I have a solution. How about great LEDs that only cost 6 cents a piece new?
Wait until after Christmas and bombard your local hardware store for their "after-Christmas Clearance" sales. You can find strands and strands of LED Christmas lights for 75% off normal, which means you spend about $3 for 50 LEDs. That saves you about $22.5 if you were to buy similar LED's at online retailers. Your LEDs cost you 13% of what they would before. 6 cents for mine vs $1.50 retail.
I like to do things visually, be sure to look at all of the pictures and the image notes for in depth comments and hints to make your life easier and this instructable better!
Remove these ads by
Signing UpStep 1Materials
Supplies:
-LED Christmas lights
-Electrical tape
-Power supply
-2 large coins
Tools:
-Wire strippers
-Scissors
-Time, lots of time......
Im interested in the end project. What did you use to control the leds?
seemed like there was too many leds for the MEGA alone to control?
Did you use some sort of shift register or something?
Thanks!
Great writeup; shame some of the pictures turned out blurry.
Velcro brand hook and loop is one of the best materials for turning a camera into a tripod. You can use anything as a weighted base.
Even if your camera lacks a timer delay for taking pictures, the tripod is totally worth it (and perhaps it would make for a good Instructable... hmm...)
A DC source is one that flows constantly in one direction. If you have them connected to a DC source, the direction of your LED is correct, and the power us under the threshold, they will work just fine.
AC sources are a different story. AC stands for "Alternating Current" which means your current oscillates between a high and low according to a sin wave. If your high is positive, and your low is negative, your LED will flicker on and off with the period of your sine wave. If your high and your low are both positive or both negative, your LED will throb with your sine wave.
Another important thing to know, is that if you should use an AC source for your LED's, make sure to place sets of LED's in opposing direction. The electrons in an AC source move back and forth (which saves energy, read up on Tesla), so you'll need allow current to move in both directions. This actually works in your favor, because your will always have an LED lit.
Quite often, you can find a much better deal on eBay. You can easily locate 100 high quality super bright LEDs in any color for a paltry $5. Five cents a piece isn't bad, but when buying in bulk, such as an order of 500-1000 LEDs, you can get them for 2.5 cents per LED.
Here's an article about what to do when there are no nearby parts suppliers, it lists a few really good supply houses that have more than fair rates.
By the way, where were you looking that listed LEDs at $1.50 each?? That's obscene!
I hope you find some cheaper alternatives for your future ventures, shopping at JameCo and RadioShack will definitely suck up your budget!
I've even done cd backighting with christmas eds.
there is a catch though.
the led focusing lens used for these lights is NOT the normal type.
instead of a normal focusing convex ens shape on the end of the led, many christmas light strings use a conical concave lens.
this makes them sparke nicely, and are easily seen from a distance, but are pretty useess for throwing light any distance.
