How to Hook Up a Amp
Introduction: How to Hook Up a Amp
How to hook up amp so it works.
Step 1: Get a Amp
Have an amp that has good fuses in it.
Step 2:
Then, hook your ground wire to the ground hook up on your amp. There are many different ways to run wires through you car so your on your own!
Step 3: Hook Up Power Wire.
You then hook up the power wire to the power hook up! Reminder: Only tighten screws tug.
Step 4: Remote Wire
Then hook up your remote wire, reminder only tighten snug.
Step 5: Speaker Wire
Next its time to hook up the speaker wire from the sub to amp. In this case the wires are blue. The blue wire with the white stripe is positive and the solid blue is negative then hook up logically!
Step 6: Audio Wire
If the audio wire is hooked up right to the stereo, then white should go with white and black should go with red.
Step 7: Done
Now your done, and you should have lost brain cells so good luck!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    I know this is an old post but it has helped me out massively XD many thanks
