How to hollow out a lightbulb
I know this had been done before, but the one before had bad images. They were all blurry.
Step 1Supplies
Basicly all you need is a screw driver and a 1 - 2 inch long nail and pliers.
16 comments
Nov 17, 2011. 7:55 PMmsmall2 says:
This was good, thanks for the help!
Jan 4, 2011. 7:18 AMhonigkuchen says:
"Take off" doesn't exactly describe what I had to do here: I had to hammer really hard.
Jan 4, 2011. 7:16 AMhonigkuchen says:
I don't know if it was for the german lightbulb I used or for whatever but tapping lightly with a screwdriver didn't do anything I had to use a hammer instead.
Nov 24, 2009. 9:11 PMstripedstarfish says:
 Thank you. very good and helpful.
Dec 30, 2008. 5:56 PMchriskarr says:
And you said your pictures weren't as blurry as his! Liar! (Step 5 picture 2)
Aug 5, 2009. 5:06 PMH3xx says:
its a picture in motion dude, its gonna be blurry.
Nov 5, 2008. 12:54 PMNameless37 says:
I got most of the white stuff out with water but i used salt afterwords to ensure there wasn't any left.
Aug 30, 2008. 7:53 PMFather Christmas says:
why do the sprinkles/sand/ salt? i just ran it under the sink. worked fine.
May 13, 2008. 12:48 PMScott_Tx says:
I just hollowed out my first light bulb. I had trouble with the brass end/black glass stuff cause I couldn't get a good grip on it with pliers so I used a bench vice and kept pinching the end and rotating it till it finally got under the brass and I could pull it off with pliers. Then I used a drill and followed down the one wire on the side till the hole was big enough to get needle nosed pliers in and snapped it all out. I used a burn out larger 3 way bulb, it looks neat. Now what do I want to do with it?
May 13, 2008. 3:39 PMScott_Tx says:
No danger of that here
May 12, 2008. 7:22 PMBrowncoat says:
If the bulb's already clear, do you need to do the sand/sprinkles/etc step?
May 4, 2008. 2:39 PMSgt.Waffles says:
Yeah, my pictures were REEEALLY blurry. /sarcasm
May 4, 2008. 4:32 PMjehan60188 says:
relax. Your picture at http://www.instructables.com/id/Light-Bulb-Shrimp-Aquarium/?ALLSTEPS were by no means blurry, but these are sharper.
Anyways, your project is about shrimp, hollowing a lightbulb is just a side-show!
anyways, both projects are neat
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:nm918273
