How to Fishtail Braid
Published
Introduction: How to Fishtail Braid
Before beginning the procedure have a hair tie near by.
Step 1: Step 1
Separate hair into two even sections using fingers/ fine point comb.
TIP: it is easiest to part the hair directly down the middle, starting at forehead and proceeding down to bottom hair line.
Step 2: Step 2
Pull a thin strand of hair from the outside of the left section. Pull it over the top of the left section, and grasp it under the right section.
TIP: Try to use same thickness with every strand, and by pulling tighter helps you learn the method properly.
Step 3: Step 3
Repeat step two, but pull a thin strand from the outside right section, pull across the right section to weave under left section.
Step 4: Step 4
Repeat steps 2 and 3 until you reach bottom of braid.
Step 5: And to Finish
Tie off the end of braid with near by hair tie.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    So helpful! Thanks!
