.
This should save you tons of money... at the time of this video Gillete Fusion 4 blade pack sales for $13.99 + tax. if you generally get one week's worth of use per blade this will run you $167.88 per year + tax! If you get 6 mos per blade then you can extend your use for two years. The math works out to $7.50 per year + tax (two blades at $3.50 per ea)
Hope you get lots of shaves for free!
Brennn10 says: Apr 3, 2011. 9:07 AM
Nice job on making it to the front page of reddit!
jakerobinson (author) in reply to Brennn10Apr 3, 2011. 9:38 PM
thanks! this may be lame... but i had no idea what Reddit was!
but it's really cool to see how many folks voted it up... cheers,
Jake
mikeanator55 says: Jan 25, 2013. 7:58 AM
And congratulations again! Back on Reddit front page
ihvpave says: Jun 25, 2012. 8:09 AM
I've had incredible luck with this - my boyfriend told me about this method when we began dating, and I've been using the same razor ever since. It's been almost two years now on that cartridge. I "strop" my blade about once a month, and have a clean shave the rest of the time. I can't argue the results!
jakerobinson (author) in reply to ihvpaveJun 25, 2012. 9:09 AM
Wow! that's awesome! thanks for the feedback. cheers,
aridas99 says: Apr 9, 2012. 1:04 PM
This method really works; see the microscopic proof here http://teamdonline.com/technology/extend-life-razor-blades/
Jossy92 says: Oct 13, 2011. 2:20 PM
Soap scum gets "welded" to the blade ....the blue jeans Polsh the blade. The harder the water, the more strokes you need. Great instructable.
fefrie says: Apr 26, 2010. 5:34 PM
I use my leg in the shower as the strop.  Seems to work well for me.
Water and the roughness of my leg seem to do it right.
Make sure you go in the correct direction or you will shave your leg.
TaniaSue in reply to fefrieMay 16, 2010. 9:46 AM
Hi Fefrie;
I'm using a tool The Martell Shaving Pad,  I have my Venus for the past 7 months now, and let me tell you i;m very very surprised buy the astonishing results from still getting a nice smooth shaving. My boyfriend uses his Gillette fusion, and he is more than amazed. I recommend this shaving tool to everyone (Women/Men): The "Martell Shaving Pad"
http://www.innovatell.com/martell_shaving_pad.php
Cheers
Tania.
fefrie in reply to TaniaSueSep 11, 2011. 5:51 PM
I'll stick to my leg thankyou. It's convenient enough.
vtturbox says: Aug 3, 2011. 6:05 AM
Very useful informative post thank you.
One thing I would add in thought is that many people tap there shaver onto the counter or in the sink as we shave, that's probably a bad habit as this likely damages the blade.
tradergordo says: May 25, 2011. 12:01 PM
I think you can get the same result (prolonged life) just by storing the blade in rubbing alcohol when you are done shaving. Its the moisture that ruins the edge. I've gotten >6 months out of a blade just by storing it in in a small glass jar with lid containing just enough rubbing alcohol to cover the blade (replace the fluid every now and then). This also has the benefit of sterilizing.
sirfroggz says: Apr 15, 2011. 2:38 PM
I used a razor for a full year using this method. Works great.
CampyClassics says: Apr 7, 2011. 10:24 AM
I've been using the same razor for approximately 6 months now and I have toasted several pints in your honor. Thanks for the post! Sláinte
jakerobinson (author) in reply to CampyClassicsApr 7, 2011. 3:28 PM
Awesome! a pint in my honor... doesn't get any better than that! cheers
PistolShooter says: Apr 5, 2011. 5:14 AM
This is the reason I have started back in 08 to shave with a straight razor. No more cartridges, no more electric razor foils. Neat instructable though.
ATTILAtheHUNgry says: Apr 4, 2011. 6:19 PM
Amazing, I hate the expensiveness of disposable razors (especially after seeing how simply they are made on TV awhile back).
This method is way better than my current method (which is to use the same razor for months WITHOUT sharpening it, getting a progressively worse and worse shave everyday). Thanks!
jakerobinson (author) in reply to ATTILAtheHUNgryApr 4, 2011. 10:30 PM
t;hanks for the kind words... and hip,hip hooray! for saving money!
siafulinux says: Mar 16, 2011. 5:26 PM
I've found this instructable months ago and I'm still using the same razor. Something I missed was the rubbing alcohol, but I did see yesterday on Youtube somewhere (at work, can't pull it up right now) to put it in Olive Oil for the same reason; I think rubbing alcohol is a little cheaper :-).
Thanks again for this one!
jakerobinson (author) in reply to siafulinuxMar 18, 2011. 12:51 AM
oil works fine. I have stopped using shaving cream... now I use hair conditioner as shaving cream... usually from the travel size we accumulate when we stay at hotels... more savings...
siafulinux in reply to jakerobinsonApr 4, 2011. 5:33 PM
I'll have to give conditioner a try, I've used soap before but it's not all that great for me.
shrpshtr325 says: Nov 18, 2010. 2:24 PM
(removed by author or community request)
jakerobinson (author) in reply to shrpshtr325Nov 18, 2010. 10:28 PM
You are the exception to the rule then... most people will agree without any treatment a typical razor will only give a good close shave for 5 to 8 shaves... maybe your whiskers are just really easy to cut? ;>)
shrpshtr325 in reply to jakerobinsonNov 19, 2010. 5:54 AM
karossii in reply to shrpshtr325Apr 4, 2011. 3:08 PM
I have very thick and coarse hair, and I am lucky if I get 3 shaves out of one disposable blades before it starts cutting me up...
jakerobinson (author) in reply to shrpshtr325Nov 19, 2010. 6:13 AM
Have you seen the comments on this ible? or the comments on the Youtube location? tons of people have this issue... why do you think they call them 'disposable'. maybe you guys have really "soft water" or something...
anyway, don't fight it bro... you can make your blade last ten years!
shrpshtr325 in reply to jakerobinsonNov 19, 2010. 12:22 PM
KittyF in reply to shrpshtr325May 20, 2011. 1:12 PM
one thing that I think makes a difference is cleaning ALL the bits of hair and stubble and soap and even as much as possible all water off the blade. leaving stuff on the blade allows the moisture to sit there and rust the blade microscopically. I've seen so many disposable razors left to sit til next use with soap or stubble under it and its gross as well. I clean mine carefully and it lasts me a year.
jakerobinson (author) in reply to shrpshtr325Nov 19, 2010. 1:17 PM
good point... if you are doing something that makes your blade last nine mos then your ible will be a bigger hit than mine...
now about denim...
what is softer? Leather or Steel blade?
then why is leather used to sharpen a barber's razor?
same principal... it removes the fine nicks on the blade as well as oxidation and rust... think of it as polishing the blade...
SecretGuideToShaving says: Oct 24, 2010. 5:28 PM
This is one of those "urban myths" people have been posting on the internet. It was busted after some people actually viewed it and put it to the test. What they did was take a fresh razor, viewed it under a dissecting microscope and attempted to sharpen it with the blue jeans. It doesn't sharpen it in the least bit. If you're really concerned about razor blade life and shaving, check out my instructable http://www.instructables.com/id/So-you-want-an-old-fashioned-double-edged-safety-r/
jakerobinson (author) in reply to SecretGuideToShavingApr 4, 2011. 3:01 PM
actually, this is a stropping technique - not sharpening... sharpening actually removes some of the metal... stropping is just like barbers do with a straight razor... the idea is to 'staigten' the blade back out... the blades on disposables are so then that the edge gets 'folded over' on itself... stropping the blade on a coarse fabric (think leather strops that barbers use) piece of material like denim and you achieve a similar result.
The video for this 'ible made it to the top of Reddit... and in the conversation on that link one person actually viewed the blade under strong magnification both before and after stropping and reports he was able to observe a marked improvement...
hope this helps... if not, let's try again...
Cheers
http://www.reddit.com/r/todayilearned/comments/ghiol/til_how_to_restore_gillette_razor_blades_to/
comp_wiz101 in reply to SecretGuideToShavingApr 4, 2011. 1:59 PM
The real benefit to this is that the motion helps draw moisture off the blade edge. Admittedly, it would be much better if both sides of the blade are stropped (just as a straight razor is). Another strop used for the straight razor is the "Canvas strop", which truly a strap of heavy cotton.
Nice 'ible! I use a badger brush + non-aerosol cream with my 1940's British Aristocrat Jr. safety razor.
jakerobinson (author) in reply to comp_wiz101Apr 4, 2011. 2:40 PM
thanks for your feedback... cheers,
jakerobinson (author) in reply to SecretGuideToShavingOct 25, 2010. 5:51 AM
Hmmmm, then all us folks must be exuding mind-over-matter....
works for me...
seems your explanation is self-serving...
btw, who are these 'some people' and do you have any hard evidence?
and if you took a fresh razon and tried to sharpen it - of course it wouldn't sharpen if it is already brand-new and sharpened.... ???
chihuahualover112 says: Apr 4, 2011. 5:28 AM
this has been fantastic! i figured it would work with women's razors too, and it does! i've probably been using the same razor blade for close to a year now. i was always sick of my dad going to buy the wrong razors or guilt me about how expensive they were...thank you so much for being such a genius.
jakerobinson (author) in reply to chihuahualover112Apr 4, 2011. 10:19 AM
Wow, solving deep-rooted family issues, who knew! cheers,
capricorn says: Apr 4, 2011. 3:28 AM
You sir are astounding :)
Thanks for sharing :)
jakerobinson (author) in reply to capricornApr 4, 2011. 10:19 AM
thanks for that! cheers,
lesrebnav says: Apr 4, 2011. 2:15 AM
awesome !!
mattthomas992003 says: Mar 17, 2011. 11:57 PM
ive been doing this method but with a terry cloth towel since i was 16 and now i am 22 i have had the same blade for over a year now
jakerobinson (author) in reply to mattthomas992003Mar 18, 2011. 12:49 AM
that's too cool...
Eddie_T says: Mar 16, 2011. 8:21 AM
Sounds good. My Dad's razor strop had leather on one side and a heavy twill on the back side.
djmachet says: Oct 24, 2010. 11:15 PM
Perhaps it would sharpen the blade... but half the wear on disposable razors is in the consumable glide strip just above the blade - sure you'll still use shaving cream, but the razor still won't glide as smooth without this strip
teveman says: Oct 19, 2010. 7:06 AM
Seems to me that if you have a few of those dessicator packs around you could throw the razor in a bag with those after doing the 20 strokes on jeans. Should eliminate the moisture problem. No dessicator packs? Just use dried rice. Both can pull moisture out of a cell phone in all the cracks and crannies inside and out.
jakerobinson (author) in reply to tevemanOct 19, 2010. 8:18 AM
Hey teveman, that's a good idea... zip lock w/rice - pop it in there... gonna start diong that...
cheers,
Jake
Skyriam says: May 13, 2010. 2:56 PM
Hello Jake, excellent video, got one question. Wich is best, "drying" the blade to remove water or just leave it in a cup of alcohol until next use? Thanks!
doxsys in reply to SkyriamJul 1, 2010. 7:12 AM
I can't keep an open cup of alcohol on the shelf, having young kids (I'm afraid they'll knock it down and spill it in their little eyeballs.) After some experimentation, I've found a method that keeps the blade edge from degrading due to oxidation: I've been using the shower curtain to sharpen the razor, which seems to work well, and is more convenient than going back to my room for my jeans. After I sharpen the razor and shave, I dry it off with a towel, give it a few more strokes on the curtain, then squirt alcohol-based hand sanitizer containing aloe (which is important, as it turns out) on both sides of the blade. I then pop the blade back into the plastic holder it came in, and leave it there until the next time I go to sharpen and shave. I discovered by accident that the aloe makes a huge difference -- Regular hand sanitizer, even with "moisturizers", doesn't keep the blade from degrading, and I was replacing the sharpened blades almost as often as I was before I started using this sharpening technique. (I figured this out as I had hand sanitizer with aloe in my travel bag, and I was using that on vacation. I noticed that the blade stayed sharp until I got home and started using the other stuff, which was when the blade started to go downhill.) Since I started using the stuff with aloe, I haven't had to replace the blade yet (2+ months.) Jake -- THANK YOU for posting this!! You've saved me a ton of money.
jakerobinson (author) in reply to doxsysJul 1, 2010. 10:35 PM
doxsys, thanks for the feedback and the compliment... and the aloe idea... will have to try that...
jakerobinson (author) in reply to SkyriamMay 13, 2010. 3:11 PM
Good question and thanks for the kind words...
well, you can slice and dice this one (no pun intended)
i did at one time use alchohol but it does have a small bit of water contained in it... also, i found it evaporates fairly quickly... so you "lose" some of your savings by purchasing another element in the process...
I would definetly not use a hair dryer to dry the blade as it uses a bit of electricity which in turns steals your savings too...
I always rinse my blade (just habit) and hit it on the jeans for 10 strokes in both directions... shave... then hit it again for 10 and 10... this usually will rid most moisture... i blow really hard a couple of times to make sure i knock off any moisture (this may be futile but prob can't hurt) and then i place the blade in it's holder.. i don't think it will be that wet if you hit your jeans after using... and it should air dry by the time you shave again...
and by that time you are sharpening it again removing most oxidation if there is any that has formed...
I do notice a fairly good wet spot at the beginning of my jean-strokes as the jeans will absorb most moisture...
long answer... short one is - don't do alcohol or hairdryer just hit the jeans...
cheers,
jake
Skyriam in reply to jakerobinsonMay 13, 2010. 4:44 PM
Hi Jake thanks for your quick and kind response. What about hermetically sealing the blade/alcohol in a container? Like mayonese or some tupperware, that would overcome the evaporation problem, what do you think?
jakerobinson (author) in reply to SkyriamMay 13, 2010. 11:27 PM
Now that might just work... can't see anything wrong with that.. but i did have a comment a while back that said alcohol has water content... so it was suggested to use mineral oil... absolutely no water and i think it won't evaporate... might be able to use that without having to seal it too...
also, mineral oil is supposed to be good for your skin... cheers,
Alphonsus in reply to jakerobinsonOct 9, 2010. 11:13 AM
I've also been told to try this, but i found it causes any rubber strips on the blade to swell up and fall off!
jakerobinson (author) in reply to AlphonsusOct 9, 2010. 7:51 PM
you could avoid stopping blade while you still have a bit of 'lubrication strip' still has life... but eventually it goes away... you will have many more shaves after the strip is gone - i do lose all the strips peel off... just have to adjust your pressure and be sure not to cut your face... i've used mine to the point that the blade broke off its mount... then i finally have to go to a new one... i'm using my wife's pink disposable right now...
Skyriam in reply to AlphonsusOct 9, 2010. 1:17 PM
Yes, I used olive oil and the rubber and other things fell off. I currently use Jakes method, one pass before and one after, then store the blade in a dry ans fresh place, not the bathroom, it has worked for me for the past months very well.
baneat says: Jun 26, 2010. 12:16 PM
The fact that this works makes me think the razors aren't getting dull, rather the sharp edge is getting covered in small debris, obscuring the edge. Am I right? A pair of jeans hardly seem rough and strong enough to actually scrape metal for sharpening.
jakerobinson (author) in reply to baneatJun 26, 2010. 9:05 PM
Hey Baneat, it may seem like jeans wouldn't have much impact... but if you could see the blade under a microscope you would see a very jagged edge due to cutting y our beard... the jeans just acts as a way to smooth the edge and take off the jagged 'spikes' thinks of a leather strap used to hone a straight razor... it is "less rough' than jeans but puts the finely honed edge on a blade.... same concept...
mondaymonkey says: Mar 16, 2010. 4:45 PM
I do this simply for the convenience.  I hate running to the store every week or so for a new razor...
TaniaSue in reply to mondaymonkeyMay 16, 2010. 9:47 AM
Hi Monkey hihi
Just to let you know ,I'm using a tool The Martell Shaving Pad and it sells only for 20$.  I have my Venus for the past 7 months now, and let me tell you i;m very very surprised buy the astonishing results from still getting a nice smooth shaving. My boyfriend uses his Gillette fusion, and he is more than amazed. I recommend this shaving tool to everyone (Women/Men): The "Martell Shaving Pad"
Cheers
Tania.
TaniaSue says: May 7, 2010. 4:55 AM
This Video is very interesting! Im using a tool The Martell Shaving Pad, and it uses a grooving surface. I have my Venus for the past 7 months now, and let me tell you i;m very very surprised buy the astonishing results from still getting a nice smooth shaving. My boyfriend uses his Gillette fusion, and he is more than amazed. I recommend this shaving tool to everyone (Women/Men): The "Martell Shaving Pad"
The company selling it is www.innovatell.com
you can see also the news papers articles talking about this invention.
this is the page product:
Cheers
Tania.
jakerobinson (author) in reply to TaniaSueMay 7, 2010. 10:49 AM
Tania,
that's very cool... this validates my method.... some have scoffed at the idea.... but jeans are 'grooved' as well... and i too, strop both before and after... Martel may have refined the surface to get the job done with better results.. but i'd like to compare... thanks for the revelation...
cheers,
Jake
TaniaSue in reply to jakerobinsonMay 16, 2010. 9:43 AM
Hi Jake,
Yes, indeed the Martell Shaving Pad is  a very cool invention, and for the price; It's really worth it. 20$ in exchange of many months without buying new blades and having the same comfort, its priceless; and it keeps going. I tried your method just for fun hihi, but I don't get the same results :-( as the Pad, I have to admit that if the Martell Shaving Pad was selling for 100$ I could understand looking for other methods; but why bother at this price.
Thank you for you nice Videos
Cheers
Tania
supersolarjetman says: Mar 14, 2010. 12:45 PM
nice
HeWantsRevenge says: Mar 9, 2010. 12:42 AM
THIS IS TO EXTEND TEH LIFE SPANS OF NEWER BLADES...people please read more careful next time...sounds like alot of u are using blades already damaged and this instructable is bout preserving ur new or newer blades
mojocracker says: Mar 8, 2010. 9:05 PM
I tried the jeans method and drying.  Neither work.  Sorry.
jakerobinson (author) in reply to mojocrackerMar 8, 2010. 11:45 PM
hmmm, we have overwhelming feedback that it does... maybe you're doing something wrong or maybe you have a particular blade or flawed blade?
or maybe you are doing it wrong and you don't realize it...
drying was not part of my advice....
technosmechno1 says: Feb 4, 2010. 9:13 AM
Excellent idea. I grab my wife's blowdryer and dry my razor after use. I think water/rust is the biggest enemy of the micro edge of the blade.
jakerobinson (author) in reply to technosmechno1Feb 4, 2010. 12:09 PM
You're right - water is the biggest enemy... i choose not to use a hairdryer as I wonder if i am nullifying my savings by using extra electricity to run the hairdryer... the jeans methods drys the blade but also does help hone the edge... probalbly quicker too...
technosmechno1 in reply to jakerobinsonFeb 4, 2010. 7:06 PM
Just a side note, this is how the man, King Gillette, made his fortune. Give away the handle, charge for the blades.
Kryptonite says: Feb 4, 2010. 2:49 AM
I've just started shaving and I still haven't worn through my first blade, but I was astonished at the price of the blades and have decided to be careful as to how often I use them, because I don't want to have to keep buying knew ones. But now I have the answer! Thank you very much, great video!
jakerobinson (author) in reply to KryptoniteFeb 4, 2010. 6:03 AM
Hey Thanks!
Wish i'd learned about this when i first started shaving... i would have saved arounnd $15,000 + investments gains... oh well, cheers,
Foghorn Leghorn says: Jan 18, 2010. 11:11 PM
I do the same thing with a paper towel.  Dry or wet should work, but I like to wet a folded paper towel and slap it down onto the counter while i'm shaving.  Every couple of strokes, I will push the razor backwards across the towel a few times, and I'll do it a few extra times when I'm finished.  I've been using the same blade for about six months now.
knektek says: Jan 14, 2010. 12:46 PM
you know you could just 'blue' your razor blade. this process is heating the blade up untill it gets red.
Deadly Computer says: Oct 8, 2009. 7:09 AM
I've tried this with a variety of diffent razor blades, from 2 blade disposables, to 4 blade quatros, on a few pairs of jeans, and it just doesn't work for me.
What am I doing wrong, if anything?
I take the razor, and stroke it up the jeans, then turn the jeans around and do it again.  I've tried 10-30 strokes in both directions, and no luck.
I'd love to have this work, as it can save tons of money, any tips?
BMWalsh in reply to Deadly ComputerOct 13, 2009. 10:46 PM
-If your jeans are "cupping", then your blades will not make full contact. Try pulling the jeans taunt so then the every blade makes full contact with the strop (jeans).
-You could be using to much pressure. If you use too much pressure then the curvature of the jeans will make the blade bend into the razor at the tip. This will shorten the life of your razor. Almost no pressure is the best.
-If all else fails go invest in a straight razor and all of the supplies, you will save money in the long run. I haven't regretted it.
jakerobinson (author) in reply to Deadly ComputerOct 8, 2009. 11:10 AM
hmmm, my first 'trouble shooting' case... haven't had anyone who says it wouldn't work...
1.  What type of 'jeans'?  - make sure it is real denim... you will notice a 'diagonal' thread pattern of 'ridges' this is what strikes the blade to hone it..
2.  Are these blades that you have laying around? - maybe they are too degradaded (from moisture - then rust) that you are not able to revitalize them
3. Have you tried a new blade and use this method from the get go?  If not, try this.. and see if you see an extension of a new blade compared to your normal life..
4. Maybe you have a really really strong/hard beard ;>)
5. try different 'angles' of contact on the denim... you may have a disposable that has a sharper angle and you are just 'sharpening' the plastic housing and not getting good contact with the blade...
I have not tried this on every type of blade out there.. i do use Gillette Quantum whatever and it works on them (orange theme) it's funny they are advertising on my youtube video...
i always do 20 strokes in both directions before i shave, then ten each way after (mainly to knock off the water and in case i ever forget the next shave or in a rush)
hope this helps, if not let's try again.. i've had many folks try it and respond...
Junk Mail says: Oct 1, 2009. 5:15 PM
Hey, sweet idea! I cant believe its that simple. But, how often do you strop the blade? Daily? When it dulls?
jakerobinson (author) in reply to Junk MailOct 1, 2009. 6:50 PM
I strop every day - i do 20 strokes in both directions.. then 10 strokes each way after shaving (mainly to knock the water off and if i happen to forget the next shave) just takes about 20 seconds a day...so I would recommend doing it everytime you shave even if the blade is new...
Cai says: Sep 30, 2009. 1:03 PM
Thanks A LOT!!!! You are fantastic! You have just saved me a TON of money. I love to sharpen knives and have always wondered how to sharpen my razors for my face and you have nailed. I just have one thing to say to myself Duh...why didn't I think of that? Kudos to you! The most practical idea out there...the best thing since sliced bread, better probably. less carbs and no one can complain! Thanks bunches. I wish I could pay YOU the money I will save, but then I wouldn't be saving it now would I. Just know you have done a wonderful deed. May you and all your children be blessed, just because of this video. (Is that a little over the top?) Any way, thanks.
jakerobinson (author) in reply to CaiSep 30, 2009. 11:27 PM
LOL i am at a loss for words... thanks! cheers!
amnartist says: Sep 24, 2009. 9:10 PM
My grandson tried it and said it works great. He uses those expensive 4 or 5 blade jobs so he is happy...said it will save him lots of money! Where did you get the idea?
jakerobinson (author) in reply to amnartistSep 24, 2009. 10:18 PM
i honestly can't remember - i am sure i read about it somewhere on the web.. could have showed up in a forum.. i'm amazed at how many people are so receptive... this video is posted on Youtube and it closing in on 100,000 views! thanks
cleody says: Sep 23, 2009. 1:37 PM
You're fantastic! Hooray for saving money.
jakerobinson (author) in reply to cleodySep 23, 2009. 2:09 PM
Thanks for the kudos... cheers,
roystonlodge says: Sep 17, 2009. 7:27 AM
This is wonderful! I tend to use my blades far longer than their actual useful life, and I end up cutting myself. Question: Does this method also help clear out the gunk that gets stuck between the blades? I can never get my blades clean, especially when I use blades that have those "protector wires".
jakerobinson (author) in reply to roystonlodgeSep 17, 2009. 9:02 AM
roystonlodge, thanks for the comment and question... i'm thinking it will most likely not help much to keep the gunk clear... I tap my razor on the edge of my sink each time i am realy to rinse of (after several face strokes) this get the bulk of the gunk off and also rinse under faucet at full blast... tons of stuff come out... so i tap, tap, tap, rinse, tap, tap, rinse until nothing visible is coming out before i continue shaving... seems to work well for me.. Please vote yes! thanks, jake
roystonlodge in reply to jakerobinsonSep 22, 2009. 8:06 AM
FYI: I gave it a shot with my vibrating Schick. Worked like a dream. The rubbing alcohol DID clear out all the gunk, lickety-split. Plus, after sharpening on the old jeans and dipping in the alcohol, I didn't need any shaving cream at all. The alcohol seems to revitalize the "lubrication strip" on the razor.
This instructable has proven far more useful than a duct-tape wallet or altoid tin computer...
jakerobinson (author) in reply to roystonlodgeSep 22, 2009. 11:33 AM
roystonlodge, Thanks for the awesome feedback - it's always great to hear folks using the idea and getting positive results!
ldumay says: Sep 21, 2009. 6:35 AM
Now that voting is over, I have a question for you: Your still shot it one of a Gillette product. (As well, in your instructions, you mentioned their name.) Did you have to get permission to use their product? It is alluded to in Rule 10, which reads in part, "By entering, Entrant represents that any (video(s), photo(s), essay, etc.), and other materials submitted as part of Entrant's Contest entry are original and will not constitute an invasion of privacy or otherwise infringe upon the rights of any third party, and that the Entrant owns or has the rights to convey any and all right and title in such recipe(s). Besides, these legal matters, first rate job! Good luck!
greeenpro says: Sep 20, 2009. 3:59 PM
Great job! Thanks for the tip. I've entered a few videos into this contest as well, but I have to say that I think this is the best one....really practical.
jakerobinson (author) in reply to greeenproSep 20, 2009. 6:12 PM
greeenpro, Thanks so much for the kind words! I really appreciate you flattering feedback! cheers, jake
greeenpro in reply to jakerobinsonSep 20, 2009. 7:27 PM
Cheers right back at 'ya and best of luck to you.
Spokehedz says: Sep 20, 2009. 5:08 PM
"If you want, you can drop your razor 'blade down' into a cup of rubbing alcohol to store it until next use to eliminate any traces of water." Bad idea... Most rubbing alcohol is up to 30% water--this will make your blades rust faster. You can use 99% alcohol, but it will evaporate quickly unless sealed up. And even then the 1% of water will eventually cause rusting. The better choice is to get a small container of mineral oil. No water, no rust. The oil lasts forever, you can keep your fingernail trimmer in there as well as your tweezers to keep them rust-free as well. And it is safe to get into cuts and even to 'eat'... although, I would recommend against it as it is a laxative.
jakerobinson (author) in reply to SpokehedzSep 20, 2009. 7:26 PM
Spokehedz, good point - thanks for the headsup - will do this... cheers,
charlieb000 says: Sep 18, 2009. 1:50 PM
Ahh now ive watched the video, you need to write "forward strokes" for both directions, the text seems to read that you "shave" your jeans. i also noticed the lubrication strip may also be a source of problems, when it disappears the angle of the blades may change for the worse... and i did bend the plastic out a little to improve it , and these instructions should be better too.
jakerobinson (author) in reply to charlieb000Sep 18, 2009. 2:26 PM
charlieb000, thanks for the comments.. i figured that with the video and that you could see what i was doing it was not necessary to explain this... did you 'read' the directions before watching the video? "Ahh now ive watched the video" - sounds like you read the directions and didn't view the video... no where did the text say you should 'shave' your jeans... I guess this is why 'disclaimers' on products are so prolific...even when my lube strip comes off I just keep using it as since it is always sharpened it works great... thanks for your feedback
barry960 in reply to jakerobinsonSep 19, 2009. 1:05 PM
I just wanted to read, and not watch, just preference, and when you said both ways it does seem to imply 'shaving' your jeans. No big whoop. My own sense would have prevented that, so this is why the world shouldn't need disclaimers. People should take responsibility for not having enough logic and thinking for themselves. (not implying anything against you, charlieb000, just saying)
jakerobinson (author) in reply to barry960Sep 20, 2009. 1:58 AM
I understand that, however, this contest is specifically a video, any text was gratuituous... cheers,
ochoa10 says: Sep 17, 2009. 9:15 PM
Hi jakerobinson! Do you think it could be a good idea to put the blades in front of a hair drier? For your answer! Thank you!
jakerobinson (author) in reply to ochoa10Sep 18, 2009. 12:14 AM
Drying the blade is definitely a positive thing to do... however, i haven't put any numbers to how much 'extra' electricity you might use with a hair drier... i kinda like the idea of dropping the razor into a cup of 91% rubbing alcohol to displace the water... but drying it with hair dryer will definitely work... thanks for the question... Please vote if you received value from this video!
ochoa10 in reply to jakerobinsonSep 18, 2009. 11:25 AM
Thanks for your answer! Definitly the alcohol method is far, far ,far better. It was just only an idea that comes to my mind!
corporatezero35 says: Sep 18, 2009. 4:35 AM
Looks like a viable technique. Although I can say that using a disposable razor is completely horrible once you have shaved using a safety razor. Aside from being cheaper, you can't beat the quality of a barbershop style shave. For anyone interested, this site shows how to. http://artofmanliness.com/2008/01/04/how-to-shave-like-your-grandpa/
jakerobinson (author) in reply to corporatezero35Sep 18, 2009. 11:23 AM
Hey corporatezero35, thanks for the interesting link... i may have to investigate further...
olsekeg says: Sep 18, 2009. 12:18 AM
Have you ever tried this an a electric razor its expensive to replace the whole unit every year.
jakerobinson (author) in reply to olsekegSep 18, 2009. 1:39 AM
olsekeg, hmmm, not sure... i'd have to take a close look at the shaver head... it seems possible but not informed enough to make a determination... since most electri razors are round maybe going in a cicle would work.. then again i don't know if the blade is exposed enought to contact the stropping surface... cheers, thanks for the comment and question
AgentSmith15 says: Sep 17, 2009. 9:44 PM
The metal used in disposable razors is not the same used in straight edged razors. The metal is harder and less malleable thus not quite the same when stropping a straight razor.
jakerobinson (author) in reply to AgentSmith15Sep 18, 2009. 12:11 AM
Not sure if this is a plus or not... even so, disposables last much much longer by stropping on denim or even leather... thanks for your comment
Tom 7 says: Sep 17, 2009. 9:28 AM
as a blade dulls it curls stooping bends the edge back to where it should be
swaneybob in reply to Tom 7Sep 17, 2009. 11:03 AM
Isn’t stooping what you and a romantic affiliate might do on the porch? I wouldn’t try it with a razor. There might be permanent damage. I believe it's called "stropping" when you do it to a razor.
jakerobinson (author) in reply to swaneybobSep 17, 2009. 1:22 PM
surely just a typo... thanks
jakerobinson (author) in reply to Tom 7Sep 17, 2009. 10:14 AM
Tom 7 - thanks for the poignant comment - chees,
larsrc says: Sep 17, 2009. 5:13 AM
I saw a similar trick in The Tightwad Gazette (a must-read for anyone trying things like this to save money), where they just suggest drying off the razor. I have been doing that for years, just drying it on my towels, and I use my blades for months. But maybe my stubble is just not hard on the razor -- though it's been known to give splinters:)
jakerobinson (author) in reply to larsrcSep 17, 2009. 8:48 AM
great tip - is the tightwad gazette online? where do you get it? thanks, jake
larsrc in reply to jakerobinsonSep 17, 2009. 10:38 AM
No, we got the Complete Tightwad Gazette as a book. It's on Amazon (http://www.amazon.com/Complete-Tightwad-Gazette-Amy-Dacyczyn/dp/0375752250), and definitely worth it. It goes from small things like the razor blade tip over how to buy big things well to general principles of economics in a wonderful treasure-trove manner and a great writing style.
jakerobinson (author) in reply to larsrcSep 17, 2009. 1:21 PM
Hey thanks, i appreciate the link...
