loading
Step 5: Connecting Directly to the Modem
If you are using a router which seems to be connecting properly but still cannot access the internet, the problem may be that it is not adequately providing the signal to your computer.
1. Unplug the end of your ethernet cord from the back of the router and plug it directly into the computer.
2. Open up the command prompt by bringing up the "Run" menu (Windows key + R if it is not in your start menu) and typing "cmd"
3. Type into the command prompt "ipconfig/release" and wait a few seconds.
4. Type into the command prompt "ipconfig/renew." You should see a new set of values come up.
5. Test your connection one last time.
If you were now able to connect, your problem may have been an issue with your router. Contact the tech support for your router to determine what needs to be done to resolve the issue. If you still cannot connect, proceed to the final step.
<p>i had the same issue with my internet last night . try rebooting the router and check the modem connection . the cable which is coming from modem to router unplug the cable from router and connect with computer and reboot computer and modem and see if the modem is working . checkout this blog if you have issue with wireless connectivity <a href="http://fixingblog.com/windows-laptop-wont-connect-wireless-router/" rel="nofollow">http://fixingblog.com/windows-laptop-wont-connect-wireless-router/</a> . see if this all works thanks </p>
Whatever case, since I am an electronics technician one day I will make it.
About This Instructable
99,581views
21favorites
More by edbob21:How to fix an internet connection
Add instructable to:
