How to fix sound in electronics that fell in water
 by TheMacyC
Featured
Almost a year ago, water fell into my ipod and the sound wasn't working anymore.. i could hear sounds when i plug my earphones, but i can't hear anything without them !!
later then, my aunt told me to put my ipod in rice for a couple of days.. i didn't think it would work since many people pay $20-30 to have the sound on their devices fixed, but i thought that i should give it a try ! and guess what? it worked.. it actually worked ! later that year, my best friend's brother's ipod fell in water and it wasn't working plus the screen broke.. the rice method that i told her about worked and all her brother had to do was replace the screen which was a lot cheaper than replacing the whole ipod ! so that means that the rice absorbs the moisture and it fixed both the sound or the ipod..
ps: this doesn't only work with ipods it also works with phones...
pss: if this method doesn't work you will have to take it to an electronics store and they'll fix it for ya !
Step 1: What you need
You'll need:
- Your device
- Rice
- Bowl
- Couple of days
momoluv says: Apr 2, 2013. 8:44 AM
This doesn't work
TheMacyC (author) in reply to momoluvApr 15, 2013. 11:04 AM
It doesn't always work, you also might have left it for little time in the rice... another thing is that the damage might be way too bad for rice to fix it.
It doesn't hurt to try though!
Phil B says: May 22, 2012. 8:58 PM
Surprisingly, after you remove the battery (and before you ever power it up to see if it still works), soak the device in distilled water to wash away trace minerals that short out tiny circuit pathways. Then dry the device thoroughly. When dry, insert the battery and try the device.
TheMacyC (author) in reply to Phil BMay 24, 2012. 6:03 AM
:D
tanarad says: Apr 20, 2012. 8:52 PM
this doesn't work, if rice absorbed water when left out you could cook it by leaving it out on a humid day. a better way is to put the broken piece in a kiln and let it dry out that way
nanosec12 says: Mar 2, 2012. 7:01 AM
It helps a little if you mix the rice up every day....just swirl it around a bit and it goes a little faster.
And this should be obvious, but you need to use 'uncooked' rice : )
GASSYPOOTS in reply to nanosec12Mar 24, 2012. 1:16 PM
D: i used cooked
TheMacyC (author) in reply to GASSYPOOTSApr 3, 2012. 8:15 AM
Really ?!
TheMacyC (author) in reply to nanosec12Mar 2, 2012. 10:17 AM
Of course I used uncooked rice ! It would have made it worst !
Thanks for your advice :)!
nanosec12 in reply to TheMacyCMar 2, 2012. 11:20 AM
LOL, I know you did I could tell from the pictures, I was making a funny (and pointing it out for those that might have been unsure)
TheMacyC (author) in reply to nanosec12Mar 2, 2012. 11:50 AM
I was pretty sure you meant that and I also wanted to make sure they know that !
dps john says: Mar 2, 2012. 1:47 PM
With an electrical device if you can remove the battery do so before putting it in the rice and do not be tempted to use a hair dryer. It will work but not in all cases.
TheMacyC (author) in reply to dps johnMar 2, 2012. 11:00 PM
Thanks for the advice :)!
Someone else told mr to remove the batteries before, but there was no way I could remove them from the iPod so.. Thanks anyway !
sunshiine says: Feb 26, 2012. 8:26 PM
Thanks for sharing this!
TheMacyC (author) in reply to sunshiineFeb 27, 2012. 10:38 AM
I'm glad you liked it :D!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
