Step 2Make the knob and key assembly
First, grab the key with the pliers. You wouldn't want to get a severe burn. Then start the torch up, and proceed to heat the end of the key that'll go into knob. Check every few seconds for when it's hot enough to melt the plastic ring type thing in the middle of the knob. Once it's at that point, turn off the torch, and melt yourself a groove in the knob where the key will reside. Push it down with the pliers until it hits the bottom, then stop and hold the key straight up till it cools. I wouldn't recommend dipping it in water, since the plastic may crack.
Once that's cooled, grab your glue gun, and fill in the area around the base of the key. This isn't completely necessary, if your key is held in good enough by the melted plastic, but I did it for added strength.
Add Comment
