Remove these ads by
Signing UpStep 1Materials
- A cane pole - I bought a 2 piece pole at Wal-Mart for $3.54
- An assortment of small hooks - about $2.00
- Some bobbers or floats, smaller is better- a pack of small ones is about $2.00
- Monofilament line, cheap is fine. Get 10 or 12 lb test - about $10.00
Some country stores may carry long one-piece cane poles, and these are good for serious cane-pole fishing by adults. For kids, I like the ones that come in two pieces and are about 10 feet long when assembled. You simply insert the top end into the bottom end and you are ready to go. Afterwards, they are easily disassembled to put in the trunk of the car.
Bite.
there is a much safer way to hold bluegills. as you can probably tell, they have sharp dorsal spines that can go into your hands very easily.
the best and safest way to hold bluegills is to cup your hand in a "C" shape and wrap your hand around the fish.
you do this by coming in from the front (not the back like you said in the instructable). then, using the outside edge of your thumb, gently push the spines down and at the same time grip the fish with your fingers around the belly.
here is a picture of a nice bluegill i caught. i'm holding it in the way i described above
http://i46.photobucket.com/albums/f120/davidsaavedra/birthdayfishing_0011.jpg
open air), I usually put them out of their misery with a hunting knife through the brain and into a wooden cleaning board.
Also (I skimmed through some of the text so you may actually mention this) but it is important to learn to adjust the bobber and thus adjust the depth of the bait. Different fish swim on different depths at different times, water temperatures etc.
Also, as kids when we did not expect to have anything big, we just carried the line readied with the bobber & weight and made the poles on the spot from tree branches etc. We seldom used dough or bread, we user worms most of the time as dough & bread lure a bit poorer type of fish around here.
I mainly use weight when I want the bait to sit on the bottom - for example, when fishing for catfish at night with a rod and reel and no bobber, etc. I use a 1/4 or 1/2 oz. slip sinker for that, along with either doughball/cheeseball/stinkbait for flatheads and bullheads or cut up bluegills for channel cats.
Cook some fries and you are in for some good eating.
- Salt,
- Pepper,
- Chicken salt,
- Chicken pepper,
- More salt,
- More pepper,
- Chicken,
- Time,
- Thyme,
- Even more salt,
- Even more pepper.
In that exact order.Another way to control a fish is to stick your thumb in its mouth and pinch its lower jaw. This subdues the fish without harming it, forces its mouth to stay open and makes it easier to remove the hook. It also gives a good grip and keeps you from getting "finned".
