Remove these ads by
Signing UpStep 1: Got radio?
Plugging in an old vacuum tube radio thats been sitting for years will usually result in bad times. You might let out the magic smoke (burnt component), damage tubes, short stuff out, trip your house breaker, or maybe even catch fire. Think I'm kidding? Read on and I'll walk you through a little radio history and some electronics lessons.
Visit Our Store »
Go Pro Today »
this is an old radiomans trick
if your radio doesn't have set screws and the knobs wont budge your going to have to turn the radio so the knobs are facing down. take a can of wd40 and use the straw to get a shot of wd40 onto the knob shaft. let it sit a while. it should break free.
if the speaker is ok, my next target would be the output tube. its consumable and does wear out. the good thing is that most output tubes on table radios are not expensive. there's plenty of types of output tubes used but google is your friend here. google search each tube number. the one that comes back as "audio amp tube" or "beam power tube" or "audio output tube" or something along those lines may be your culprit. you can usually find radio audio tubes as New Old Stock on ebay for just a few bucks.
If the voltage of the filaments did not add up to 120 or 220 V (used outside the US), the manufacturers added a resistor for extra voltage drop. In many cases, to save space and reduce internal heat, such resistor was wound inside the power cord, which made it warm to the touch when the radio was on.
The safest way to work with a "Five" is to use an isolation transformer (1:1) of the right volt amp rate (around 200 VA). This way, none of the power cord wires would be related to ground and it would be possible to touch the chassis without a 50/50 chance of getting electrocuted.
they are usually cheap and can be found at antique electronic supply
turn radio on in a dark room and keep an eye on the tubes. if the large metal cylindrical structure in the tube slowly begins to glow orange after maybe 5-10 minutes of use you may have an out of spec resistor. keep in mind im not referring to the filaments of the tube, those are supposed to glow.
make sure your antenna is ok. a broken antenna loop will cause lousy reception.
a worn out output tube will cause low audio. listen closely to the radio. if it sounds good at low volume but just wont play very loud before distorting, you may have a worn out tube. most small radios used 25L6, 35L6, or 50L6 output tubes.
get back to me here and let me know what you find.
you mentioned that when you put your hand on the antenna you get lots of static. many old radios used loop antennas. the antenna has at least two wires, sometimes 3 or 4. whatever wires it has they must be hooked up, if not the radio will pick up lots of random noise at stations will be drowned out.
you can check the loop antenna by disconnecting it and measuring continuity with a meter. its rare but sometimes rough handling causes one of the wires to break in the loop.
I would suggest checking resistors while you're going about replacing capacitors. The resistors used in those old sets tend to drift upward in value as time passes and this will affect bias voltages on tubes.
It should also be mentioned that service data for these old sets were published by two companies- Beitman and Rider. Their multivolume radio service manuals can be found in many public libraries. The manual pages usually have full schematics, tube pin voltage levels, and tune-up instructions. Scans of Rider's manuals are found on-line here:
http://hertzmail.com/riders-vols/
If you want your own original set of the manuals or DVDs full of scans you can check ebay.
