I was given a kayak but it had six cracks in the hull and would eventually take on lots of water.
I had two options: scrap it or repair it. It didn't cost me anything, so I thought I'd try to repair it.
Is it possible to make a permanent repair using a drill, cloth tape and a hair dryer? Yes - it really does work!
I've made a few river trips in my repaired kayak and there are no leaks.
Remove these ads by
Signing UpStep 1Materials needed
- A drill with a very fine drill-bit
- A reel of fabric tape - this is also known as duct tape, cloth tape or gaffer tape. It's a flexible self-adhesive tape reinforced with a cloth mesh. It's quite cheap and easily available.
- A hair dryer or hot air gun.
- A marker pen
Mark
The trick is the heat - I applied it on a warm day and was sure to apply lots of heat using the gun.
It's been on for two years and still no leaks, after lots of flexing on stones and shallow rivers ;)
Easyliving's suggestion sounds like the best way to go to effect a permanent repair.
The kayak was free - it was going to be scrapped, but I'm still using it and it doesn't leak!
It's such a cheap and easy thing to do, it's worth a try.
However, to make a better color matched repair, I've looked around and found plastic containers the color of my kayaks, to use for my repairs and modifications. NOTE: Plastic container must have a recycle triangle, with HDPE , which stands for High density polyethylene..
Cut off a piece to use instead of the black welding rods, that's provided in the kit... I recommend practicing on scrap poly container first... Cut the container, then repair it, with a piece of the scrap plastic container.
Basically , work slowly heating the damaged edges of the break, don't melt all the way through your kayak.. Be gentle, let the tool do the work... You just want to melt the surface enough to work the wire mesh into the softened damaged area, for reinforcement... While it's still hot and soft, hold the scrap poly against the welding tip, melting old and new poly together, to completely fill cracked area. When you have plenty of melted poly, smooth it out with the spoon shaped bottom of welding tip... If you don't get it right the first time, reheat it a little and smooth it out again....
You can also use the spoon shaped tip to smooth out deep scratches on the hull and to make any modifications you'd like on your kayak.
I'm getting ready to convert my kayaks into optional sailing kayaks! Adding Sails, Masts, rudders and outriggers. I plan to drill a mast hole through the hull, and weld a poly pipe, into the hollow of my Sit on top kayak's hull. I've ordered some kayak deck plates. I think by adding deck storage holes, I will be able to work throught the deck plate hole to weld inside the hull! I plan to reinforce the Mast pipe base, by welding it to the inside bottom of the hull... Wish me luck..
I've always wanted to sail, Now I'll have the chance.
West System G-Flex Epoxy is great for the Kayaks material,
bonds good, A small repair kit is under 25.00,
1-1 ratio for easy mix and is compatible with fillers.
and fibreglass fabric.
