3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to fix your swamp cooler ("Overclock" it 50%)
Step 6Install the pump and supply line and the power connection
Now put the basket filter on the basket, the basket in the water and the pump in the basket. Take the supply line and run it up to the spider alongside the original supply line. (the tubing I purchased tended to kink so I tried to zip tie it every so often to the original to keep smooth curves.) Cut the tubing to length and fit it onto the spider.
Unplug the pump power from the connection and pull that connection out of its mounting slot. I got a grounding splitter to plug both pumps into the power source. (they are now both controlled by the main switch.) I zip tied it to the mounting area making sure that the cords are attched with zip ties and the whole thing is out of the way of the fan, fan belt and the water. You dont want something migrating into one of those areas.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:vatosupreme
