Step 3Whatcha do with your Vista PC
So, you wanna get on Live, but you have a Vista PC. For some dumb reason, Microsoft took out the connection wizard that older versions of Windows have. Don't fret, you can still has your Livez, but you'll need to manually do what the connection wizard does.
I'm going to list what I think worked for me, as I just did a bunch of crap until it worked. If one of the Vista users could comment back and tell me if I'm right/wrong, I'll correct as needed or edit out this "crapshoot" sentence.
First, you'll need to give your Ethernet connection an I.P. address, then you'll tell Vista to share the dial-up connection to any PC/360 plugged into your network. You'll need administrative rights to do this.
Note that if you have any type of pre-existing network set up, you might mess up a connection to it if your IP wasn't manually assigned to begin with.
Right, let's begin. Start by opening Control Panel and clicking "Classic View" on the side panel to keep things simple. Open "Network and Sharing Center", and click "Manage Network Connections" in the sidebar. This will be the window where you'll do everything. You should see the your dial-up connection and the Local Area Connection listed.
Right-click the LAN connection icon and click on "Properties". Highlight "Internet Protocol version 4" and click on the Properties button. Check the "Use the following I.P. Address", and type one in (if there isn't one beforehand, and you weren't connected to any LAN networks, use 192.168.0.1 . It's just a simple one to use). Type in a subnet mask of 255.255.255.0 if it doesn't fill in automatically. Leave the Gateway box and DNS fields blank, and click OK.
Back in the Network Connections window, right-click your Dial-up connection, click Properties, go to the Sharing tab, and check "Allow other network users to connect through this PC."
That should be all you need to do. Again, comment if this works/or doesn't.
Whenever I click the "Allow other network users to connect through this PC" box and click OK a message pops up reading, "Sine your service is currently active, the changes wont apply until you dial back up" then I dial up and dial back on and the changes to the Sharing aren't check!
The same thing happened with the LAN IP Addresses, I type them in and I click OK and the box closes and I go back to it and the changes aren't made! Someone help!
Then Whenever I go to join Xbox Live on my Xbox 360 is has a loading screen for a second or two, but then it says cannot find connection so I click on the button that says TEST CONNECTION and the screen goes blank and it goes to this one screen with two options. Test Wired Connection and Test Wireless Connection and both say I dont have the right equipment.
I know its possible to do this for Vista from AOL Dial Up, so someone be a saint and message me or something telling me how I can fix these massive problems!
