How to Hardwire a Disco Ball Motor to Be Controlled by an External Switch!
1,081
7
Posted
Introduction: How to Hardwire a Disco Ball Motor to Be Controlled by an External Switch!
Ever had a time with a battery powered disco ball motor, where you had to reach up and fumble for the switch?
Those times are over!
Level: Novice
WARNING! IF YOU DO THIS INCORRECTLY, YOUR MOTOR WILL BREAK!!! DO NOT ATTEMPT IF YOU ARE INEXPERIENCED!!!
Step 1: Step 1: Getting Stuff
Get your motor controlled by an ON/OFF switch, battery powered. Link: http://www.ebay.com/bhp/8-mirror-ball
U WILL NEED
1x D-Ball Motor (described above)
1x Audio wire (speaker wire) however long you want your control to be away from the D-Ball
1x ON/OFF Switch
1x Soldering Iron W/ Solder
1x Wire Strippers (or use your teeth)
Step 2: Step 2: Open the D-Ball Motor
Take out these screws.
Remove the switch. (If it comes out intact, great! You can use it in a hack! If it doesn't, oh well, you don't need it anymore...)
Solder the wires that were previously connected to the switch to the audio wires.
Step 3: Step 3: Soldering!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Now solder the other ends to the switch you procured. (not the one you tore out of the motor)
Step 4: You're Done!
Enjoy your new motor!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
3 Comments
Looks great! If you don't mind a little advice, I would recommend against stripping wires with your teeth. You can hurt your teeth badly if you do it (and you probably shouldn't put wire in your mouth anyway- it can contain certain harmful chemicals).
Thanks, and I guess you're right about the wire. But thanks for the comment, and the advice!
No problem! See ya around the site :)
