How to Get Food, Water and Shelter in the Wild
5,179
68
Posted in OutsideSurvival
Introduction: How to Get Food, Water and Shelter in the Wild
In this instuctable I am going to show you how to get clean water, catch a rabbit for food and build a basic shelter. This could be a matter between life and death or just prepare you for your survival trip. First I am going to show you how to separate clean and dirty water a very simple way. Then I will show you how to catch a rabbit by making a snare. Finally I will show you how to make a simple shelter to protect you from the wild.
Step 1: How to Separate Dirty Water From Clean Water
First find two jars of similar size, next find a piece of cloth.
Fill one of the jars with dirty water but leave a 2cm gap from the top.
Twist the cloth into a rope like shape and dip one end into the dirty water and one end into the empty jar.
I found that if you put the full jar higher up than the empty it will work quicker.
Leave it for one or two hours when you come back the dirty jar will have a sludgy like mixture in and the other will be full of clean water.
Step 2: How to Make a Simple Snare
This is how to make a simple snare to catch rabbits.
First find a 3 ft piece of flexible wire.
Next create a finger sized loop at one end, fix this into place by turning the excess wire around itself.
Put the long remaining part through the loop.
Find a small stick
Push the stick into the ground outside a rabbit run
Tie the wire around this.
Check it every hour as you may cause the rabbit a lot of pain as it will take a long time to die. KILL IT HUMANELY PLEASE.
Step 3: How to Make a Shelter
To build a shelter you should first find two branches with a 'v' shape at one end. Push these into the ground with the 'v' at the top.
Next find a branch that is about the length of you and an extra two feet.
Place this branch into the two 'v' 's.
Next place branches diagonally onto the longer pole on both sides ( look at pics)
Once you have done this find branches and twigs with leaves on and place these ontop of the other branches.
Finally find some big leaves and stuff these into any gaps.
Now you have a fully wind proof shelter.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Outdoor Fitness Challenge
    3 Comments
    I wanna say a few things. First, a bandana doesn't filter out giardia, cryptosporidium, our any organisms. All it does is act as a pre-filter. Some replacements would be a solar still, water purification tablets or a stainless steel cup to boil water. With the rabbit snare, I would rather use a spring or spear snare. They both effectively catch and kill the rabbit at the same time. My favorite, the spring snare, can easily be made by putting the noose onto a bended sapling. If the snare wiggles when the bunny moves it, it will most likely break its neck. I like the shelter, but sometimes a lean-to can be more effective. I say that because with that shelter you can't have access to a fire while laying down, but with a lean-to you can. You can make a lean-to by just taking one side of that shelter off. I would also make a bed of leaves on the grass so you can sleep comfy. Overall, I can see you have put a lot of effort into this instuctable! Good job!
    I agree, but I also like that at least the turbidity of the water is decreased. If you're also using a gravity filter, this will increase the use time between cleanings, and certainly beats the crap out of drinking boiled mud (though I completely agree that the boiling is neccesary)
