How to Fix a Broken Bicycle Pump
Published
Introduction: How to Fix a Broken Bicycle Pump
About: I love to camp,hunt ,fish,bike,canoe or basically anything to do with the outdoors.
This instructable is on how to fix a bicycle pump that has a hose that is cracked at the base. Hope it is useful to you. Pease like comment and vote!!
Step 1: Tools and Materials
Well this is The pitiful list of tools and materials:) 1 Broken bicycle pump
                                                1 Utility knife
                                                1 Flathead screw driver
                                                1 Tiny hose clamp
Step 2: Remove and Cut Hose
All you have to do here is pull the hose off then cut off the cracked section. A picture says a million words :)
Step 3: Attach the Hose and Clamp
First thing to do here is slide the hose clamp (pre tightened to the size of the hose) over the hose and shove the hose onto the hose barb (the pointy thing you pulled it off of). Then making sure the hose covering is under the clamp start tightening the clamp (over the barb). Once again a picture says a million words :)
Step 4: Fill Something With Air
Now you are all done test it out and then fill somthing with air for example a car tire,a bicycle tire,a tree e.t.c. Hope this was useful to you and once again Thanks for reading!! Please like comment and vote!!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    6 Comments
    how to fix if its the other end thats cracked? thats what I need.
    Same idea to repair the other end. But you need that original metal piece/fitting that was attached to the hose. 1. Cut off the hose at the damaged section and slide that tiny round clamp onto it. 2. Remove the other end of the damaged hose, (now cut off), from the fitting. It should have a barbed end onto which you can slide your good hose onto and clamp it.
    Good fix! The barbed end had a compression clamp and I cut it off using a dremel tool. The rest was exactly as you described.
    Yep it works good with any type of hose!! Thanks for commenting!!
