Introduction: How to Fix a Broken Bicycle Pump
This instructable is on how to fix a bicycle pump that has a hose that is cracked at the base. Hope it is useful to you. Pease like comment and vote!!
Step 1: Tools and Materials
Well this is The pitiful list of tools and materials:) 1 Broken bicycle pump
1 Utility knife
1 Flathead screw driver
1 Tiny hose clamp
Step 2: Remove and Cut Hose
All you have to do here is pull the hose off then cut off the cracked section. A picture says a million words :)
Step 3: Attach the Hose and Clamp
First thing to do here is slide the hose clamp (pre tightened to the size of the hose) over the hose and shove the hose onto the hose barb (the pointy thing you pulled it off of). Then making sure the hose covering is under the clamp start tightening the clamp (over the barb). Once again a picture says a million words :)
Step 4: Fill Something With Air
Now you are all done test it out and then fill somthing with air for example a car tire,a bicycle tire,a tree e.t.c. Hope this was useful to you and once again Thanks for reading!! Please like comment and vote!!
Fix It Contest
Great Outdoors Contest
Bikes and Wheels Contest
