3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to fix your swamp cooler ("Overclock" it 50%)
Step 5Remove Spider, Glue it up , Install It again
Cut the zip tie that is holding the spider in place and pull the spider out (keeping track of the orientation) then use the glue that comes with the spider to quickly glue each piece in. Then you will need to glue the plugs in for the other 4 holes that you aren't using. Make sure the tubes are pointing down, because you don't get 2 chances at gluing since it welds the plastic.
Now re-install the spider. I used two zip ties to hold it to the original one. I went around it in an x pattern. You may have better, and cleaner ways to do this but the reality is that the roof was about 105 degrees so zip ties seemed great at the time
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:vatosupreme