travisrichardson1980 says: Sep 17, 2009. 10:22 AM
i agree: PROPER CARE can extend a disposable WAY beyond it's expected life!! your trick is awesome!! i never heard of it before! i use triple blade disposables with green handles, sold in walmart 4 for $2-3 my last blade lasted me for over six months, and i use it to occassionally shave my entire head! it was still sharp enough to shave with after that, but it was so discolored by shaving foam that i decided to let it go... now i'm using the second blade from the pack, and have two more left!! here's my method: 1 -use a small bucket or a sink filled with water, rather than running water 2 - between strokes, shake the blade vigorously under the water (works great to clean out the hairs!!) 3 - tap the head firmly against the side of the bucket/sink to clear the remaining debri AND to get almost ALL the water out 4 - repeat 5 - when finished, shake the head under water for an extra few moments, then tap the head repeatedly on the tub/sink to get everything out from between the blades. 6 - keep the blade guard, if you can, and store with it on, in a dry place, away from the sink and tub. that's it! just keeping the blade clean and dry will keep it sharp for a LONG time - i wish more people knew about this!! great instructable, i'm going to try the jeans trick tonight, and hopefully i can stretch my razors even LONGER!! LOL
jakerobinson (author) in reply to travisrichardson1980Sep 17, 2009. 1:21 PM
travisrichardson1980, thanks for the detailed tip - an 'instructable' inside an instructable! cheers,
genericcomment says: Sep 17, 2009. 9:16 AM
Awesome! One of those so simple never would have thought of it type of things.
jakerobinson (author) in reply to genericcommentSep 17, 2009. 10:15 AM
I'm glad you found something useful and easy to use... thanks for the comment... please vote if you found value! cheers, jake
kirnex says: Sep 17, 2009. 6:23 AM
I've never used the jeans technique, but I have been soaking my razors in rubbing alcohol for years. It makes the razors last so much longer it's ridiculous. A suggestion for anyone wanting to do this: use 91% isopropyl alcohol. The 70% has too much water in it and will, over time, rust your blade. I also like to add a few drops of clove oil to it to act as a mild analgesic--plus it cuts the smell of the alcohol.
jakerobinson (author) in reply to kirnexSep 17, 2009. 8:53 AM
great tip - i didn't know 91% was out there... and the clove oil tip is neat too.. cheers,
kirnex in reply to jakerobinsonSep 17, 2009. 9:27 AM
You bet. If you can't find the 91% at your grocery or Wal-mart/Target type place, drugstores definitely carry it.
Dunno if this applies to you, but you might want to check out this string re: razor bump, while you're at it.
http://www.instructables.com/answers/How-do-I-prevent-razor-burn/
This stuff I recommend for stopping razor bump is CHEAP and VERY effective.
Best Regards.
jakerobinson (author) in reply to kirnexSep 17, 2009. 10:13 AM
kirnex, thanks for the tips - good comment... cheers,
Duckism says: Sep 17, 2009. 9:00 AM
yay! thanks a lot for this great idea! I have often wonder if there is anyways to make my razors last longer. they're too expensive and I feel like I am just paying the packaging and advertisement. I just tested this method out, first I shaved half my face with my dull blade and then I sharpened it with my jeans and finished off the other half of the face. Wow what a different it makes! As for shaving cream, I have been using olive oil for many years now it works really well and its good for your skin too!
jakerobinson (author) in reply to DuckismSep 17, 2009. 9:12 AM
You guys are awesome... Duckism, thanks for the side-by-side comparison... that is probalbly the best way for anyone to 'prove' it to themselves... good going... and thanks for the olive oil tip.. i am starting to see a trend here about oils... cheers,
bluzjamer says: Sep 17, 2009. 7:13 AM
Great, now if you can only find a way to save me money on my cable bill!
jakerobinson (author) in reply to bluzjamerSep 17, 2009. 8:59 AM
bluzjamer, wow, that's a tough one, and in 30 seconds - the only thing would be a call to cancel it! cheers,
Garasvaldi in reply to bluzjamerSep 17, 2009. 8:25 AM
if you really want to save on your cable bill, just drop the cable and find all your shows online. there is sidereel.com, hulu.com and many others out there that are free to watch. Have fun
a2e in reply to GarasvaldiSep 17, 2009. 9:15 PM
mytvblog.org. Most of files are in parts on rapidshare.com You should try Raptor; a rapidshare downloader really good... you only enter the URL's and go to sleep.
Garasvaldi in reply to a2eSep 18, 2009. 12:14 AM
No, not with sidereel.com or hulu.com they stream, no direct downloading required, that is why I suggested it, most people don't want to bother with downloading and having to find the right codecs to play the vids they download. and I did say I solved it in less than 30 seconds, takes longer than 30 to download a whole show now doesn't it :p
jakerobinson (author) in reply to GarasvaldiSep 17, 2009. 9:12 AM
now you're talking... good idea... cheers,
Garasvaldi in reply to jakerobinsonSep 17, 2009. 10:15 AM
and it took me less than 30 seconds to explain it :D
iamunique127 says: Sep 17, 2009. 7:26 AM
So I read the first page of comments and was convinced. I ran to the closet and began "stropping" my jeans. Funny, they were getting thinner and thinner. All of a sudden I'd shaved right through one leg. I figured I must have done something wrong. I tried the other leg. Nope same result. So I came back here and read the second page of comments and finally came upon Jake saying "I do strop away from cutting edge". Dang! Oh well, at least I'll fit in at the next punk rock concert. And now that I've got it figured out my blades are much sharper. Thanks Jake. Vote cast.
jakerobinson (author) in reply to iamunique127Sep 17, 2009. 8:58 AM
iamunique127, haha, can't decide if your pulling my leg or not... anyway, thanks for the vote... cheers,
Peale says: Sep 17, 2009. 6:26 AM
Different blades give different results. I was using a blade (which escapes me @ the moment, I haven't used it in years) that was expensive, but I couldn't use it more than a week. I got a free Gillette Turbo from them some years back, and now I won't use anything but. I can get a good four or five months of shaves out of it before I have to replace it. And I shave every day.
jakerobinson (author) in reply to PealeSep 17, 2009. 8:55 AM
Hey Peale, thanks for that... maybe you can go for a year or so at a time now! cheers,
jridley says: Sep 17, 2009. 5:45 AM
I'll have to try this. I already use a disposable for about 6 months anyway, maybe I can make one last a year! 'Course, the house brand pack of double-edges I'm on now had 14 razors in it for $4.50, so this trick could save me 33 cents a year! Maybe I won't bother.
jakerobinson (author) in reply to jridleySep 17, 2009. 8:50 AM
good comments - maybe you will want to sharpen each time even tho you won't save much - having a sharp blade is always preferrable to a slightly duller one... cheers,
Javin007 in reply to jridleySep 17, 2009. 6:37 AM
*heh heh* Yeah, the alcohol would probably run ya that much.
jakerobinson (author) in reply to Javin007Sep 17, 2009. 8:54 AM
worthy speculation... but rubbing alcohol is very inexpensive... less than a buck and one bottle should last you months...thanks for the comment
Javin007 in reply to jakerobinsonSep 17, 2009. 11:25 AM
Ah, I wasn't saying that your instructable wouldn't pan out. (I can't even use regular blades, so I wouldn't know the cost.) Was just saying in response to jridley that if he would end up saving 33 cents, for him it may not be worth it.
jakerobinson (author) in reply to Javin007Sep 17, 2009. 1:52 PM
good comments anyway... thanks
trgz says: Sep 17, 2009. 5:31 AM
Neat - I'm going to give this a go. I noticed that some blades come in diamond and non-diamond finishes (Wilkinson for one) and found that the cheaper options lasted only a couple of shaves, however I've run a Wilkinson Protector (2-blade) and a Gillette Fusion (5-blade) for weeks before I need to change - I'm a 46yr old with a reasonable amount of light coloured beard growth, though I do tend to shave every other day, and never before cycling, for comfort - but this tip could still save a fair bit.
jakerobinson (author) in reply to trgzSep 17, 2009. 8:47 AM
trgz, thanks for the comments...
