3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to get more light out of a single strand of optical fiber attached to an LED
video How to get more light out of a single strand of optical fiber attached to an LED
Very simple stuff, but it has to be seen to be understood.
Fiber optics works because the light moving along the fiber is kept inside it - it is reflected by the shininess of the surface of the fiber. This is "total internal reflection" - or at least for standard acrylic fiber, it's a high percentage of internal reflection, and that's good enough.
Therefore, to get light out of the fiber at any point other than the end, you will have to disturb that internal reflection. A very easy way to do this is to simply crimp the fiber beyond a certain angle, and as you can see, the remainder of the fiber will light up much more brightly.
You have to experiment with each thickness of fiber and each brightness of LED light source, but in general with a good high-bright LED you should be able to bend the fiber about 6 times without losing too much light out of the end of it.
I am using 0.75mm plain acrylic hobby fiber, and a strand of flashing color changing RGB high-bright LEDs.
This is the foundational concept that will allow you to make your own LED fiber projects - especially wearables. I've made cloaks and tutus that light up using this idea. Have fun!
PS if you need to figure out how to get your fiber attached to your LED, look here: http://youtu.be/zTD4xzlwiRU
9 comments
Oct 16, 2011. 9:18 AMbgartman says:
where did you buy your color changing led lights? I'm thinking of a project, but don't have any experience with this type of light. Your Instructable has inspired me :)
Aug 13, 2011. 7:01 AM.Unknown. says:
If you straighten it out again...will it lose the effect?
Cos I want to find an LED replacement for EL wire...
Jul 29, 2011. 11:05 AMPS118 says:
Where do you get your fiber?
Jul 26, 2011. 3:52 PMDoug Paradis says:
Neat technique! I'm going to give it a try. Thanks for sharing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:lukku
