Introduction: How to Hide Stuff in a Floppy Disk
Nobody uses floppy disks anymore so why not turn that unused floppy into a convenient way to hide your things from prying eyes...
So today I present:
Step 1: Dissasemble the Floppy
This is relatively easy, just make sure that you don't break the disk. I used a pocket knife and cut the places where the corners are held together. Put your disk aside for now.
Step 2: Find the Things You Want to Hide
Now you find something you want to hide, in this case I wanted to hide an SD card with some sensitive information (see picture). You can use anything that is thin enough.
Step 3: Make a Hiding Place
Now we need to cut a space for the object to sit in, I traced and cut an SD card sized hole in the disk
Step 4: Put It Back Together
Now you need to put the thing back together. You don't need the soft things but you need the disk. I simply taped the bottom and used the clip to hold it together.
Step 5: Final Thoughts.
You are done. I sugest adding a label to your disk to fool those trying to steal your data.
