3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to get rid of pimples
This is going over how to get rid of pimples, with simple supplies and no brand named treating medicine. This is very effective. I do not know if this will work on acne, becuase I have been using this and never have had real acne. If you like this rate it.
WHEN DOING this try not to touch your face very much.
Step 1Supplies
Get rubbing alcohol, some bandaids, and a Q-tip.
55 comments
1-40 of 55next »
May 24, 2010. 9:57 PMpaperbagdoves says:
honey under a bandaid usually works for me.
Jan 14, 2008. 5:48 PMacy says:
i wouldn't recommend this tip to anyone (sorry, clamsrule!) because what you're doing is applying a very harsh astringent to your face that will work--but will inhibit the pore from healing. you may end up with bad scars :|
May 2, 2008. 7:50 PMTchalvak says:
I agree. Deal with the source (infection), don't overkill the result (the pimple itself).
I posted this in response to the other RocketScientist2015 instructable, and finding out the information made a big difference to me, so I want to pass it on:
I happened to read a "skin care" book (a heavy duty one by some dermatologist or another) and came across, among all the dietary suggestions, this GEM of information:
Many commercial "anti-pimple" cremes are -inflammatory- agents because they act to dry out the natural oils of the skin and have astringent ( http://en.wikipedia.org/wiki/Astringent ) properties that pucker the visible pimple site's size for a time, but irritate the skin to cause pimples to continue to return (especially cremes with sulfurous drying agents, as I recall).
The advice of the book was, DO NOT USE ASTRINGENT ANTI-PIMPLE CREAMS, they'll clear things up for the short term but make the pimples return long term. USE ANTI-BIOTIC CREME!
After this common sense revelation, I started using Neosporin instead of the anti-pimple creme that I had tried before, and the change over worked wonders, I really recommend it.
Jan 15, 2009. 8:28 PMmadhops0620 says:
I've actually used neosporin on pimples before (i forgot why I tried it) and it seemed to work pretty well
Sep 5, 2009. 12:15 AMkimkim09 says:
where cud i buy neosporin? how much does it cost?
Oct 22, 2009. 12:29 PMtomieboy997 says:
 You can just buy it at your local CVS store or Riteaid or Walgreen's. Also, check the health and beauty section at your local grocery store :) for a half ounce it is about  $6 for one whole ounce it costs about $9
Sep 5, 2009. 7:12 AMmadhops0620 says:
If you live in the U.S you can get it at rite aid, or pretty much any drug store, as well as most grocery stores with a pharmacy/health department. Look for it near the band aidsbecause it is an antibiotic ointment
Jan 19, 2009. 3:49 PMThelonelysandwitch says:
milk of magnesia works very well too.
Jan 27, 2008. 6:25 PMDeLorean4905 says:
now I wonder... perhaps a syringe I shall seek? jk
Aug 21, 2008. 5:47 PMBriguy9 says:
what about putting astringent on a bandaid and putting the bandaid on the pimple and leaving it there until you cant stand it anymore? dries it out and preps for popping. very easy fix.
Jun 13, 2008. 10:55 AMjoey2542667 says:
just pop it!
May 8, 2008. 9:54 PMBox_Full_Of_Sharp_Objects says:
cant you just do it old skool and dab it with mud and wash?
Apr 9, 2008. 2:04 PMlilaznkikas says:
Eensie weensie bit of water and baking soda mixed into a paste also csn help clean acne.
Mar 13, 2008. 11:26 AMSunshine75 says:
How did you figure this out? I'm not surprised it works b/c alcohol dries out the area.
Mar 12, 2008. 10:06 PMBox_Full_Of_Sharp_Objects says:
Im in 7th grade and i has a pimple on the side of my face (you can't see it) i think it's from the natural oils in my hair. Any way to get rid of that?
Mar 5, 2008. 2:57 PMMr. Deeds says:
I had medicine for a while, but I decided to just forget after a while. Alone with taking my contacts out and all that other garbage I have to do every night, it just meant another waste of a couple minutes.