JamesRPatrick says: Sep 11, 2009. 4:46 PM
Interesting honing technique. I wish I could use it, but shaving with the same razor more than twice gives me acne.
mad_mat in reply to JamesRPatrickSep 17, 2009. 5:03 AM
James, I used to get terrible acne and at my age it was embarrassing. Definitely due to bacteria for me and I hated using the extremely expensive acne soaps and creams, so I started using (our every day cake of) Dettol medicated soap instead of shaving cream and I have never had acne since! I just lather it up on my hands a little bit then rub it on my face, and since we use that soap in the tub anyway there's nothing extra to buy! There are other brands too, I think 'sunlight' does a medicated soap, but my misus buys our soap so I cant say for sure.
jakerobinson (author) in reply to mad_matSep 17, 2009. 8:42 AM
mad-mat - great feedback... i am learning so much about the art & science of shaving! thanks for the feedback! if you feel you recieved value your vote in the contest will be appreciated... cheers, jake
shantinath1000 in reply to JamesRPatrickSep 13, 2009. 8:16 AM
I wold suggest a couple of experiments. The acne is most likely caused by bacteria either in the follicle / skin surface or stuck on the razor. experiment 1- before shaving use a cotton ball to wipe down your face with alcohol and let air dry. experiment 2 - Use razor 1 on day one and razor 2 on day 2. then on day three go back to razor 1 and on day 4 go back to razor 2. On the days that you don't use a razor dunk it in alcohol and dry it carefully and set it where it will dry fully. if you try these let me know the results and don't forget -you could just grow a beard!!
jakerobinson (author) in reply to JamesRPatrickSep 11, 2009. 9:45 PM
Hey James, don't know what you can do about this... maybe if your blade is sharp and if you kept it submerged in rubbing alcohol it may work... don't know if it is a 'duller' blade or maybe bacteria that could be causing this... (i'm not a dermatologist - have you ever asked one about this?) maybe try the sharpening method on a blade you have only used once and see if it may work... maybe you can get two or three additional uses which can greatly extend your savings as well - good luck and thanks for commenting... cheers, jake
kiwi_fella says: Sep 17, 2009. 4:03 AM
Legend!... What a neat little trick - im sick of paying these big greedy companys loads of money for something i need to do daily. As a side note - i recently got tired of butchering my face with my old gillette sensor (old school 2 blade) - after 2 shaves with a new blade it whould cut me every time, so not knowing if it was the blade or the chemicals in the shave foam attacking my skin, i changed both... so i bought the new schick razor & an organic shave gel (www.primalearth.co.nz, its NZ made, but im sure the US & UK would have something similar (ensure its "paraben" & "sulphate" free) The best thing i have done is started to use a "pre-shave" oil - either buy an overpriced one, or simply mix 50:50 'olive oil' with 'castor oil' and rub 5-6 drops into beard a couple mins before you apply shave gel (some people only use oil to shave with, i still use shave gel over the top) - The castor oil is an emoliant, it absorbs into the beard & softens it. - The olive oil adds a great slippery barrier to the skin, and both are great for the skin... smoothest shave i've ever had! And now with your tip for sharp blades... it'll be even smoother :-)
jakerobinson (author) in reply to kiwi_fellaSep 17, 2009. 8:30 AM
Awesome feedback... thanks for taking the time to offer this great idea! cheers,
chamunks says: Sep 12, 2009. 4:49 AM
I use a double edge safety razor to avoid using these money holes. But when I'm using my blades instead of just blowing the water off after wet-shaving, I will dip the blade itself in some Mineral Oil to prevent oxidization. Mineral Oil is also good for your skin granted the small layer you'll get on your blade wont treat you're whole face, It will possibly make up for that dissolving aloe/vitamin E strip they have on those fancy jobs of yours. Though I really enjoy the shave with my safety razor after hearing the confidence in your voice over this trick. I might dig that 6 blade thing sitting in the bottom of one of those boxes I have in storage to give it a try. I think its called a gillette something or other.
bitterbug in reply to chamunksSep 17, 2009. 3:46 AM
I switched from shaving with water and shaving gel to using Vaseline Intensive Care lotion, and it works great. I assume any other similar hand lotion will work just as well. It doesn't just give a layer of moisture for the blade to traverse. It softens the whiskers too. And I've found that my skin suffers less trauma and is already moisturized when done :) Thanks for the honing tip :)
jakerobinson (author) in reply to bitterbugSep 17, 2009. 8:29 AM
Thanks for the contribution - great comment!
jakerobinson (author) in reply to chamunksSep 12, 2009. 11:12 PM
Hey Chamunks, thanks for the feedback... I have kept my razor submerged in rubbing alcohol but mineral oil may be a better choice... cheers, jake
chamunks in reply to jakerobinsonSep 13, 2009. 2:10 AM
I am infact trying almost a hybrid of this I'm planning on testing swishing the blade around in 99% usp isopropyl alcohol to get the water off the blade completely first than a quick dip in mineral oil to protect against humidity and leave it on a tray. This might become a bit neurotic but I mean the samurai sword wasn't perfected in a day. one day maybe I will post an instructable for shaving or something. Only as a sum it up of shaving. Without laser hair removal every man and sometimes women will shave for most of their lives. So you might as well enjoy it.
jakerobinson (author) in reply to chamunksSep 13, 2009. 1:09 PM
Post back and let us know how it works...
chamunks in reply to jakerobinsonJul 5, 2010. 1:32 PM
I apologize for taking almost a full year to get back on this.. I had tried for quite some time the combination and it worked great as long as I stuck with it. My main issue is that when I'm shaving I do so in the shower with a defogged mirror so if I don't jump out of the shower to give my razor a quick bath in alcohol than dropping it in the mineral oil the water it wouldn't help all that much. But I think it was my method I used because I didn't have any extra room on the counter sharing it with two other people I couldn't be taking up too much space with all my razor preserving tools. So what I had been doing was pouring alcohol across the blade to rinse it than dropping the cleaned blade into the mineral oil. This turned out to be rather wasteful. Ideally I would do is have two containers, a container filled with alcohol and another container filled with a layer of mineral oil. These would both remain closed when not in use. I would toss my razor into the alcohol bath while still showering than when I get out afterwards take it out and drop it in the mineral oil for storage. I found that the mineral oil is at the base of many moisturizers so using it to coat my razors had turned out to be a decent concept almost like those moisture strips they use on those fancy blades I rarely use. I try to stick it out old school with the double edge safeties. On a side note more related to the main article: I did try this on my fusion blades and it works great you really have to try and preserve those expensive little buggers, let me tell ya a weeks worth of shave out of a 6$ razorblade is obscene. So using this method I can get at least 6 times the extra wear. Long after that so-called "Indicator Strip" is gone! I also did this with some safety blades and it worked out just fine aswell so now I'm using this concept with my safeties and taking my 40cent blades and making them last months lol!! Yep I'm pretty darn frugal.. Its my money I'll do with it what I want to.
jakerobinson (author) in reply to chamunksJul 5, 2010. 3:18 PM
thanks for coming back and commenting... you may want to read back through other comments as there have been many suggestions concerning how to preserve the blade... is there a place to leave a 'shampoo' bottle in the shower? You could put enough minereal oil in a bottle and maybe take the top off (if it's big enough) or cut the top off and just drop your blade back into the bottle of Min oil and leave it in the shower (of course - after you've sharpened it...) cheers, Jake
studebaker26 says: Sep 14, 2009. 5:18 PM
I used this trick this morning, and it worked like a charm. Thanks, you just saved me all kinds of money!
jakerobinson (author) in reply to studebaker26Sep 14, 2009. 6:12 PM
Thanks for you feedback and letting me know you had success! can I ask you a favor? if you like my idea - would you cast a vote for this video for the contest? thanks jake
studebaker26 in reply to jakerobinsonSep 14, 2009. 7:48 PM
Already done, with pleasure.
jakerobinson (author) in reply to studebaker26Sep 14, 2009. 11:43 PM
thanks brother...
