Open or load a game, then pause (defaults to ESC or Pause/Break). Type "sv_cheats 1", hit enter, then do the same for "impulse 101" in the console (wi...
Unpause. Use the number keys to select weapons, and press the assigned "left portal fire" key to switch. The Portal Gun is available under "1". On-scr...
There's something even better than this: Use that cheat, but then use the ccommand "Map [ Map Name Here ]", and picking the starting HL2 map. Portal gun in HL2 :D
Here is a mini-tutorial for the "skin" mod in Portal to make Chell dressed in camo. first download this www.fpsbanana.com/skins/53296. then go to computer in the start menu, and go to C:\Program Files\steam\steamapps\(username)\portal\portal. when you get the rar. file downloaded you should see a folder called Materials drag this onto the 2nd portal folder and start up the game! To remove drag the Materials folder to the desktop.
You just don't wanna go into *thirdperson mode or look in a portal with 1 on the floor and 1 on the wall derectly in front of it with grav-gun equipped. Trust me O.O *type in sv_cheats 1 then type thirdperson
I figured out a cheat for the zombies/headcrabs/fast/poison zombies
do the sv_cheats 1 thing then for normal zombie type in "npc_create npc_zombie" (no quotes) for headcrab "npc_create npc_headcrab" (no quotes) for fast zombies "npc_create npc_fastzombie" (no quotes) for poison zombie "npc_create npc_poisonzombie" (no quotes) for the lols type in "npc_create npc_zombine" (no quotes) to rapidly spawn them type bind (letter here) "npc_create npc_(whatever)" EXAMPLE- bind z "npc_create npc_zombie" (WITH quotes)
follow the freeman. Gordon is right on this. it started when half life came out. But i give you credit for doing this. it probably will teach a few how to do this.
There would be generic sounds, such as firing weapons, Combine beeping, and scanners, well, scanning, but as far as talking, no. The classic CP who gives orders to pick up cans is silent, Dr. Breens never ending broadcasts are mute, and citizens are as silent as Gordon himself. But, there's portals! So who cares!
Instead of loading the maps into portal or using garry's mod, there's an easy way to get the portal gun into hl2 and play through the game with it. I, uh, don't remember what it is right now. You open a GCF editor and move a file from portal to the hl2 directory iirc. I'm sure google will help you.
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
There's actually an easier way of accomplishing this step. If you go into the options of any Source game, and under the controls options tab click the Advanced button, you can enable Developer Console. This can then be accessed at any time in the game by pressing the "~" key. Just saying, there's an easier way.
Its actually easier to go to "options" go to the keyboard tab, click on advanced keys or something like that, and check the box that says "Developer console '~'". to access the console, just press ~ at anytime. if u have it on and your in the menu, it will close. also ul need buddha. just type in buddha
I actually just saw that in a magazine... try googling "how to get portal gun in Half Life 2" and it'll bring some stuff up. Basically, you need to use the level editor to import all the HL2 levels into Portal, then play portal (it works because they all use the Source engine).
cant you pause, go to options, go to key board&mouse, click on advanced&click enable developers console, bck out and click apply, tne press the tilda(~)&do the rest from there?
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
LOL!!!
