3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to identify, and deal with, a design flaw
The Triax watch from Nike is super handy for running, but it has a tragic flaw. This instructable is about how I decided to analyze the flaw and figure out a way to make a workaround for myself.
I've long been a fan of the Triax watches. The designers behind it, ASTRO, even got a Design of the Decade award for it. The big numbers and the tilted face make it a dream to use while running. And yet I never had one until I got one as a Christmas present last year.
While all of the standard features work great with the easy-to-read digits and the lap times, there was one feature that was included that has caused plenty of problems. For the life of me, I have no idea why it's on there.
Step 1Identify the Problem
This situation has happened to me dozens of times. I'll look down at my watch and see that the time is 12:00 am. The watch is stuck in Alarm Set mode because the Alarm Set button was pressed.
Why anyone would use their watch, especially one designed for running, as an alarm system is beyond me. There are clocks everywhere! Alarm clocks, clocks on the walls, clocks on poles, clocks on your computer monitor, a clock on your cell phone. Most of these have the ability to make an awful noise at a set time if you want them to.
In the past year, I've used the alarm function once and that was only as the third alarm that was set because I was so exhausted I figured that I could use every back-up system available. One use per year should hardly make this button so important, but it is.
I'll show you how.
35 comments
Aug 23, 2011. 4:26 PMilpug says:
put a tiny blob of black Sugru over the button and smooth it to blend in. this will render the button unpressable and will match the watch, although it will leave a little black nubbin on the side of your otherwise perfect watch.
Jan 22, 2010. 9:26 PMkid007la says:
I have this same watch and have never had this problem...maybe its just me
May 24, 2009. 2:17 AMcameron20020 says:
you could possibly melt, or trim the button so its sits flush with the surface of the wristwatch, meaning more effort required to press it, though unconventional, would stop the alarm set button being pressed so easily
May 20, 2009. 5:59 PMbarry_allen7 says:
Fantastic instructable! I wanted a watch like that. Maybe if I buy one now, I'll make sure it has no alarm. ;) Thanks!
Jan 6, 2009. 1:00 AMmettaurlover says:
you can sand the button down so that it's a reasonable distance out and make the edges round :) it wouldn't affect the performance negatively; in fact, you could sand it all the way down to the casing and it wouldn't affect the water resistance. the buttons, as i have seen, are actually over rubber seals covering the circuit boards. or at least on the watch that my dad broke trying to change the battery...
Nov 15, 2008. 9:54 PMLithium Rain says:
:D This instructable really did make me LOL! 5 stars for making me laugh.
Nov 13, 2008. 9:50 PMSamuraiGoose says:
I have a nike watch like this one and i could really use it but the issue is the thin strap got rotten and broke. The problem is that I can't buy a new strap cause it's one piece whit the frame of the clock, unlike common watches. design flaw u said? anyway :'(
Feb 28, 2008. 5:32 PMGjdj3 says:
Nice instructable! It's helpful for all of the design flaws that seem to pop up in products.
Jan 21, 2008. 11:19 PMHAL 9000 says:
Dremel the button off, or at least so it is shorter.
Dec 15, 2007. 3:28 PMandresm says:
i have the same watch... and ill liked it a lot! for a month. the glass covering the numbers is sticking out as well so it scratches really easily, there was a point i couldnt tell the difference from an 4 and an 8... as well i have skinny wrists so i had the watch on the last hole. and this caused the strap to fall off.. i glued it on various times and it keept falling off. apart from that, i play american football as well as do backflips and that for fun, and if i hite myself of the watch it resets to 12 00 am of january 1 not because the alarm button but it resets... and the last problem is the alarm button (but i think it was there because in previuse models it was the backlight button) thx, o and my watch broke aboute 2 weeks ago.. and i dont use it anymore :(
Dec 19, 2007. 10:38 PMPatrik says:
Mail the broken watch to fungus - so he can take it apart and figure out how to disable that button! :-)
Dec 12, 2007. 5:25 PMPatrik says:
Heh - you angling for a design job with Nike? :-) They could do worse, methinks...
Let us know if you hear anything back from them!
Personally, I'd be tempted to just file the button down a bit. Maybe even file it flush, so you need a pencil or paperclip to push the button. Might not stop accidental contacts completely, and it'd be more annoying if and when it did happen, but that would make it a much more rare event at least. With a button that small, it seems highly unlikely they would bother to make it hollow, so you should be safe regarding creating a hole to let water in.
Then again, I didn't pay for the watch...
Dec 19, 2007. 4:26 AMmaker12 says:
agree! :-)
Dec 18, 2007. 6:26 PMmaker12 says:
"You can simply find a customer service e-mail address and send some virtual bile that way as well. "love it!
you can make "virtual bile" about business. HEARhttp://www.complaints.com/!!! ;-)
Dec 12, 2007. 11:52 AMTrans_Am says:
Could you not just use a little dot of clear glue, and glue the alarm button in place so it wouldn't do anything? Or file/drill/whatever the buttong flush with the watch? I was expecting something more creative out of you, fungus.
Dec 12, 2007. 1:23 PMzachninme says:
What if you completely remove the button, and fill in the hole with epoxy or something?
Dec 12, 2007. 9:27 PMinventorjack says:
"Impossible to undo"? Impossible!
Dec 13, 2007. 11:26 AMinventorjack says:
Okay, that I can agree with ;)
Dec 13, 2007. 11:14 AMoberpriller says:
I have a similar watch. On my watch, button number 1 doesn't give me any problems. My problem is with button number 2 which controls the chime on my watch. I constantly press it when I bend my wrist.
Dec 12, 2007. 5:20 PMrandofo says:
There are no design flaws.... only unexpected and/or impractical features.
Dec 12, 2007. 6:22 PManotherkill says:
I have the same exact watch on my left wrist right now, and I love it! I use it every year for cross country. It is a great convince to be able to see your lap times as you complete a lap in full screen, and show your current lap and total time at the same time. I use it for time now that the season is over, and I too find it frusterating to look at my alarm set screen. I fully agree with your concept, I guess the instructable is good...
Dec 12, 2007. 4:17 PMGorillazMiko says:
thats a good watch you have there
Dec 12, 2007. 1:14 PMzer0vector says:
If you are as opposed to the alarm button as you sound, couldn't you just disassemble the watch and disable the button from the inside? I removed the speaker from a watch for my g/f that she needed to use during a "no audible alarm" test. I will commend you on the clever alarm setting. I would have never thought of that.
Dec 12, 2007. 1:02 PMWeissensteinburg says:
..plenty of people use the alarms during travel, to remind them to take medicine, to remind them of things that should be done at a certain time (like when cooking) etc.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1413
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
