loading
Step 4: Heat the area to be repaired
ALL THE FOLLOWING STEPS ARE DONE ON THE INSIDE OF THE KAYAK OR CANOE.
Heat the repair area.
Use a hair dryer or heat gun to heat the kayak (or canoe) plastic so that it is hot to the touch. If you are using a powerful heat gun, be very careful not to heat the plastic too much.
Wow, Why don't you save your duck tape (brand) or duct tape (purpose) for a red-neck Tux-C-Doe and use one of the many proper repair procedures. You don't want to be 2 days from home when your duct tape gives out with no hairdryer to fix it again. Try plastic welding or a proper epoxy as stated above. To me for the best repair, use Tear-Aid tape. When this stuff sticks, this stuff won't come off. It is also supper scuff resistant. Personally I've used it on Awnings and inflatables. This product is also recommended when repairing Zodiac boat tears. No seven layers of duct tape when it counts. Is it worth your life or ruining a kayak trip if your boat takes on water?
Wow, a bit harsh...
What a great Instructable! I am now thinking about picking up a damaged kayak for cheap and repairing it.
What type and brand of tape did you use? Most &quot;Duck&quot; tape has an adhesive that slowly yields and leaves almost indelible white tracks, though perhaps the heat would make it set solid...<br><br>Mark
I used a no-name tape. As it happens, the glue on the tape was nice and tacky.<br><br>The trick is the heat - I applied it on a warm day and was sure to apply lots of heat using the gun.<br><br>It's been on for two years and still no leaks, after lots of flexing on stones and shallow rivers ;)
I have a hard time seeing tape a permanent repair. I'd consider it a emergency fix until you can get something solid done. <br><br> <br><br> <br>Easyliving's suggestion sounds like the best way to go to effect a permanent repair.
I hear what you say, but it really does work. The secret is the use of a heat gun.<br><br>The kayak was free - it was going to be scrapped, but I'm still using it and it doesn't leak!<br><br>It's such a cheap and easy thing to do, it's worth a try.<br>
Gorilla Tape is available at Home Depot and other places as well. It is super strong with a violently strong glue.
I have a sit on top type kayak that has a tiny hole near one of the drain holes due to scraping over rocks in rivers. Can I use this tehnique to fix the hole or do you have any better ideas for fixing small hole? it is not a crack but more of a scraped hole.
Hi, I've got&nbsp;Sit On&nbsp;Top&nbsp;kayaks also.&nbsp; Most&nbsp;are made of polyethylene, and are&nbsp;easily repaired.&nbsp; You can use any tool that will melt the polyethylene, to make the needed repair, but&nbsp;Harborfreight.com sells a 80 watt plastic welder, for $15.00. Included is&nbsp;&nbsp;Wire mesh to reinforce the crack, along with poly welding rods...&nbsp;<br /> However, to&nbsp;make a better&nbsp;color&nbsp;matched repair, I've looked around and found plastic containers the color of my kayaks, to use&nbsp;for&nbsp;my&nbsp;repairs and modifications.&nbsp;&nbsp; NOTE:&nbsp;&nbsp;Plastic container must have&nbsp;a recycle triangle, with&nbsp;HDPE , which stands for High density polyethylene..<br /> Cut off a piece to use instead of the&nbsp;black welding rods, that's provided in the kit...&nbsp;I recommend practicing on scrap poly container first... Cut&nbsp;the container, then repair it, with a piece of the scrap plastic container.<br /> Basically , work slowly heating the damaged edges of the break,&nbsp;&nbsp;don't melt all the way through your kayak..&nbsp; Be gentle, let the tool do&nbsp;the work...&nbsp; &nbsp;You just want to melt the surface enough to&nbsp;work&nbsp;the wire mesh into the softened&nbsp;damaged area, for reinforcement...&nbsp;While it's still hot and soft, hold the scrap poly against the welding tip, melting old and new poly together, to completely fill cracked&nbsp;area.&nbsp;&nbsp; When you have plenty&nbsp; of melted poly, smooth it out with the spoon shaped bottom of welding tip... If you don't get it right the first time, &nbsp;reheat it a little and&nbsp;smooth it out again....<br /> &nbsp;<br /> You can also use the spoon shaped tip to smooth out deep scratches&nbsp;on the hull and to make any modifications you'd like on your kayak.&nbsp;&nbsp;<br /> &nbsp; I'm getting ready to convert my kayaks into optional sailing kayaks!&nbsp;Adding &nbsp;Sails,&nbsp;Masts, rudders&nbsp;and outriggers.&nbsp;&nbsp;I&nbsp;plan to drill&nbsp;a mast &nbsp;hole through the hull, and weld a poly pipe, into the hollow&nbsp; of&nbsp;my Sit on top kayak's hull.&nbsp; I've ordered some kayak deck plates. I think by adding deck&nbsp;storage holes, &nbsp;I will be able to work throught the deck plate hole&nbsp;to weld&nbsp; inside the hull!&nbsp; I plan to reinforce the&nbsp;Mast pipe base, by welding it &nbsp;to the&nbsp;inside&nbsp;bottom&nbsp; of the hull...&nbsp;&nbsp; Wish me luck..<br /> I've always wanted to sail, Now I'll&nbsp;have&nbsp;the chance.&nbsp; <br />
<br /> West System G-Flex Epoxy is great for the Kayaks material, <br /> &nbsp;bonds good, A small repair kit is under 25.00, <br /> 1-1 ratio for easy mix and is compatible with fillers. <br /> and fibreglass fabric.<br /> &nbsp;<br />
You might want to try silicone sealant if it's a small hole and there's not too much flex at the point of repair. I've got a sit-on-top kayak too, and I know the plastic is a lot thicker, so the silicone is less likely to flex and pop-out. It can't do any harm, anyway!
<br /> &nbsp; West System G-Flex Epoxy is great for the Kayaks material, <br /> &nbsp;bonds good, A small repair kit is under 25.00, <br /> 1-1 ratio for easy mix and is compatible with fillers<br /> <br /> <br />
I wish I had a kayak to fix =[<br/>
Seconded.
I've used this in years past and it works really well (I used a spoon to press/iron the tape). That bridge looks familiar. Where's the river?
Wow, thanks. I was curious how hard it is to fix cracks in kayaks. I've seen several for sale that needed some repairs. :|
very good instructable nice to see something repaired rather than dumped. if the cracks are visible on the outside or very large you might consider drilling a series of holes on either side of the crack and stitching it up with copper wire.{some silicone or goop could be used to seal the whole thing} though it might spoil the look somewhat a layer of gaffers tape on the outside would help also.
About This Instructable
224,442views
17favorites
License:
More by jinnan_tonnix:How to fix a plastic kayak or canoe Budget Chopper Bicycle
Add instructable to:
