How to Get Started With PICAXE 08M Microcontroller
Published
Introduction: How to Get Started With PICAXE 08M Microcontroller
This is instructable for how to get started with PICAXE 08M microcontroller.
To get started, you need:
- 08M Protoboard or same kind of board (Can be homemade)
- A LED
- AXE027 USB Cable
- 3V Power supply
Step 1: Connect the Led to Pin 4
Just  connect cathode lead to Ground, and anode lead to pin 4 of the microcontroller like this:
Step 2: Connect the Power and the Cable
Connect the power, and plug the cable to the socket.
Then open PICAXE Programming Editor.
If you don't have it, download it from http://picaxe.com/
Step 3: Write the Code and Press "Program"
Write this code to the editor:
main:
high 4 'LED on
pause 1000 'Pause 1 second
low 4 'LED off
goto main 'Repeat
Then press the "Program" button on the top.
Step 4: Watch Your LED Blinking!
It is ready now, good luck for future!
Links:
PICAXE Downloads - http://www.picaxe.com/Software
PICAXE Manuals - http://www.picaxe.com/Manuals
PICAXE Shop - http://www.techsupplies.co.uk/PICAXE
All the links you need to order, download, and study PICAXE!
Hope you enjoyed! :)
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
    how did you connect the usb cable? I can't see the socket in the pics
    Hey! It's just plugged to usb port of the computer after you installed the drivers. If installing drivers is hard, I can make another Instructable!
