3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to freeform the bicore ( BEAM robotics )
This instructable is part of the one motor walker.
http://www.instructables.com/id/How-to-build-the-one-motor-walker/
The bicore or suspended bicore is the name given to a little circuit created by Mark Tilden. He is the founder of BEAM robotics. BEAM robotics is an acronym for Biology, Electronics, Aesthetics, and Mechanics.
http://en.wikipedia.org/wiki/BEAM_robotics
quote from Wiki http://en.wikipedia.org/wiki/Nv_network
"Probably the most utilized Nv Net topology in BEAM, the Bicore consists of two neurons placed in a loop that alternates current to the output. Input into the loop is given in the form of changing the resistance in each separate Neuron, which changes the rate at which the Neuron discharges, affecting the pace at which the loop oscilates."
WOW my head! Let me reformulate that for you.
The bicore is a oscillating circuit. In our case, it will oscillate a motor, like the wiper on your car.
The motor will go back and forth, back and forth when power is apply.
Look at this video to understand:
http://www.solarbotics.net/bftgu/starting_nvnet_bicore.html
This instructable was a Flash animation for my BEAM website. You simply follow these instructions.
Step 1The bicore freeform
The bicore freeform
Many thanks to Ian Bernstein from www.beam-online.com
39 comments
Jun 17, 2011. 6:31 PMMCRIPPPer says:
hi. im wondering if the capacitor value is essential? can i use a 0.1 microfarad ceramic cap instead of 0.22??
Jun 5, 2011. 10:55 AMlukeD says:
no programming or software?
Apr 21, 2011. 10:06 PMsaqrock says:
If i am using a 9v battery which Chip should I use instead of 74AC240.
Feb 2, 2011. 10:08 PM101nemesis says:
hey guys.
i got the ic 74hct240.
What i was wondering is that does this ic require any sort of programming or is it pre programed..
thanks..
wicked.sunny.89@gmail.com
Sep 28, 2010. 11:46 AMyogesh99 says:
Hello Sir, Can I use 'SN74LS240N' instead of 74HCT240. I am unable get this IC . Please tell sir,I really want to do this project. Also is their any application of '74HC14B1' IC in BEAM Robotics.
Sep 11, 2010. 10:10 PMPrathameshKini says:
Why is pin number 16 connected to pin number 17?!
Sep 10, 2010. 10:05 PMPrathameshKini says:
I have constructed the bicore circuit. Now I have modify the servo. However I want to know why the servo was chosen over a simple DC motor. And what is the drive current and the sink current of the circuit?
Sep 11, 2010. 12:52 AMPrathameshKini says:
I don't understand. So what if it doesn't have a gearbox. Can I not just glue a circular piece of plastic to the shaft of the motor which will do the same thing as the servo horn and then glue the gear which has been cut in half to that plastic piece?
Also, if I'm using the servo I don't have to remove the plastic tab right? And is 6V input to the terminal okay? Because it says 5V in the bicore tutorial.
Jul 4, 2010. 5:05 AMaviksaras says:
I have made my BICORE.But it is not working.Does the difference in motor cause that.I live in India so can be?the poblem is-it's taking only one round and stoping,don't know why?I have a 9V battery so can that be the problem.i have many questions to ask so please don't be annoid.Please.
Jul 17, 2010. 3:37 AMmattyh says:
Hello, I believe the 74AC240 can only handle 6v max so chances are you've blown the chip. With my playing around with freeforming ive found it usefull to freeform an IC holder as that way any damaged ICs can easily be replaced.
Jul 4, 2010. 5:09 AMaviksaras says:
Hello again,Jerome i have another problem-i have a resistor of some other colour so that could be the prob?only two colours are matching.
Jan 9, 2010. 5:01 PMsalahaddam says:
 Hey I bought a cool BEAM robot like this at
 www.middlecreekmerchants.etsy.com
Dec 9, 2009. 8:57 AMmohankarthik says:
pl help me . i ve finished making d body of d walker . m not getting d control circuit output for two days . pl help me out .
Dec 9, 2009. 8:55 AMmohankarthik says:
hi . m not getting any rotation of shaft after i did this circuit . any suggestionms ?
Oct 7, 2009. 9:33 AMcheverecachaimachochidoche says:
hello robomaniac,
I cant get the 74HCT240, does it have to be a particular kind of IC chip?
can you suggest me another IC chip?
thanks
Sep 1, 2009. 3:02 PMwarpling says:
I've built a two motor walker before, and discovered and built yours many years back! I loved the simplicity of it, why make a master slave using two motors! Anywho I rediscovered your tut here on instructables and I have to say great graphics and I'm excited to try again. I've always wanted to try using a pager motor and cell phone lion battery (with the possibility of a solar charger as a separate project). Think it's possible?
Sep 1, 2009. 6:35 PMwarpling says:
Would an internal gearing system like this be powerful enough?
http://www.hobbyengineering.com/H1705.html
Or
http://www.hobbyengineering.com/H2341.html
Thanks again,
~Ryan
Aug 3, 2009. 4:20 AMderbert says:
i must be getting on your nerves now, huh? take it as a compliment. does it have to be a particular kind of IC chip? i have a MAW2819.4. will this do? it's 20 pin.
Aug 3, 2009. 6:29 AMderbert says:
hmmm. bugger. well, this one came from a remote control, so i'll give it a go. i'll have a look at the robot the control went with too.
Aug 3, 2009. 6:06 AMderbert says:
(removed by author or community request)
Aug 3, 2009. 6:12 AMderbert says:
if my capacitors are .22uf but are the black tube ones does THAT matter?
Jul 18, 2009. 10:31 AMGhost Wolf says:
Question: Do I use a solar cell or batteries? If I do connect a solar panel to it, how do I know that I won't FRY the IC.
Jul 18, 2009. 2:01 PMGhost Wolf says:
Thank you, I just was wondering
Apr 2, 2009. 11:03 AMYashknowsbetter says:
Hey there is an error in the connections...pin no. 17 and 16 are shown to be connected when they are actually not! In other words we are practically connecting i/p of one not gate to o/p of another...thus creating a monostable multivibrator...
Feb 21, 2009. 10:19 PMm3lt says:
Parts list and links to purchase parts would help greatly. Presentation is great, but lack of info kills it.
Jul 15, 2008. 6:02 PMtrebuchet03 says:
Nice write up... Just to point out for others that may not be aware... Windshield wiper motors do not reverse directions - they spin in one direction and drive a mechanism that has the back and forth motion....
Feb 21, 2009. 7:35 AMamando96 says:
they are so powerfull...
Jan 19, 2009. 7:45 AMallenph79 says:
Hey om im a 12 year old guy and i was wondering what parts do you need for all this and can you get them cheap i am working my way up to bigger robots i started with bristle bot then almost done with your beetle bot and my next project is the walker, also i have a schematic for a robot i invented i was wondering if you could help me out with it but you dont have to thanks!
Jul 19, 2008. 6:32 PMitanium says:
very interesting! gratz there
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
239
Author:robomaniac(www.JeromeDemers.com)
I am a French Canadian that loves robots and embedded electronics. I work on all kinds of cool projects, like a high-power electric push scooter controlled with an Arduino. Please visit my website fo...
more »