Jan 18, 2008. 2:50 PMsavagesteve says:
Alcohol isn't good for most acne, but putting a band-aid on a pimple really helps! The only problem is if its on your face people think you've been in a fight. I wash my face with unscented cleanser, dry it with paper towel and then apply a round "dot" bandaid to the pimple.
Jan 14, 2008. 5:04 PMIamTheCreator says:
naruto777 is going through pooberty :P Jpin wit yah nart......I might try this sometime
Dec 31, 2007. 1:44 PMnaruto 777 says:
i am in middle school (7th grade) i see many people with acne, including me, an i need a cure, i just ordered some medicin stuff for it and it is working,but who wants to wear a bandaid on their head? that will just lead to more criticisum.
Jan 5, 2008. 6:21 PMBran says:
Scrub your face every day - might sound like a pain in the butt, but trust me - it's definitely worth it. There's a few people at my school who have so much acne, it looks like they scrape themselves with razor blades, being that most of their face is a bright pink color.
Jan 6, 2008. 3:19 PMnaruto 777 says:
i always scrub my face with warm water to open my pores and put the medicine i have on my head and i do this every night before i go to bed, and my acne isnt as bad as what you described, and bran are u a hunter?
Jan 6, 2008. 3:45 PMBran says:
Yes. 'Tis me and my deer in my avatar.
Jan 5, 2008. 1:58 AMAirforce349 says:
Naruto777, I don't know where you ordered your medicine from but the best thing to do is either schedule and appointment with your doctor or next time you are there for a checkup just mention that your acne is becoming a problem and he/she can prescribe some medication based on your age, health, and degree of acne. It really is best way to eliminate acne versus just a single pimple. The doctor knows best....usually.
Jan 5, 2008. 10:31 AMnaruto 777 says:
yes but this said it worked, ( most things do) but this is actually working.
Jan 2, 2008. 3:56 PMnaruto 777 says:
But some people get ready in the morning or don't feel like doing it at night, and I read in a booklet that came with my medicine and it said that rubbing alcohol is harsh, and it ages your skin faster.
Jan 3, 2008. 3:51 PMnaruto 777 says:
Hold on let me check
Jan 3, 2008. 4:05 PMnaruto 777 says:
no it doesnt but this is what it does say.
Isopropyl rubbing alcohol can be cerry irritating to skin. it will strip the top layer of your skin and may actually cause the oil glands to secrete more oil to stay in balence. this can cause more blemishes and dry red skin, especally if you have sensitive skin. and so i dont get in trouble with the coppieright law or something, this came in a booklet that came with a proactive kit, the words that are bolded is the what the book said.
Sep 27, 2008. 3:30 PMoniman7 says:
I know this is a huge delay, and hopefully you got over the problem by now, but... don't use the proactiv. It makes it better for 2 weeks, and then it comes back much worse
Sep 27, 2008. 7:21 PMnaruto 777 says:
no but i got stronger medicin from the doc, people say its working well, but i dont think it is
Dec 30, 2007. 8:26 AMjessyratfink says:
Just a warning - rubbing alcohol is very harsh. Your skin is going to age much quicker if you're constantly drying it out this way. I would suggest using tea tree oil instead, honestly. A little goes a long way.
Dec 28, 2007. 11:19 AMcry_wolf says:
I just pop mine on site and they are gone in a day or so XD
Dec 28, 2007. 3:56 PMcry_wolf says:
I do it in a sanitary way mind you. What is inside is basically bacteria so i squeeze it until it bleeds. Then i sanitize my face by washing it using a cleanser like Cetaphil or soap. After i dry my face it is swollen and tissue fluid comes into to do its job. In no way do i spread the bacteria, etc. Thats just unsanitary and disgusting. Its like taking engine grease and rubbing it on your face.
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:Thornburg
