How to Get Waves in Your Hair
102,136
6
7
Published
Introduction: How to Get Waves in Your Hair
Here are some simple steps that it takes to get awesome 360 waves.
Step 1: Step 1. Get All the Necessary Tools and Items Needed for Wave Preperation.
The items that will be needed to get and maintain waves are a good-high quality wave brush, good quality wave gel/pomade, any kind of durag, and a good shampoo and conditioner to keep your hair in shape and maintained.
Step 2: Rub Wave Gel/pomade Into Your Hair
Get just enough wave gel/pomade so that it covers up 3/4 of the tip of your index finger. You need enough to cover your entire head or the area of hair you wish to get waves.
Step 3: Brush the Rest of the Gel/pomade Into Your Hair
Brush the rest of the gel/pomade evenly into your hair. This is so that it is easily absorbed into your hair. This allows for you to have stronger waves due to more hold from the gel. Do this twice a day, once at the beginning and end of each day.
Step 4: Continue Brushing Your Hair for 10 Additional Minutes
You need to continue to brush your hair so that you train your hair to lay down and curl (wave up). This is really what happens when you begin to feel and see your waves. Make sure you brush evenly around your head, so that your waves come in even around your head.
Step 5: Rub an Additional Light Layer of Wave Gel/pomade on Your Hair
You do this just for extra support and hair hydration under the wave cap.
Step 6: Place Wave Cap on Your Head
Now you need to put the wave cap on your head so that it fits snug around your head. This is for your hair to continue to lay down and train itself to curl and wave up. (Wear your wave cap as much as you possibly can during the day.)
Step 7: Take Wave Cap Off
You now take your wave cap off after having it on for some time. You do this to see the progress made from allowing your hair to lay down and absorb the wave gel/pomade.
Step 8: Wash Your Hair
You now need to wash your hair (with a brush) to keep it hydrated and moisturized. You should do this once a week. If you do not do this, you will not get max results. This is because you need moisturized and conditioned hair to get the best waves possible. You need to use your brush while washing your hair, because it will allow you to keep your wave pattern while your hair loosens up.
Step 9: Rub Wave Gel/pomade Into Your Hair
While your hair is slightly damp/saturated, rub the wave gel/pomade into your hair so that it is easily absorbed into ones hair.
Step 10: Brush Your Hair
Brush your hair to ensure that the wave gel/pomade is fully absorbed into one's hair. Continually do this throughout the day and week. Do this for 5-10 minute intervals. Remember, the time and dedication that you put in is what you will get back out.
Step 11: Repeat Steps 2-10
Repeat steps 2-10 daily and weakly to get the best results. Results will differ based on how much time and care each individual takes with their hair. Also you can go through any of these steps out of order except for washing your hair.
Step 12: Wave Achievement
After following each of the steps above for about 3-12 weeks you should now have or be gaining great 360 waves long as your are consistent.
  • Oil Contest
    Oil Contest
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
5 Questions
After you finish and get the waves do you keep doing the process or
stop?
Yes any hair product helps
Hey I just wanna ask if I can still get waves without the wave cap
Well the caps are used to flatten your hair but if you dont have a cap use a pillow case or tie a shirt up like a durag.
Does it matter if my brush is old??
Why once a week?
7 Comments
only if your hair is wave length
Also this works on just about any hair. You just have to have it cut low, but not so low that your waves get cut off. You want to make sure that your barber cuts your hair down to a dark wavelength every time. Not light where its close to your scalp. Lastly, while repeating these steps daily and weekly, you want to allow your hair to grow an extra week or two before getting it cut. This is so your waves will be thicker and more trained/formed when your hair gets cut.
This isn't going to work on all hair types. You must have some natural wave/curl to begin with. Ethnic hair will yield the best results. As a hairdresser, I live in a predominantly white area, and have never had the chance to try this. The results look amazing. Great instructions!
The waves look really nice. Are any of these pictures of you? Thanks for sharing!
Hey these images are not of me, but I do have waves that look similar to these. I just have a different hair cut so they aren't as thick, because im kinda starting over. But because I have taken care of my hair, they still remained there. Just not as prominent. Also this works on just about any hair. You just have to have it cut low, but not so low that your waves get cut off. You want to make sure that your barber cuts your hair down to a dark wavelength every time. Not light where its close to your scalp. Lastly, while repeating these steps daily and weekly, you want to allow your hair to grow an extra week or two before getting it cut. This is so your waves will be thicker and more trained/formed when your hair gets cut.
