How to make an arduino power supply
Picture of How to make an arduino power supply
what you will need...
a few alligator clamp wires and a plug for your Arduino, an Arduino, cell phone adapter from the wall to the outlet i will show you how to make . This project should take under 5 minutes to build.
Step 1: Make an arduino power supply
Picture of make an arduino power supply
 I used an ohm meter to figure out which wire goes to the center contact which is positive and labeled it. Label the other wire negative. I stripped the wires from an old cell phone charger. Then I put my meter to DC volt and labeled the wires and connected positive to positive and negative- negative.
lemonie2 years ago
What sort of caulking, what if If the hole is smaller than 1/16 of an inch?
L
jbaker22 (author)  lemonie2 years ago
(removed by author or community request)
Would you make the hole bigger to fix it if it was less than 1/16 wide?
L
Ranie-K2 years ago
Have you tried this?
jbaker22 (author)  Ranie-K2 years ago
yes it worked well.
drew.adc2 years ago
Please don't take this as rude, but why would you not just buy a new tube or a patch kit. A tube costs ~$6, a patch kit ~$3. The patch kit will have several patches, so in the long run it will probably come out cheaper and more reliable.
jbaker22 (author)  drew.adc2 years ago
If you have an open container of it it won't cost anything it will eventually go bad.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
