Intro: How to hack a servo for continuous rotation - TowerPro MG995
Why would you want or need to modify your perfectly good servo? It turns out that servo motors are great little gear motors that can connect directly...
Parts and tools MG 995 Servo Two 2.2k ohm resistors Soldering iron solder sponge Needle-nose and diagonal pliers Flat and phillips head screwdrivers...
Remove the gear that has the spindle that pokes outside of the servo. This is usually pretty tight, so pull it off with your needle-nose pliers if yo...
Use your flathead screwdrivers to pry the plastic piece out of the bottom of the gear. Try to get the plastic out of the inside of the gear without l...
Just a precaution to make sure the resistors don't short against something. Also, be sure the leads on your resistors aren't making contact with anyt...
This is the code you can use to test your servo if you are using an Arduino. The myservo.write(90); line sets a standard servo to it's mid-point. It...
Bio:Electronics are a newly re-found hobby for me. I'm not an engineer - I'm an ordinary guy who likes to tinker with electronics in his free time. You can see more about my projects at www.meanpc.com. ...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