shantinath1000 says: Sep 13, 2009. 8:08 AM
I have had the habit of using a blade for three or four weeks before getting rid of it and over time the blade would get duller and the comfort level would go down. I tried this last night with a two week old blade and while I don't think it was as close a shave as when new it was a MUCH smoother shave than yesterday. As far as those lubricating strips go- I just ignore them- they are after the blade and seem to only offer marketing opportunities and nothing else. I think I am going to a local leather repair shop and see it I can get a scrap to try as a strop. This was a great idea and one I will be using for the rest of my life! (really)
jakerobinson (author) in reply to shantinath1000Sep 13, 2009. 1:33 PM
Wow, thanks for the great feedback... I am also interested to see if this will work on a leather stop as I wonder if the blades will make good contact with leather or if because denim is 'softer' and flexible it allows for better surface contact to the blades... let us know your result! Cheers,
shantinath1000 in reply to jakerobinsonSep 13, 2009. 6:26 PM
Actually I was wearing the jeans at the time. I just pulled the fabric tight and set my foot on the edge of the tub. as far as the scrap of leather goes- I will try it with the rough (unfinished) side of my belt tonight.
jakerobinson (author) in reply to shantinath1000Sep 13, 2009. 8:41 PM
Cool... yeah, rough leather should be best... cheers,
shantinath1000 in reply to jakerobinsonSep 14, 2009. 4:33 PM
Tried it with the belt this morning-- worked great- the blade was like new so after shaving my face I shaved my head with it rather than use my electric clippers- took a bit longer but I got to stand under a nice hot shower longer too!
jakerobinson (author) in reply to shantinath1000Sep 14, 2009. 5:54 PM
Great - you are brave! well, i've never shaved my head but sounds good... may have to scrounge up a leather belt... if you like the idea - i will be crass and ask for your vote in the contest! thanks
jeff-o says: Sep 8, 2009. 11:27 AM
What a great idea! I'll have to start doing this, even though I only shave once a week. I've got plenty of old jeans to use, too.
jakerobinson (author) in reply to jeff-oSep 13, 2009. 10:57 PM
Hey jeff-o, thanks for the comment - post back with your results! Tell your friends to watch the video too... thanks
flyingbuttress says: Sep 13, 2009. 9:32 PM
Hey Guys... You hone with leather right? Leather is really just skin right? An old guy taught me this trick 20 years ago... I have bought very few razors since.... Just use your thumb or the pinky side of your palm. Rub the blade upwards with moderate pressure against your skin 5-10 times before and after each use. Have the blades point downwards obviously or blood will be let. Each razor will last 6+ months. Works like a charm...
jakerobinson (author) in reply to flyingbuttressSep 13, 2009. 10:53 PM
Very interesting... makes sense... and i bet ridges from you thumb or palm print help to hone it... thanks for the comment...
suzukisuv says: Sep 12, 2009. 10:34 AM
WOW thanks, illlet you know next time i go shave, i just have same shaver as you do i hope this will work.
jakerobinson (author) in reply to suzukisuvSep 12, 2009. 11:14 PM
suzukisuv, thanks for taking the time to comment - i am sure you will get the same results i do... cheers, jake
daywalker42 says: Sep 11, 2009. 9:19 AM
well here's to you Mr. Robinson.........Jeesus loves you more than you will know.....teeeheee, great -ible, man, thanks for the trick
jakerobinson (author) in reply to daywalker42Sep 11, 2009. 9:49 PM
daywalker42, ha! good one and thanks for the kind words... cheers,
dontno says: Sep 11, 2009. 9:24 AM
I read your "Ible" last night and tried it out this morning. I was greatly surprised at the shave it produced. I do say it was the best shave I've had in quite some time. I am now a convert to the jean razor sharpening method. It Works!
jakerobinson (author) in reply to dontnoSep 11, 2009. 9:48 PM
Hey dontno - Great! you are the first person to actually use the method and then come back to confirm your success - thanks for that! Tell you friends! cheers,
pdesousa says: Sep 11, 2009. 7:23 AM
I buy those blades that have been cryogenicly frozen. ( greatrazors.com ) Then I use a mixture of grape seed oil and almond oil instead of the more expensive stuff mentioned above. Water is the enemy of razors; the oil traces left on the razor help to extend the life. But the denim thing makes it a hat trick! Thanks!
jakerobinson (author) in reply to pdesousaSep 11, 2009. 9:38 PM
Hey pdesousa, neat idea about frozen blades, will have to check it out... i like the tip with oil... i have submerged my blade in rubbing alcohol to eradicate water - and it is definitely the enemy of a sharp blade... thanks for you comments, Jake
kriemer says: Sep 11, 2009. 5:46 AM
This Instructable speaks to the larger issue of "disposeability". Our consumer society, indeed our economy depend on built-in obsolescence to keep ticking; but it hasn't always been this way. I have always found this change of culture to be revealing of who we have become as a people. When the original safety "disposable" blade was first marketed, consumers just couldn't get the hang of throwing away something that should still be good if it wasn't just a bit dull. Many companies filled this void with disposable blade sharpeners some simple, some very complex (nothing new in the product jakerobinson mentions above). I own a bunch of these devices, and I imagine there are many types of these machines I haven't come across. k
jakerobinson (author) in reply to kriemerSep 11, 2009. 9:30 PM
Kriemer, you are correct - there are many products marketed to extend the life of a disposable blade by resharpening it... I didn't care to compare my method with other gadgets as many here will have never seen or heard of some of them... so, the 'fix' i am demonstrating is just the simple method that all gadgets (that cost money) attempt to do... some may work well others are poorly constructed and some are just dubious... So, this method may be known by many - it is not an original idea but it is a valid way to save money, extend the life of a product and reduce waste if this is important to you... thanks for your comments... cheers
bruc33ef says: Aug 20, 2009. 11:38 PM
Nice one; I'm going to start doing this. Another step to reduce shaving costs would be to use shave oil -- super lubricated oil -- sold in very small bottles. It's great for travel and you only need 2 or 3 drops, believe it or not. This should also increase blade life.
nworbekim in reply to bruc33efSep 11, 2009. 12:48 PM
yah, i tried that stuff and i liked it, but in my present financial condition, the oil's a bit pricey, so i started extending it with baby oil, and when i ran out, i tried straight baby oil, it works as well.
jakerobinson (author) in reply to bruc33efAug 21, 2009. 12:13 AM
Hey, great idea.. can you get this at a drugstore or say, Wal-Mart? thanks for this...
bruc33ef in reply to jakerobinsonAug 21, 2009. 4:28 AM
I get it at CVS in the shaving section. I've seen two brands there (I don't remember the names), but one brand I've seen recommended is Somerset.
drnorwood in reply to bruc33efSep 11, 2009. 5:54 AM
King of Shaves is one brand of shaving oil and I found it at Wal-Mart. For me, it does not seem to do as well on fine stubble (like the day after a good shave). I also notice I have more stubble at the end of the day after using it instead of shaving cream. This may partially be because I use a Gillette Fusion blade. I get a closer shave all around with my old twin blade Gillette Atra. However, I do use the King of Shaves a couple times a week and for travel - no fuss, no muss.
jakerobinson (author) in reply to bruc33efAug 21, 2009. 11:52 AM
Thanks for that... btw, if you find this video has value please share it with your friends online... cheers, jake
creativeaddress says: Sep 8, 2009. 2:57 PM
A friend told me that he was talking to the ad department at Gillette and they said they never advertise as to how often to replace a blade. This means the blades last longer than they are normally used. So I have been using the same blade since November 2008. Facial hair can be 'trained' and you get used to a duller blade but still a close shave. Still works great.
