3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to mod and old flashlight into an LED one
In this instructable, I will show how to mod this classic model of flashlight into a new LEDs flashlight. Basically replacing the old light bulb with a bunch of LEDs.
Step 1Material
Material
This is a pretty cheap instructable (provided you have the flashlight already!).
You'll just need:
-The flashlight
-18 LEDs
-A bit of a styrofoam tray (or anything that could work as a frame for the LEDs but also that can be pierced, like wood, cardboard, plastics...);
-Some thin wire
And as tools:
-Pliers
-Wire cutter
-Cutter knife
11 comments
Feb 29, 2012. 11:59 PMSIRJAMES09 says:
so what you are saying is, the physical size of the batteries does not matter?
all that matters is the voltage,watts & amps? is that right?
Sir this was a great read, but, being the uneducated man I am, I still get confused easily.
TY for sharing Sir. :)
Dec 12, 2010. 7:45 PMpoppyo says:
This seems like the "mini" version of the full size Army flashlight we carried. You're right, it was carried on the belt, or set on a table or ground. There was, and is in this mini model, and extra bulb in the base. And the different lenses. I just got one each from 2 different Army/Navy stores, one w/ a "prism" reflector. I discovered that the CR 123 or other 3V batteries also fit w/o adaption! So I put a KPR 118 7.2 V bulb from "The Shack" in it and had an Instructable version of a Tactical flashlite that I have been making from various flashlites that I could find. With some trial and error. Like tearing up the insides of the chamber meant for 2 AA batts with a 5/8 " bit. With this flashlite and others, I found I was melting the reflector if I left it on more than a few seconds. So I took off the lens to let it breathe. Working OK so far. I'm having trouble finding even cheap flashlites that are NOT an LED.
Nov 14, 2010. 11:52 PMjflores0731 says:
Quick question: What size LEDs did you use? 3mm? or 5mm
Mar 23, 2010. 10:11 PMunaffiliatedperson says:
ha i had one of those lights. i gave it to my nephew. i always wondered why they were angled like that though
Jul 22, 2010. 3:14 AMsandollor says:
It's a US military flashlight; we were issued them in the US Army. The bottom portion can be unscrewed and has a blue, red, green, and clear lens to change the color of the light.
Apr 28, 2010. 8:52 AMlimonchi says:
it´s angled because you would use it in your pocket or belt, i think
bye
esta en angulo porque se usa metida en el bolsillo o en el cinturon, si no me equivoco
saludos
Feb 6, 2010. 8:59 PMomega23JP says:
sweet  ,   leds rock  ,   here is a torch i converted before i knew of instructables   sites.google.com/site/jpsprojects/home
Dec 13, 2009. 11:07 AMapplesaucemodifier says:
Terrific idea, can't wait to try it out!   :)
Sep 8, 2009. 3:47 PMatombomb1945 says:
Very cool. I have been trying to do the same thing with one of my old Army lights, and a 9 LED light that broke on me. I like your idea of just using a larger amount of lights together. How long do the two D Cells last now? I know the old bulbs you would get between two and four hours.
Sep 8, 2009. 3:49 PMatombomb1945 says:
Oh, and I believe that the word you are looking for is "Styrofoam" for the meat container.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:molusco
