3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to format a usb memory stick to FAT!
Hi all!
in this instructable i will tell you how to format a usb memory stick to FAT(not FAT32)
you will need:
USB memory stick(everything under 8gb works)(duh)
computer(duh)
command prompt
Great lets get started
p.s. sorry for low qaulity images i took them with my cellphone
Step 1Step 1
step 1
Put the memory stick into your computer(duh!)
open command prompt ( start > all programs > accesories > command promt.   or    start > run > cmd)
type:
format x: /fs:FAT
PLEASE NOTE X IS WHERE YOU MEMORY STICK IS LOCATED WHERE THE X IS YOU SHOULD PUT THE LETTER OF YOU MEMORY STICK IN MY CASE E ; AND PLEASE DO NOT ACCIDENTLY FORMAT YOUR HARD DRIVE ITS NOT MY FAULT IF YOU FORMAT YOUR HARDDRIVE SO BE VERY VERY CAREFULL!!!!!!!
5 comments
Jul 24, 2011. 9:13 AMchorusofweasels says:
I was hoping you would explain why I would want to format a flash drive to FAT instead of FAT32. What are the advantages?
Sep 12, 2011. 5:57 AMdwathen says:
Some of the classic DOS games don't get along with the modern file systems. I just got done doing pretty much the same thing for a friend because the game couldn't read it's own save files from a FAT32 or NTFS hard drive. I'm sure there are other legacy programs that have the same problems and this makes a handy workaround for those time that you can't use a more up to date program.
Jul 17, 2011. 6:30 PMS33PlusPlus says:
You can't format the system partition while it's still active. I'd be more worried about nuking other detachable storage you might have connected; for example, my old dell has a card reader that maps to E, F, G, and H weather I have cards in it or not, so always triple check the drive letter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Sharky44401
I like making guns and fiddle with computer stuff.