Sparkplug in reply to creativeaddressSep 10, 2009. 10:32 PM
I just recently saw a commercial for the Fusion razors that points out a small "indicator strip" that tells you when to replace the blade.
jakerobinson (author) in reply to creativeaddressSep 8, 2009. 3:07 PM
hey, great comment... maybe you can 'train' your blade back up to a sharper edge too!
notwen says: Sep 10, 2009. 2:26 PM
I've enjoyed the safety razor shave for years. Two things the old Rolls Razor had built-in strops and were/are great. But I can't remember the source, double-edged blades can be 'honed' by inserting them into a glass tumbler and using a finger to apply light pressure and flex the blade, then slide the blade to strop or hone it.
jakerobinson (author) in reply to notwenSep 10, 2009. 9:34 PM
hey notwen, i appreciate the feedback and the tip... cheer,
captainjamescook says: Sep 10, 2009. 1:57 PM
I have a Tip for you. If you practice a little you can shave with the old razor blades. I'm talking about the blades you can change and keep the razor. Use one for about 1 month or even with the jeans method 6 month and pay nearly nothing. the key is the technique. First shave top bottom second shave bottom up. And always use shaving cream, conditioner or ..... shaving soap. With shaving soap you get much much more value for money and if you have a nice brush you will feel the difference. cheers
jakerobinson (author) in reply to captainjamescookSep 10, 2009. 9:32 PM
Hey cap'n cook - thanks for the feedback - i agree with your suggestion up up then down stroke... might have to try shaving soap as well... cheers
bairdwallace says: Sep 10, 2009. 1:21 PM
I sometimes soak the blade in white vinegar, to knock off any mineralization that builds up after a few shaves. I'm also a fan of conditioner in lieu of shaving cream, although sometimes it is nice to get a good lather in a brush and really work it in.
jakerobinson (author) in reply to bairdwallaceSep 10, 2009. 9:30 PM
Baird, great suggestion! and thanks for the comment... we might have to start an ebook for a 'shaving system"'! and i like the hair conditioner idea as a shaving medium... thanks for this... cheers
locofocos says: Sep 9, 2009. 8:02 PM
When you run it across the jeans, is the sharp edge pointing in the direction you're moving it or away from the direction of movement?
jakerobinson (author) in reply to locofocosSep 9, 2009. 11:00 PM
Hey Loco, you run the blade away from the sharp edge... otherwise your jeans would enjoy a close groom! if you notice in the video - I'm 'pushing' the razor away...when you sharpen a knife you typically run the blade on the sharpening surface as if you were going to cut it... but once you have a good edge on a blade, then you 'fine hone' it by dragging the edge of blade away in the opposite direction - this tends to knock off the fine burrs that may be on the blade for a really sharp edge... we are just skipping to this step with the razor blade as it is very fine edge to begin with...
BennyMelb says: Sep 9, 2009. 7:03 AM
Great Instructable, I'll be trying this out. I've also found that using hair conditioner as an alternative to shaving cream gives me better results when shaving. Cheers
jakerobinson (author) in reply to BennyMelbSep 9, 2009. 8:57 AM
Wow, never heard of that! i'll have to give hair conditioner a try... thanks for the great comment & feedback...Jake
chipf in reply to jakerobinsonSep 9, 2009. 9:37 AM
My girlfriend introduced me to this and I haven't bought shaving cream since.
madwilliamflint says: Sep 8, 2009. 11:02 AM
The cost of these things is absolutely demonic. Some being upwards of $2.50 each. I actually switched to using a safety razor a few months ago because I just couldn't justify it. (Which I'm now used to and enjoy a bunch.) The blades are $17 for 100 and one will last me about 2 shaves. (So... a week if I'm unemployed, 4 days if I'm not ;) But I'll take the plunge and give this a shot. Looks like it could work really well. very nice.
jakerobinson (author) in reply to madwilliamflintSep 8, 2009. 11:30 AM
Thanks for the feedback.. and yes, it will work on the really inexpensive types too... i wonder how far you can extend a pack of 100! call me back when your finish the last one... when you 80! cheers,
madwilliamflint in reply to jakerobinsonSep 8, 2009. 12:16 PM
Ya know, I almost think it might work better on the single blades. I'll give it a shot over the next couple days and let you know.
yanni50 says: Sep 8, 2009. 11:59 AM
Thanks for your tip. Those companies are making a killing of the blades, any tips which sticks it right to them is appreciated. The other rip offs are electric toothbrush heads, inkjets, laser toners... the list goes on and on. Would be great to get an instructable on how to extend the life of my electric toothbrush refill as well :)
quantumz says: Aug 20, 2009. 10:29 PM
Thank you for this. It pains me to spend so much money on Gillettes every month, but I cut my face up terribly when I buy the cheapo razors. Does this damage the jeans (esp after 6 mo of sharpening)? Should I do this on an old pair of work pants or just use the jeans I'm gonna be wearing that day?
iectyx3c in reply to quantumzSep 3, 2009. 6:47 AM
It doesn't seem to damage my jeans, but do notice that Jake is stropping AWAY from the cutting edge, so it is not like you are shaving the jeans. I am using it with the el cheapo orange handle BIC razor and 99 cent (on sale) Barbasol sensitive skin aerosol shave cream, which usually would cut me up like burger, and it seems to work great. Also I use a hair dryer to dry off the blade after shaving.
jakerobinson (author) in reply to iectyx3cSep 3, 2009. 9:28 AM
Hey Bruce, thanks for the imput - very good comments... I do strop away from cutting edge... And using the hair dryer will make the blade last a lot longer... rust is the enemy of a disposable razor.. I haven't thought to calculate how much it may cost to run a hair dryer each time - you know someone will figure out the add'l cost factor... can't be more than new blades tho!
jakerobinson (author) in reply to quantumzAug 20, 2009. 11:14 PM
Thanks for your comment... I haven't noticed any damage to the jeans... but they are a knock around pair... if worse comes to worse you could go to a local thrift shop and buy a cheap pair just for this purpose... or a yardsale/garage sale... I haven't noticed any change in the appearance of my jeans... The one down side is the 'gel strip' which helps 'lubricate' the blade against the skin will wear away... i have not sacrificed any quality in shaving... as long as you are lathered up it should not effect your results. If you believe this has merit share it with your friends online! Thanks, Jake
hishealer in reply to jakerobinsonSep 8, 2009. 1:36 PM
That strip is a joke anyway! No matter how good it is, it is going on AFTER the blade does its damage. The shave cream or gel or whatever does lots of good conditioning the skin BEFORE the blade scrapes its way across your tender skin. Not to mention making the hairs easier to cut.
jakerobinson (author) in reply to hishealerSep 8, 2009. 2:31 PM
appreciate the feedback.. yeah, i wondered about the to.. doesn't make too much sense... maybe is lubricate after you remove the lather? I always splash hot water on my face and then lather up.. then i take my razor and hit the jeans for 20 strokes each way... then run blade under hot water to warm steel up.. by that time i think my beard has time to soften up...
iectyx3c says: Sep 3, 2009. 5:36 AM
$3.50 a week is bizarre consumer madness. Your blue jeans strop is a cool idea. Thanks for saving me money. I have Twittered this so check your 'ible stats for more hits.
jakerobinson (author) in reply to iectyx3cSep 3, 2009. 8:38 AM
thanks for the comment... i'm on twitter... @jaketrobinson cheers,
rimar2000 says: Aug 22, 2009. 4:56 PM
Good work. I have not done that test, but all that is savings or maximize the utility of the things, I think is great.
Jughead77 says: Aug 22, 2009. 3:38 AM
Awesome.
ve2vfd says: Aug 21, 2009. 9:05 AM
This does make a lot of sense as my strop (yes I often use a straight razor) is leather on one side, and heavy woven cotton on the other side. Another trick to make your razor blades last a lot longer is to shave in the shower. The hot water softens body hair and opens skin pores. Shaving towards the end of your shower means the blades are cutting softer hair and not wearing out as quickly.
jakerobinson (author) in reply to ve2vfdAug 21, 2009. 11:56 AM
very true... thanks for that... I shave just after i get out of the shower and I also lather up and then sharpen my razor as the longer your lather is applied the softer your stubble will be... I just never could get into shaving in the shower... Cramer could do it - he prepared his dinner in the shower ;>) if you like this instructable please tell your online friends! thanks
ylujenuj says: Aug 20, 2009. 11:17 PM
How about using old leather belt ... ... I am going to try this for sure ... thanks ...
jakerobinson (author) in reply to ylujenujAug 21, 2009. 12:11 AM
thanks for the feedback... sure, you could use a leather belt... i don't have a leather belt that is not 'finished' - i think raw leather would work better... i like jeans as it is very easy to get 'full' contact on the blades. I also think (just an opinion) that the threads are 'grooved' on jeans so they are slightly raised (like micro-speed bumps) and therefore seems like they can make contact on the blades easier... There is a consumer product advertised on TV that you place your razor into a slot and a 'wheel' with flaps (imagine a wheel with a bunch of mudflaps) that turns and hits the blades... Every review I read suggested that it was not very sturdy and malfunctioned quite easily... plus it cost money... The jeans is just a linear way to accomplish the same thing just without bling!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
