If in first case we can help ourself with clock generator, then in 2nd and 3rd cases bring uC back to life is impossible with standard serial programmer. Most of people do not decide to build parallel programmer because its inconvenient and its cheaper and faster to buy new uC.
Project site - how to fix AVR fusebits
Remove these ads by
Signing UpStep 1Sockets
This circuit use the high-voltage parallel and serial programming method. Atmega8(doctor) has saved in it’s memory signatures of 96 (so far) AVR Atmega and Attiny uC’s, just put your dead avr in socket, press the START button, and enjoy your good-as-new processor.
There are three slots on board, for most common AVR’s, pins compatible with: DIP28 Atmega8, DIP20 Attiny2313, and DIP40 Atmega32 compatible processors.
There is also an extra goldpin connector with all signals so you can attach adapters:
-the "#1 HVPP adapter" with DIP20-B Attiny26 and DIP40-B Atmega8515 compatible
-the "HVSP adapter" for tiny DIP8 Attiny13 and DIP14 Attiny24 compatible.
-your own adapters for other types of processors, in trough-hole or surface-mounted, you can use the breadboard for this – just connect signals to correct pins. How? Check your AVR datasheet, go to “memory programming” and then “parallel programming” – check the signal names, all signals are described under the DIP40 slot.
under $30, not worth to build one yourself.
The sotware size is to big to flash memory ,ATmega8 ,12Kb .
Exemple :
atmega_fusebit_doctor_2.01_BETA.HEX = 21KB
atmega_fusebit_doctor_2.09_m168.hex =31 KB
If use first-release-03-05-2010 ,the microcontroler ATmega 8 is blocked !!
i d'ont recomand to test this softawre ,only scop of autor is to damage your microcontroler !!
Be carefull !!
600 comments on project site are also faked?
And BTW, 2.11 firmware and 2h PCB are available, it seems that there are no more bugs at all :) Version 2.1x brings new feature, you can send your own fuses etc to uC trough terminal.
It supports 145 chips now.
Also, PCBs will be available to ship worldwide :)
Sorry for not posting news here, got no time :(
Also, to be up to date with updates - http://twitter.com/manekinen
