Step 8Improvements and such
My business parnter said that the second pump should only come on when it is over 95 degrees outside (to save electricity) and that I should install a second switch for the second pump.. But I don't want to do the wiring.
so, possibly a wireless switch in the swamper with the other switch downstairs. It would be really cool if you could just get the second pump to kick in when necessary, but that is beyond my techability.
Other ideas might involve adding a unit for spraying the inside or outside of the pads with a sprinkler head. to get better distribution of the water on the pads.
Anyway, hope it works for you .
Hi all,
I live in Melbourne Australia where we have extremely hot and dry summers and as a result I have done a heap of modification and testing of evaporative coolers or Swamp coolers as you call them. My greatest success came from the use of celdex which is the media commonly found in rooftop home /commercial coolers.
It is a specially treated corrugated cardboard which remains rigid, is highly water absorbent, has much greater surface area than aspen and it doesn’t rot and smell like a swamp. The design and angle of the corrugations/ channels forces the air to foil or roll up and down through the material rather than a straight horizontal flow though creating a much cooler and less restricted and more directed airflow.
I recommend being careful about airflow restriction as the motor/fan relies on flow for cooling and not all portable coolers have a thermal cut-out. I would not recommend multiple layers of aspen for that reason. Celdex is easy to cut to fit and is somewhat self cleaning in operation.
Filtration of the water going through the pump and spider is recommended because evaps filter a lot of dust from the air which ends up in the water reservoir and blocking spreader/spider holes. Flywire or fairly fine mesh around the pump does ok.
Bigger or more pumps will help to a point but the main key is the surface area of the media. I get superb performance from my coolers after mods but the only downfall is they use at least twice as much water. But this goes to prove that I am getting at least twice the performance from them as the more you evaporate the more you are cooling. A friend was seriously fooled into thinking they were a refrigerated air conditioners! I think they need float valves connected to the garden hose as I got sick of trying to keeping them topped up. I also experimented with a solar powered evap cooler made by fitting a small cooler with an auto thermo fan and 12 volt bilge pump from a boat running from 80 watt solar panel. One final note is to the importance of both ventilating the moist air from the opposite side of the room from the cooler and providing the back of the cooler with fresh dry air from outside. This helps keep internal humidity down so your sweat can also evaporate. Hope this is a help for all to stay as cool as I and use little or no power to do so.
http://www.bonaire.com.au/evaporativecooling/range.aspx
I live here in Las Vegas Nevada, And this is the first time I've ever seen this type of media. The celdex is very efficient, wets completely, and allows for good air-flow even when salts are built-up. There was the added boon of cutting a 23x23" hole in the wall to install it, as I chose not to mount it in the windo!!!! RRRRRRR!!
I purchased a complete second pump, basket, tubing, and identical spider and essentially "doubled up" the water flow to the pads by zip tying the second spider legs to the first. Now the pads stay wet when the temps are in the 90s, the air smells cleaner and the small amount of extra electricity for the second pump is worth the added efficiency. The guy at the electrical/plumbing shop where I bought everything thought it was an ingenious idea. Kudos to the author!
