It's the door that goes outside to our firewood storage area, and we use it regularly. Only issue is, any lock we put on it can be opened by just breaking the glass, and putting your arm through.
We narrowed our options down to two, get a new door without glass, or a double locking deadbolt.
So, after hours of battling with the lock, one side one side working, and the other not, (Bought at home depot, figures) we had to make the tough decision about what to do with the key. We couldn't just leave it in, or put it anywhere close by. That would defeat the purpose.
We decided to disguise it. Read on for details, if the picture isn't enough.
Remove these ads by
Signing UpStep 1Gather your materials and tools
For parts, you need a spare light switch plate, a dimmer knob, and obviously, a key.
For tools, you need a torch (lighter works, torch better), a pair of pliers, and a 4 sided square file, a glue gun, and hot glue sticks.
Also how about a key outside, knob inside dead bolt located more than an arm length below the window.
In an Altzhimer's ward the exit doors had a second knob above head height (and eye level) on the theory that the patients would not see and thus not turn the knob.
True enough about Alzheimer's patients, but you want the stress evenly distributed if someone tries to kick the door in. That would be about 1 meter above the floor, or else one installed 1/3 up from the floor AND one installed 1/3 down from the header.
After all, if they want in badly enough, they will break out the whole window anyway.
you can get one here for 8 bucks
Pretty sure its not the same show.
